Originally Posted by
bass528
Fal kindly tell me if Im updating my folders properly. Im combining the3 ecu folders from ediabas into one, and using ediabas 6.7.4, leaving the bin folder and others alone. Does this properly updates ediabas from the three inpas? I have learned that if your thowing an old ECU folder into a newer ECU folder then you should click no to replace the files when windows asks you. However since there is no "no to all" you will be pressing lots of No's. To simplify this, you throw the new ecu files into the old, ( rather then old into new)and in this case you can press yes to all. But you will be replacing the files that have the same name with the new version. Which is fine since we dont mind replacing old files with the same name to new ones. For the most part while observing the file size during each file windows asks about. I noticed that they are the same size, with the exception to a few that are slightly bigger in size. Not many though.
To get a visual on this, I have the 3 diabas folders opened Ediabas from inpa3 ( ediabas 6.4.3) on the left, Inpa 5 ( ediabas 6.4.7) in the middle and inpa10 on the right. With a new folder called ECU modified under the three. The middle ECU folder from inpa 5 gets thrown into the ediabas modified folder. Then the inpa 3 on the left gets thrown into the ecumodified folder, you will be asked if you want to replace the files with the same name. Since its an older inpa 3 ( ediabas 6.4.3) going into inpa 5 ( ediabas 6.4.7) Then I click no for replacing the file. What this does is it adds any files form the old ediabas without replacing the already exisiting newer ediabas 6.4.7 files. Then I take the ecu files from ediabas from inpa 10, and throw them into the ecumodiefied. This will give you a prompt if you want to replace the exisiting files, since its a newer version, here I click yes, as a result I get the newer files plus any extra files. The number of files you get in the new ECU folder is 1141 files. While inpa 3 had 740 files for the ediabas ecu folder, inpa 5 had 947 for the ediabas ecu folder and inpa 10 Ediabas ECU folder alone had 1088 files. So the combo of the three gives you the total1141 if done right. This ECU folder gets thrown and replaces whatever ECU folder I have.
Now Im still testing doing the same thing with all 3 inpas cfgdat and bin folder.
We are also looking forward to finally do what Jay has originally asked in this thread, is how to update the daten files, but first we wanted to update our inpas, and ECU folder before we move onto the ncsexpert daten/ECU files. Big file mess I tell you.Hope it works out at the end. And we all have a diagnostics and coding system built to its optimum levels giving the least amount of errors. All the best and wish everyone to have a powerful functioning Ediabas suite.
We will be currently testing the new ecu folder and how it plays with the modified inpa.
If all goes well then we will move onto the daten files and ncs expert or NFS in the EC-APP folder.
Cheers to all.
