some people say that m3 e36 abs is different than non-m3 abs. That tune in m3 is more aggressive. But, in bmw on-line parts catalog abs ecu have same part number for all models:
http://bmwfans.info/parts/catalog/34521163089/
abs sensors have same part number.
So, what is differences between non-m and m models? abs pump and brake boster have different part numbers but if I am correct abs pump only close and open oil flow to callipers? Correct me.
I ask because want to know if I swap calipers, rotors and abs pump to non-m3 model do I have same functionality?
thanks
http://www.youtube.com/watch?v=Ocrvaw3d4UM Dont drive over limited speed!!! Drive safely......
You should be Fine, as long as you also use the M3 front spindles.
(The E30 M3 has different programming in the ABS ECU.)
Sensors are the same.
m
Don't forget the master cylinder.
What year e36?
of course, master cylinder...
probably parts will be from euro m3 e36 evo, 96-99, obd2 into same year e36. why is year important? abs ecu from 93-95 m3 have different part namber.
