I have an 88 e30, recently under hard acceleration i am not getting any power to the real wheels, the engine just revs up, if I let off and ease the accelerator back it continues to accelerate fine. I was thinking there might be something going on with the limited slip, it has an e36 M3 limited slip in it, though I might be wrong on this. Any thoughts?
Thanks.
It really sounds like you just need a new clutch.
Jim Levie, Huntsville, AL
I really can't picture any scenarios that would be temporary, other than wheelspin, that would involve the LSD. The diff either transmits power or it doesn't (because internals are fubared), regardless of how much force you're putting into it.
It doesn't sound as if you've noticed any wheelspin, so the remaining choices are all upstream of the diff (clutch, fuel injection issues, etc).
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
yea if the rpm just climb under hard accel, or on a hill, without the car moving forward or accelerating then it sounds like you might have a bad clutch.
1991 BMW 325i(Current Daily) (S52)
I have carburetors, and I'm not afraid to use them!
There are always other fish (engines) in the sea (Craigslist)
Life is about enjoying the engine you are sitting behind.
dude thats your clutch.
STOP PM'ING ME ABOUT MY WHEELS
-Crager D-window , 17x8 et0 (then add 12mm spacers up front and 15mm spacers in the rear). falken ziex 912 205/40/17
Thanks everyone!
Im having the same problem.85 325e 5speed...I was on the highway and noticed when I gave it gas the RPMs dropped.??The next day I took a ride around the block and noticed when I put it in gear release clutch and give it gas the car revs high and barely moves.Whats going on?Do I need a master clutch?Slave?Another member had sad that it might be a bad timing sensor??
I had the same problem...until I read the back of my car and it said "318i"
I have the same problem BUT mine's an Auto.
My driveway's steep too so it'll only make it up in reverse
Or at the very least check your tranny fluid level. Many differences between an auto and a manual in operation, including the auto tranny not engaging gears at all if fluid doesn't get to where it is needed.
Metal Bumpers Are For BEEETCHES!!!!! "King of Lean" - Retired
"If that bikini isn't made of Micro-Fiber and has Quick Detailer on it then GTFO!" -BabyM
That one made my day... Lol hehe.
I have to say i do have a 318i, and acceleration is notnexactly what it was when i got it. It still moves, but not quite as it used to.
I did clean my maf, changed the oxygen sensor and etc this year.
But one thing i know ill need to change is my differential.
Its leaking oil a bit.
It might seem like a newb question,
But what are the "symptoms" of an old differential, a past due one ?
Thanks in advance
So when you floor it in say 1st or second gear, it revs up really fast but barely moves? but if you do the the 5th gear test (20mph, quick shift to 5th and floor the gas) it just bogs?
Either your clutch is just starting to go out or something is seriously wrong in your drivetrain (read, you have an alien drivetrain).
Just went out and drove it again. After it was at operating temperature I once again had a ever decrease in power an a smell. Car started to get hot and if I pushed in the clutch car would slow. I pulled over so as not to burn up my fresh swap. Let it cool for 15 and tried to push the car, no joy. All brakes were stuck so I popped out the booster check valve and brakes released.
I now don't know if the problems are related or not.
It sounds like your booster isn't releasing. That could be from a lack of free play between the pedal and the booster, or a fault in the booster.
