Results 1 to 20 of 20
Thread: Halo Rings Dim on 1 Side
    Jul 2003
    Severna Park, Maryland
    2013 M3 Comp 6mt
    Question Halo Rings Dim on 1 Side
    Question. I have the Depo Euro ellipsoids w/ angel eyes. My halo rings are dim on the left side and I can't figure it out. My headlights are fine and the fuse is new. Is there a bulb(s) to replace?
    ///MLOVE
    1993 325is (Jet Black) (sold)
    1995 M3 (Cosmos Schwartz Metallic) (sold)
    1987 325is (Jet Black) (sold)
    2001 M3 (Laguna Seca Blue) (sold)
    2004 X5 4.4 (Sapphire Black Metallic) (sold)
    1997 M3 Saloon (Cosmos Schwartz Metallic) (sold)
    2003 X5 3.0 (Steel Gray Metallic)
    2013 M3 Competition (Lemans Blue Metallic)
    Jul 2003
    2013 M3 Comp 6mt
    ///MLOVE
    Jul 2003
    2013 M3 Comp 6mt
    ///MLOVE
    Feb 2002
    Northern Va
    A KICK A$$ 88 CHEVY NOVA/05 G35
    Are depos using an LED to power up the rings cus if so that may be your problem. Other then that i would check the light source itself what ever it may be that lights up your rings.
    Jul 2003
    2013 M3 Comp 6mt
    I am not sure. If they are, what should I do?
    ///MLOVE
    Jan 2003
    Still in Seattle
    95 M3, 05 F-150 STX
    check the connections to see if they are all secure. Did you have to wire them up to your parking lights? That could be the problem.
    Jul 2003
    2013 M3 Comp 6mt
    My parking lights are bright. The connection is fine. I put a new connector. Is there an led bulb. The headlights are fine. The rings glow very dim.
    ///MLOVE
    Jul 2003
    2013 M3 Comp 6mt
    ///MLOVE
    Jul 2003
    2013 M3 Comp 6mt
    ///MLOVE
    Feb 2001
    Nor Cal
    97 M3
    we can't help you unless we know what kind of setup you have
    97 M3/2
    Jul 2003
    NYC
    11 328ix, 08 Q7, 93 Ty
    Check the ground wire. I had a light on my old car that was dim and even changing the bulb I had no luck. It ended up being a bad ground wire connection. After cleaning the ground and putting it back together the bulb was bright again.
    Just an idea.
    Jun 2003
    Cape Cod, MA
    95 M3
    I was told its because it might be cold out and they need some time to warm up. Same thing has happened to me. I actually just hit my headlight and for some reason it just went bright again. I dont think its anything to do with the wiring.
    Jul 2003
    NYC
    When you hit the light what do you think is happenning? The wires are vibrating becasue of the hit and maybe you got lucky to get the wire that is causing the problem to move and start working again.
    Again just an idea.
    Jul 2003
    2013 M3 Comp 6mt
    How do you change the led bulbs? Do I go from the back of the head lamp or from the front through the glass? There should be an easy way to get to these since they will go bad eventually. I am going to remove the whole lamp and try to change the led bulbs. I will check connections in the lamp itself. I tried new headlight bulbs and tried reconnecting the red wire with a new tap connector. That didn't work. I am open for all options.
    ///MLOVE
    Jul 2003
    NYC
    Mlove, you stated you looked over the red wire which that should be power but i dont think that is the problem becasue you have power there. The lights are on but they are dim. Well if the ground is also cleaned and connected well then it sounds like the led's like you stated or somthing internal.
    good luck and keep us posted on what resolves it and sorry i couldnt help much more.
    thanks
    Jul 2003
    2013 M3 Comp 6mt
    Does anyone know where and what LED bulbs to get for the hyper white angel eyes in the Depo ellipsoids? What is the volts or watts? I've got to fix this problem.
    ///MLOVE
    Feb 2001
    Nor Cal
    97 M3
    please post pics of your setup
    97 M3/2
    Oct 2001
    GA mountains
    GT3 RS, Miata R, F31
    Have you inquired about this with the supplier or manufacturer of the part? They will be able give you better assistance.
    "Way-dull" Racing #74
    Jul 2003
    2013 M3 Comp 6mt
    I bought them from a guy by the name of Steven Chiang. He was selling these lights on ebay awhile back.
    ///MLOVE
    ATX
    BMW M3, MBZ 190E, BMW 530i, TOYOTA PRIUS
    Ok MLOVE..
    Take out your headlight assembly. Take it all apart and make sure the connections are good.. the LED is on the top portion of the angel eyes.. you can change them out for different colored ones all you want..
    For halloween I am goign to have orange and green LEDs.. for Xmas .. red and green!
    yes im very festive.
    [phêär dàs ùßèrsñåx]
    «[1990 19ÖÉ 2.6]» RIP
    «[1998 ßMW ê36 M3]» Sold
    «[2003 ßMW 530i]» FOR SALE!
