- indicator problems help
hi guys i own a 1996 328 and would like to ask if anyone could shed a light on a problem i seem to be having regards my right hand indicator, i have changed the colum stalk but it still didnt work,then i was informed to change the relay under the bonnet "black one" with approx 6 or 7 pins on the under side, this got the indicators working for around 2weeks and it has happend again its the right hand side which doesnt work the car has a cat1 alarm and imob fitted and when its armed or disarmed all the indicators flash, but it refuses to flash when operated by the stalk has anyone any ideas as to what may be causing this "relay" to go it was a new relay which i fitted is there a uprated version of this relay??? please anyone know a cure for it,thanks guys for your time on this daz
- You may not post replies
- You may not edit your posts
Forum Rules
