is there some kind of adjustment i can make to the 2 latches?
i have cleaned them and lubed them with whitl lithuim grease but it still is not working, can i screw out the pins a little further or somthing?
I'm not really sure what you're trying to say here, but on my car, the right side of the hood doesn't go down all the way. I've tried adjusting the pins and checking to see if anything was in the way when I closed the hood, but nothing. It's still higher on the right than the left.
umm.. i think you wanna go to a different forum.. but on my car i just used a screw driver to adjust the pegs.
ill try the screw driver thing tomorrow i think i also need a 17mm wrench,
if you asking about the Fiero pic. it was my first time ever attaching an image so i thought what the heck ill give it a try
Rich,
loosen the nut at the top of the peg.
get a flat head screw driver and adjust the height of the peg.
tighten the nut at the top of the peg.
test the fit.
repeat as needed.
-Ron
Hey man, I'm a professional!
ya, i read that On someones page last night, thank you
