Results 1 to 25 of 69
Thread: E31 DME 1.7 INPA without EWS - working
    Europe
    bmw
    Some people probably noticed that You cannot connect with INPA to DME's in early model E31's. This is becouse it doesnt contain EWS and there is no scripts for nonews version. You must know that INPA is not a public program and has been leaked from BMW.
    Now, this post is to report that our friend "guest" from e31-klub.pl fixed that issue and modified both scripts! They will probably be public very soon.
    [ame]http://www.youtube.com/watch?v=rtJP2FjsUK8[/ame]
    Oct 2008
    Madrid - SPAIN
    850iA - 1990
    Good news !!! If it could be shared, it will be and excellent input to the 8 supporting community.
    Thanks for the info.
    Nov 2009
    WI
    01M5,72TA,06LBz,850,540m
    Subscribed
    Orange County, CA
    94 840Ci-6 and 01 740i S
    "leaked from BMW?"
    I think you mean stolen.
    Don't get me wrong, I am all for using any tools that can be accessed, but let's call it what it is.
    Northern WA USA
    91 850i +++
    Actually, I think "leaked" is more accurate. BMW is probably the most lenient car company around when it comes to sharing their proprietary info. I suspect that lots of stuff is willingly shared, if not necessarily broadcast. You can pick up the phone and call them and generally get an answer. All the parts lists and repair manuals are posted online by BMW directly, at least for the older cars, and most everything else is treated as an open secret.
    How come the middle half of any project always takes the most time?
    Europe
    bmw
    http://www.e31-klub.pl/m70_non_ews_e31klubpl.rar
    This is the first alpha release by guest so all comments are welcome. Please write about all problems in this thread. Two first are exact copy of originals but without checking immo. The last one is a completely new one that integrate both so You can see both sides at the same moment working together. You need to copy this ipo file and replace L or R side and then select it in INPA.
    Have fun.
    Nov 2007
    Belgium
    Made in Germany
    Great news for M70 owners! Even more amazing is the simultaneous left and right bank view. How many times I wished for that... Does guest have plans to implement the "dual view" in the DME17 with EWS as well? Or can the modified non-EWS version be used on EWS cars too?
    Backup download link because the original link is no longer available:
    https://revtor.be/guest/m70_non_ews_e31klubpl.rar (all credit to guest)
    Europe
    bmw
    It has not been tested but it will work on EWS cars too.
    Jun 2012
    Uk
    1994 850csi rhd
    Amazing! I was just trying to use INPA today on my CSI, this worked a treat. I can't figure how to get both views though. I placed all 3 files into C:INPA/SGDAT and replaced the 2 existing files.
    Thanks so much for releasing this.
    Europe
    bmw
    You need to rename the dual-view file to one of those L or R files, and select the correct one in inpa. You will not have any additional options to choose from, so You need to put the dual-view file in the place of one of the sides.
    Jun 2012
    Uk
    1994 850csi rhd
    Right I see, thanks for the explanation. Would it be possible to edit Inpa and add a Dual M70 option that points to that iPo?
    That would be cool.
    Jun 2012
    Upper Silesia
    go to INPA dir -> CFGDAT -> edit file BMW_ALT.ENG,
    find [ROOT_E31_MOTOR] and add line "ENTRY=DMEBOTH.IPO, DME 1.7 both motronics,".
    You can also start that script by right button mouse click -> open with -> select the INPALOAD.EXE from path INPA/BIN.
    greetings
    Jun 2012
    Uk
    1994 850csi rhd
    Quote Originally Posted by quest View Post
    greetings
    Awesome! you the man!
    Nov 2007
    Belgium
    Made in Germany
    quest: What tool did you use to decompile the original *.IPO files?
    Jun 2012
    Upper Silesia
    I didn't use any special tools, linux mcedit only - it was quite easy, but of course took more than few hours. The source code after compile gives equal md5 sum with the original, so it is 100% bit perfect. I deleted the version checking from original, and released that scripts. I know that battery voltage, temperatures, and fault reading is problematic with non-ews cars. I am looking forward for feedbeck from you (screenshots, videos).
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    Hi quest,
    superb job done
    Unfortunately I can't extract the files. It says "header broken". Would you mind sending me the files via email (info@wokke.de). I'm more than keen to check my M70 using them.
    Thanks a million.
    Cheers
    Wolf
    Jun 2012
    Upper Silesia
    Try download it once again(I think it get currupted when you downloading), I've just checked archive without any problem.
    did it already. Maybe Windows Vista related? I tried WinRAR as well as WinZIP
    Jun 2012
    Upper Silesia
    Check your mail box
    Check your mail box
    nothing in there from you. Typo when sending?
    Jun 2012
    Uk
    1994 850csi rhd
    Quote Originally Posted by wokke View Post
    It worked fine in Windows 7 32 bit. I had loads of problems with Vista and ended up installing 7 instead.
    Jun 2012
    Uk
    1994 850csi rhd
    greetings
    worked a treat!
    Apr 2009
    Vancouver Isl, BC, Canada
    09 335, 98 Evo M3, 01 M3
    works great! Thanks! much quicker for basic code checking then booting DIS every time.
    Current:
    - 09 335i, JB4 G5 ISO, AFE Downpipes, AFE Stage 2 Intake, MHD BEF, Dinan Exhaust
    - 98 Euro M3, Estoril Blue
    - 01 M3, Pheonix Yellow, 6 speed coupe
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, 6pd Manual Conversion
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i
    The OC, CA
    95 840Ci, 00 740i Sport
    Where can we get the serial cable needed?
    Apr 2009
    Quote Originally Posted by IJustDrive View Post
    i got this one. works perfectly
    http://forums.bimmerforums.com/forum...highlight=gert
    Current:
