Results 1 to 11 of 11
Thread: Trunk lid open dash warning, when it's clearly not open.
    Mar 2012
    Michigan
    1994 BMW 525i Touring
    This just showed up the other day while driving home. Said the trunk on the touring was open, pulled over opened it and shut it and the warning went away. Now it's appearing again. What could the problem be?
    Feb 2010
    Australia
    92 525i
    frayed wires in the hatch harness might cause the warning? But I'm not really sure...
    Arlington, VA
    1997 BMW M3 NASA GTS2
    Guessing frayed wires. It's a problem on both the sedan and touring, but more common on the iT's. I believe they run down the left side of the hatch. You might have one where the insulation has come off or worn down. If the circuit is open (i.e. a cut wire) then it'll trigger the OBC message... I think.
    2011 F-150 FX4 | 1997 BMW M3 #404 GTS2 | 2006 BMW M3 Convertible
    Out Motorsports
    Jun 2010
    Flint, Michigan
    '94 530iA, '93 525itA
    Or it may just be the sensor/switch needs adjustment, mine does the same thing. I can go push down on the hatch and the message goes away, sometimes it'll go away by itself.
    OT Snozz...I'm gonna be wrenching on a lot of underside issues I have soon, if you want to help/learn you're welcome to join me.
    Give Blood, Play Hockey
    Apr 2009
    Driverseat
    e38 Msport, 2 e53 x5 4.6
    switch is on its way out. replace it and your be fine. As well do look at your wiring.
    Texas
    2002 330i, 1989 535i
    I have a similar spaz trunk open warning, though looking into my trunk through the ski pass, I can see the trunk lights not coming on, so it is a problem beyond the switch. I am fairly certain mine is due to a faulty check control module, but have yet to prove that.
    Dec 2009
    Auburn Ca
    525it,330iZHP,535is
    I had a similar problem on my Touring I had to slightly adjust the arm tighter on the glass hatch actuator.It had become a little loose,adjusting the arm with a screwdriver so it had more tension on the hatch bayonet (carefully) cured the problem for me.
    1994 525it Sunroof delete , S52 obd1, 5 speed , Spax springs ,Koni shocks, T-Stars
    Link to my Touring 5 speed swap Photos
    https://picasaweb.google.com/Johnny5...eat=directlink
    Mar 2012
    Michigan
    Thanks for the responses. It was just the wires that were causing the dash warning. It's all good now.
    Mar 2005
    Long Beach, CA
    93BMW 525i/95 BMW 540i/6
    Quote Originally Posted by Sparke34 View Post
    Where is the switch?
    USC Ralph - Long Beach, CA USA
    1989 E34 White 525i (M20) 310,000m (Sold)
    1993 E34 Black 525i (M50) 308,955m
    1995 E34 Calypso Red 540i/6 (M60) 201,254m
    1993 E34 Black 525iT (M50) 138,500m
    Mar 2005
    Long Beach, CA
    Found the switch. Looks like it needs to be replaced.
    Mar 2010
    NYC
    e36 M, e30 m, e90
    Where is the switch located?
