While sorting out pics. If your heater/AC fan does not work, works only at full speed (mine did that) or does other funny things you probably need to replace "sword".
Here's how to find it and replace it.
Access to i is on pass side under dash (you need to remove under dash and one side panel):
Here it is:
You need to disconnect electrical connector and remove 2 Torx T20 screws. Also disconnect air duct:
Pull "sword" out:
One can replace power transistors (google it) or just buy rebuilt one for $100 - I did that.
Now my luxury coupe has fan that works at all speeds.
Oleg.
Thx, I need to do this.
My blower fan is starting to get persnickety, sometimes only works at full speed, and I have to turn the knob to max in order to get the fan on and it still blows at low speed.
What exactly does the sword do?
it would be nice if you check back maybe 6 months or a year from now to let us know how the rebuilt sword is working for ya. For some reason I remember reading that this was one of those items that was "preferred" to be OEM.
CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
My other projects:
Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
Nice to see someone who loves 8 so much and can shell out $1,093.22 for new sword module (link).
I'll try remember to post in 6 months. "Rebuild" process is to replace four MOSFET's that are off the shelf part. Here's list of links to DIY rebuild pages:
http://www.bimmernut.com/forum/7-ser...centrated.html
Oleg.
Oxford Green Metallic, Parchment leather, 854 badge, EDC stock struts, M-Sport springs, 3.91 LSD, CSI rear sway, 18" M-Pars, M-Sport wheel w/flappy paddles, CD-43 head unit, Strong Strut brace, Euro FTPs, CSI rear defuser
Previous -
'70 2002
'92 525it e34 - Touring
'97 530i e39
'06 325xi e91 - Touring
I did this repair (according to SHOGUN) when I first got my car over 7 years ago, and it is still working as advertised. Total cost of parts was less than $4 at the time.
Glad I did not get OEM, but considering ALL of the money that was dumped into Esmerelda, I guess it really would not have been noticeable.
'93 850Ci - Mineralweiß Metallic
2001 740iL - Titansilber
ALPINA B7 -Alpinweiß III
I have replaced the sword in my e32, but obviously not in the e31. Removed the 2 screws, but the duct is not playing nice, feels like it is pivoting on something up on the inside. Like a screw or press clip. Can’t find my good mirror, so will get new mirror tomorrow and if have to pull the glove box.. seems silly though.
reading a post on another 7 series board they talked about an underdash microfilter accessible when changing sword. do 850 have this part as well?
No. Thank god ours is right in the top of the engine bay.Originally Posted by lloydsss
thank you sir.....
For some of you that are wondering why the duct is a little troublesome to get out, I pulled the top glove box and found a press clip that was holding it in place. I felt real stupid until I took the time to investigate. In my opinion easier to investigate rather than break plastic in a 21 yr old vehicle
Now the hard part, sword replacement did NOT fix the problem of each time I take the fan control center knob off the full left detent. ALL lights on the AC heater controls go dead and all heater-AC operations are dead. If I put the fan ALL the way to the right, starts working. I am not going to put this thing back together until I get it fixed. So either the IHKA control unit in front of the sword (I have a bad one I replaced in the E32 years ago) or the actual center console control unit, or is there something else in the crevices of this beautiful beast I don't know about?
I agree, after reading the ETK, I see there are about 20 different variables that could be a problem and I do not see any reasonable code readers for reading the IHKA codes on an older vehicle. Will button it up enough to drive, and hopefully my local BMW dealer can get me a readout. I can only read engine codes with the peake.
Thanks,
Jack
I bought a sword on EBAY few years ago and found literature from this website in the pkg.
www.programainc.com
Looks like they do rebuilds and sell refurbished swords amongst other items.
I assume the one I got was a refurbish item, works great.
Just an FYI, no affiliation.
Dan
Would this fix my issue with heat in the foot wells? Or is that something completely different? Was going to pull things apart and look into it, but it is raining.
Finally had time to get the codes $117 at the dealer (plus $20 tip to the tech)
IHKA fault code 1:
Temperature control wheel, right
Short circuit to B-
IHKA fault code 31:
Air-volume control wheel
Short circuit to B-
So looks like I box up the center console control and ship it off to programa.
Jack
if someone wants to have his sword rebuilt and tested, contact E32Fan on the E32 forum, he is our expert electronic expert and even has set up a test module to test those items after repair
http://forums.bimmerforums.com/forum....php?t=1861067I have everything mounted and connected, so I have a complete E32 IHKA test stand with all the electrical components - including a Blower and a Sword. I do not have Heat Exchangers or Evaporator, but I do have simulated thermistors for each of these, so I can pretend.
I even have a panel with 10 stepper motors on it (2 rows of 5).
So the Module Under Test (MUT) can include:
1. Sword N2
2. IHKA controller A11
3. Switch Unit S26
4. Blower motor
After I repair a few Modules, I will understand the common failure modes and fixes.
Please send me any defective or intermittent Modules you have lying around, so I can work through a representative sample.
we sent him a lot of other parts so that he can make testing units
http://forums.bimmerforums.com/forum....php?t=1769254
I do have a bad e32 module. will forward..
Nice to see you still taking care of the e32 crowd.
I will probably never let mine go (e32).
Jack
HELLO
My name is David Moore and I have a '95 840 Ci and the fan stopped blowing. In the beginning, the fan only blew on high, then the high stopped blowing. Do you think this is this caused by the sword being bad or the final stage resister or what?? Thanks for any help you can provide and for your pictured install.
Thanks,
David Moore
San Diego
blower fan speed is regulated by the sword.
There are now some diagrams on my website
http://twrite.org/shogunnew/topmenu.html
under reference data>>sword schematic
more here with plug pinout etc http://www.e32-schrauber.de/bmw/s-heizschwert.htm
How timely. I hope to replace mine tomorrow at the SoCal 8s WrenchFest. That is if I can get the damn thing from UPS.
Where did you buy your replacement from?
Mine died last month...thanks for the link.
