Results 1 to 25 of 33
Thread: I know Mishimoto doesn't make an aluminum rad for the E39, but...
    May 2005
    Meriden, CT
    '03 540i/6 M-tech
    is it just me or does the E46 one look just like the E39 one but up-side-down?
    E39:
    E46:
    I'm going to try to figure out what the overall dimension differences are and if the hose connection diameters are the same or not... if so with some fairly cheap modification (add mounts) we may have a $319 all aluminum replacement radiator...
    OK, so...
    The Mishimoto E46 rad core is 22.8x15.67x2.05 which is 732.4 total area
    The OEM E39 core is a bit bigger in surface area at 25.6x17 but is only 1.34" thick for a total area of 583
    I havent found out about the hose connections yet though...
    2001 330Cic/A in the same color combo is "Her" ride.
    Sep 2009
    UCF/Oviedo, Florida
    (Prd. 5/96) 528i.
    I'm in to hear from your research. I believe the E46 cooling systems have clip on hose attachments. I wonder if the Mishimoto radiator will work for the clamp on hoses? Also Mishimoto has their own set of hoses.
    May 2005
    Meriden, CT
    '03 540i/6 M-tech
    I have a 2003 so I also have the O-ring/clip style hoses... thats the main reason I am looking at mishimoto... for you guys with the hose clamp style I would imagine you can more easily find an all aluminum replacement radiator... its the machined hose connections that make it tough to match up with something form another application or that is "universal".
    It looks like both cars are listed as having 1.5" inlet and outlet so we may have a winner... I can't imagine BMW made 2 cars at the same time with the same I.D. inlet and outlet, and same style connector, but with a different locking mechanisim/connector shape...
    OK... wait a second... the pictures on mishimotos site shows the radiator with the same orientation as the E39...
    yup, it is the same orientation...
    That means the drain wouldnt hve to be moved and the mounts may be a closer match?
    I think I might see if I can get my hands on a junk M3 radiator to take some measurements...
    Bay Area, CA
    1990 BMW 535i/5
    Subscribed, interested to see how this turns out
    Tampa,FL
    97 528IA
    ^ for sure:d
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Ok, but doesn't the Mishimoto's fail as well?
    Dec 2009
    Bellingham, WA
    '00 M5, 79' 633csi, 5.0
    Quote Originally Posted by Jason5driver View Post
    I've heard subpar things about them on Mustangs at the very least.... They're popular but I havn't heard too many super things on them to be perfectly honest.
    Feb 2008
    Upstate
    2 Boosted,1 more left to
    Isnt that what JackEatsEmoKids do for his turbo project?
    This radiator is meant for an E46, but now fits the E39 perfectly lol
    May 2005
    Meriden, CT
    '03 540i/6 M-tech
    Hmm, I will have to dip some research before proceeding... That may be why they don't make one for the e39.... High pressures and they know they get failures at lower pressures?
    Might not be worth it... You can get almost 3 regular radiators for the Mishimoto price...
    97heath528i's Avatar
    97heath528i is offline Eager to learn/wrench BMW CCA Member
    Sep 2011
    La Vergne, TN
    97 528i Canyon Red
    Ok here is the thing then, if you want to proceed with the Mishimoto then you will need to use Evans which produces little to no pressure.
    Dec 2008
    NW & SE
    Why would they fail? I don't see any plastic, unless the joints are weak. Anyone know?
    Sep 2011
    La Vergne, TN
    97 528i Canyon Red
    I am just saying use Evans coolant and there will be no pressure. End of story.
    Minneapolis,MN
    2003 M5, 2014 535i
    Even aluminum radiators fail especially if mounted improperly and or have improper welds.
    I to felt the stock radiators were poorly made hence the reason I don't run one in my 528i but I have since changed my opinion. I believe the biggest contributor to failed E39 radiators, is the pressure at which BMW chooses to run their cooling system. 2 bar (~30 psi) coupled with high temps, significantly decreases the life of the plastic parts in the cooling system.
    This is why both my E39s now run the 1.4 bar cap.
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
    In the wood
    02-530 stick Blown
    Hey Schitzo buddy, have a part number for the E30 1.4 bar cap? I don't have any issue right now but figure if it works for you it will for me.
    May 2010
    Salem, OR
    2000 BMW 528
    In the wood
    02-530 stick Blown
    Quote Originally Posted by Jesus Freak View Post
    http://www.bimmerzone.com/product/VSL-AR-E39M5.html
    1.4 bar cap
    Part# : 17 11 1 742 232
    Thank you!
    Cheers!
    Apr 2006
    Fall City ,Wa
    E36 Turbo, E39 M5
    Doesn't running a lower pressure cap make the boiling point lower in your cooling system?
    93 325is: obd2 M52, 22rpd tuned, 6266, RSI manifold, 555whp on 18psi
    Minneapolis,MN
    2003 M5, 2014 535i
    Quote Originally Posted by 16valex View Post
    Hi Alex, as JF indicated, the part number is 17111742232. I buy the Behr brand from Autohausaz.
    Gary at germanautosolutions is working on a 1 bar cap but I think that is a little on the low side. Then again 1bar (~ 15psi) is the standard pressure cap rating on most cars. Furthermore, 15 psi is the pressure at which most coolant mixes are tested at.
    http://germanautosolutions.com/BMW_Solutions.html
    Quote Originally Posted by E36 328is View Post
    Yes it lowers the boiling point but not enough to cause ill effects. At 1 bar (15 psi), a 50/50 mix of water and ethylene glycol has a boiling point of 264 F. It is obviously higher at 1.4 bar and higher still at 2 bar. There is no reason your engine should be getting to 264F if your radiator and fan are working properly. What this means is, something in the cooling system would have to have failed (e.g. faulty fan, low coolant, faulty WP etc) for the coolant to reach it's boiling point at 1.4 bar.
    Justin, sorry for the hijack.I'll stop now.
    Build Thread
    Quote Originally Posted by Schitzo View Post
    My thoughts were also along this line as well.
    If the E39 runs at a lower pressure = less things to fail, less wear on the plastics.
    And, if the V8's were running Evans on the aluminum radiators, why wouldn't be just as affective/ affordable with the OEM radiator...?
    Are you able to run the 1.4 bar cap on the E39 OEM expansion tank as well?
    I thought it was only for the E30 expansion tank...
    Great information, as usual, Sir!
    Thank you!
    I don't have any issues right now, but I figured if it works for you it will for me.
    1.4 bar cap
    Thanks!
    Dec 2008
    NW & SE
    Agreed. What are your thoughts on Evans if you are looking to reduce the pressure, aside from cost?
    Minneapolis,MN
    2003 M5, 2014 535i
    Quote Originally Posted by jvestal View Post
    I haven't spent much time reading on the Evans coolant and neither do I have personal experience with it. However, I think the "0 pressure" reference is often misunderstood (or maybe I'm the only one confused about it)
    The regular ethylene glycol water mix (EGW) coolant, requires pressure to raise its boiling point hence the reason we have pressure caps. On the contrary, Evans coolant does not require any pressure to raise its boiling point. Per their website, its boiling point is 375C at 0 psi.
    However, that does not mean if you run Evans coolant and retain your 2 bar cap that you will have zero pressure in your cooling system once your engine is at operating temperature. After all, I believe Evans coolant is still subject to the physics/relationship of volume, pressure and temperature.
    So to answer your question, as far as I know, even with the Evans coolant, you would still need a low pressure cap or "no pressure cap" to lower the operating pressure of your system.
    I think that is hinted at in the link below from Evans website.
    http://www.evanscooling.com/how-it-works/conversion/
    Build Thread
    Miami, FL
    '02 530i & '15 X1 35i
    The E46 M3 radiator is much thicker btw.
    You will need to just weld tabs on the top side and use some existing holes on the plastic mounting frame with some screw clips. The two L brackets on the bottom. I will take a pic tomorrow to show you guys how I mounted mine.
    '02 E39 530i/5sp Topaz Blue/Black Interior - MegaSquirt3x - Garrett GTX3582R turbo - E85 fuel - Apex FL-5 - 265/295 tires - Custom Porsche Brembo BBK - 600whp @ 22 PSI
    '15 E84 X1 35i M Sport Alpine White/Coral Red Interior - H&R Sports & Bilstein B6 - Velgen VMB5 - 265/305 tires - ETS FMIC - MPI Charge pipe & DME Flash - 3.5" down pipe
    May 2005
    Meriden, CT
    '03 540i/6 M-tech
    Old thread is Old, but...
    Jack... ever end up getting pics of your setup?
    May 2009
    Madison, wi
    2010 E61 535i Xdrive
    Thanks for bumping this Justin.
    Canada
    2001 M5
    Is the E30 cap a direct fit on E39?
