Are you looking for Type IIs? 17s or 18s? 1 piece or 3 piece?
Don't know if I'm looking for either, really.... Why? Whatcha got?
I haven't driven my car in about 8 weeks?... Major changes have taken place and I have yet to experience any of them!!! (LTW flywheel, Short shifter, 3.15 and of course, the new suspension)! It's gotta feel like a totally different animal!
I am waiting on a new power steering pump and reservoir.... to arrive tomorrow? Hopefully, getting it all buttoned up and back home!!!
I am so STOKED!!!!
Gone but not forgotten:
'95 540i/6 M-Sport. GA65474. Alpineweiss/Parchment.
Supercharger project
I'm thinking you're going to really like it... the combination of lw flywheel and 3.15 really works well to wake up the 540/6.
991 | 964 | G55 | D90 | LX570 |
Past: SC'd e34 540/6, CSL'd E46 M3, E36 M3/4/5, E36 M3 turbo, E36 M3, 335D, Porsche 951, 80 Series LC, Kleeman E55 Wagon, LX470, 970 Panamera TT, E92 M3
I can't wait to hear how it goes gixer, LW flywheel and 3.15 are in bold on the to-do list for my car. And come to think of it, so is the new suspension (already have the short shifter part)..... sounds like we have similar thoughts
I've got six 3 piece ACS Type II headed my way. Not sure what I'm going to do with them yet.Originally Posted by gixxerboy63
6? what widths will the 2 spares be?
gixxer -car is looking very clean....and you're doing all the stuff I need to be doing. I love the 3.15 for DD'ing and will definitely do the flywheel and solid mounts when my clutch goes....whose demise I am trying my best to expedite.
e34 540i/6 :: e30 M62/6 :: e30 318is :: c5 Z06
Things that made it onto the car within the last few days....
Finally! The corrected 215mm DSSR with new shift knuckle
Vogtland springs:
Koni Yellow Adjustible shocks and struts:
...along with new shock mounts and spring pads
Got rid of these nasty, dry rotted door handle trims;
small cleaning detail
New trims;
Installed;
New thick mats from Bav Auto and aluminum pedals....
Going onto the lift area for the suspension swap!
It's been a good week thus far! I will post pictures of the newly installed Vogtlands/Koni setup on the car a little later....
Did you get the pedals from bav auto too? They look sweet. How much?
Looks great!
Thanks, Brandon! I really appreciate your imput, especially after all the effort you have put into perfecting your car...... Maybe we should put together for a photo shoot when I'm closer to being finished?
I want to hear about the konis and vogtlands once you're done!
540 brake ducts
It's just an add on pc?
Yup. I believe there is a DIY on e34.net. You have to get the OEM ducts and brackets and then cut away the factory lip.
Gixxer, would love to do a shoot sometime.
Let's set it up!
Also.... Up for grabs is my H&R sports (BRAND NEW!) and used KYB stuff...
Check it out here;
http://forums.bimmerforums.com/forum....php?t=1857316
Are you coming to bfest East? if so, you will be passing through so let's make it work then and caravan
I got my DSSR figured out, the suspension installed and the car has finally been put back together today... I have been waiting weeks, no MONTHS for this day; It was supposed to be monumental!
.....However, I got a call from the shop and was told; "The car looks great, sounds great, the differential is awesome and it shifts great, but Dude, you're not going to be happy...."
What?!? WHY? apparantly the car has developed a vibration between 1500-2700 that will drive you crazy. It almost feels like a bad CSB or driveshaft, but at idle with the clutch pushed in... This is not what I was expecting!
I didn't have any vibration prior to all this work. I know that a lot of changes to the driveline has occurred and we're jsut trying to figure this out....
New Diff, new CSB, New Guibo, New tranny mounts, New engine Mounts, New OE Sachs clutch kit and the original dual mass flywheel has been changed to a 13lb JB racing LTW flywheel. The flywheel came "0" balanced and we also "0" balanced and indexed the new pressure plate to the flywheel (according to JB Racing's instructions) and installed it using factory torque specs.... I have no chatter, but I have vibrations..... this can't be normal... is it?
The vibration is at it's worst at about 1800rpms.... It doesn't matter if you are driving the car or sitting still with the clutch pressed in.
Is this a characteristic of a solid flywheel as opposed to a dual mass?
Is it because of the Poly engine and mounts stiffened everything up too much? (these are the blue ones, not the red ones, but still much stiffer than stock)
Combination of all of the above?
Or can there be another issue altogether?
NOW WHAT DO I DO?!?
I put in some UUC Black trans mounts in my M5 and had the same thing happen.
I have not been under the car yet but I am pretty damned sure I did not screw up reinstalling the driveshaft or flex disc.
Current Fleet:
E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
Past:
E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
E39 1998 528i 5-Speed Black on Black - Sold locally.
E34 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
Well, I can say with assurance that it's not the mounts. I have the same mounts, and I don't have any vibes like that at all. I'm wondering if that new flywheel is perfectly centered on the crankshaft - it did fit snugly on the hub there, right? If I remember correctly, they're supposed to be 'hubcentric' just like the wheels are, so if there's something amiss there it could be an issue. Also, check your fan - maybe it threw a blade? Hopefully you find it (or more the guys that did it - you paid mechs for a reason, it should be on them to find and fix this if it didn't do it before).
Fox
Any chance they forgot to put the pilot bearing back in? When I did my M52 swap, the block came out of an auto and when I installed it, I forgot all about the pilot. Luckily a few months later I did the UUC clutch and had already realized the problem so I took care of it then. Made a similar noise.
Awesome thread, I somehow missed it until this morning! I love white E34's with M-pars, and it will look even cooler if you put the M5 U.S. Filler plate on it.
Welcome to the club.
