Add it up. Serious inquiries only. 615.656.5082 MMA. Will Negotiate. E90 Parts Considered.
Late 03 E46 330i. 8500K on Build. Less than 6k on motor. *NO AMATEUR WORK* This car was built for the track by professionals. The owner (an MD) has moved on to a '10 335 M-Spec and wants to recoup. You will not find a better daily driver/track car. E46 M3 parts, Turner Motor Sports Programming Shark Injector, K&N, DEPO, UUC, BimmerWorld, Alcon, APEX, DDM, A/C Schnitzer, Hotchkiss, Hawk, Rogue Engineering, Vorshlag, Genuine BMW.
ALL PARTS LISTED - INVOICES BEFORE PURCHASE
Installed Parts Include:
*UUC Motorwerks*:
-Alcon Big brake kit, 325mm vented, front slotted rotors, calipers
-Stainless steel brake lines
-UUC short shift kit with upgraded linkage and carrier
-lightweight flywheel and high-performance clutch
-Race durometer engine and transmission mounts
-UUC front control arm bushings
-ECU remap-shark injector
-Underdrive pulleys
-Stainless steel Clutch lines
*APEX Racing*:
-18x9" ARC-8 lightweight forged rims
-AST 5100 monotube, gas pressurized coil-overs with GT springs. 450 front, 550 rear
-Vorshlag front camber plates
*Bimmerworld:*
-Race-grade Powerflex rear subframe bushings
-RTAB (Rear trailing arm bushing) Delrin limiters
-E46 rear subframe reinforcement kit
-Ground Control premium adjustable rear lower control arms
-Rogue Engineering front strut tower RACE brace
-Rogue Engineering heavy duty rear strut mounts
-Front strut mount reinforcement kit
-BMW center caps
-E46 M3 gas tank baffle
*Turner Motorsports:*
-M-tech aluminum front control arms with spherical bearings
-Euro-spec LED clear rear taillights, side and front lights
*Out Sourced*
-K&N Cold air intake kit
-Supersprint headers ( Currently stock Headers are in place)
-Full ZHP exhaust
-M-tech brushed aluminum pedals
-M-tech 6-speed weighted shifter
-M3 steering wheel cover
-Revised instrument cluster (Chrome Rings)
-Trunk Lip spoiler
-Roof spoiler
*Tirerack:*
-255/35/18 Dunlop Direzza Star Specs
-Hotchkiss high performance, hollow rear swaybar
-M3 Power slot replacement rotors for Rear subframe
-Hawk performance ceramic pads
*Custom-sourced parts*:
-e46 M3 rear subframe (3.62 ratio limited-slip M-diff with M3 rear brakes,
suspension geometry)
-New m3 rear drive-shaft
-Front subframe reinforcement kit
-Revised interior with black german-sourced berber cloth centers and
micro-suede bolsters
-Black-out trim
-Tinted windows
-M-stiched shift boot
-M-stiched E brake cover
*DDM Tuning*
-E46 DEPO projector46 Headlights (HID & Angel Eyes included, 6000k Angel eyes)
-DDM HID kit slim ballast
-DDM code eliminators
-35 watt bulb H1 bulb color 4500K
-E46 sedan Euro corner lights, titanium trim
-Chrome Amber signal and marker lamps
-E46 Sedan side marker, clear
-E46 M3 Front Bumper w/Fog Lights OEM BMW
***New m54b motor place at 145k miles. New motor with ~60k on it.***
--New BMW fuel pump and Sucking Jet Pump.
M3 front bumper, color matched molding rear ZHP trunk lip spoiler, rear window roof spoiler A/C Schnitzer.
Black trim painted with acid etching primer, base black, clear coated
Needs CVV. I'll include it installed for $600 over agreed price.
The world needs anger. The world often continues to allow evil because it isn't angry enough. -Bede Jarrett
What's your asking price?
idk man.. it seems like you put a lot of money in the wrong place. I think you'll have a hard time getting $20k for it but GL
2015 M235i 6MT
