what splitter is that?
Who did the roll bar for you if you don't mind me asking? looks great!
Mind if I ask where you got that sunroof delete panel? Thanks!
Great looking car
Well done
It weighed 2880lbs right after filling the tank. Track weight should be just under 2800.
Awesome, build. Can I ask what material your door cards are made of?
Oil filter housing is leaking oil, so I have to replace the gasket in order to pass tech. I also have a few bushings that are worn out, so I figure that it is time to replace those too. They also had a set of ground control camber arms that are being tossed on.
You may be able to notice some of the oil that has been leaking in this picture.
One of many worn out bushings
Ground control rear camber arms
Delrin bushing
Do you still have A/C and the heater core installed? Weight seems heavier than I thought but I can't remember how low in weight these cars can get. Still a good loss in weight.
Yes, I do; I am thinking about taking it out. I have since taken about 20lbs out of the car. There is a lot of weight to be removed from under the car though, I think I can get another 20lbs out from under there.
nice and clean
LTW risers getting shaped up before the paint goes on.
nice job..
19 - BMW's: Past / Present
1979-E21 Euro Red/Black-RIP. Where it all began!!
1986-325es/345 Bronze/Tan -SOLD
1992-325IS Silver/Dove-SOLD
1993-325IS-Brilliantrot(Custom)/Tan-SOLD -
2005-E46 M3 ZCP ILB / Grey - SOLD
1999-M3-Alpine/Black - SOLD
1995-M3 Alpine/Dove - SOLD
1997-M3/4/5 Black/Black - SOLD
1994-M-Design/M-Technic - Project car-sold
1995-M3-Avus -track car build
2003 ZHP Mystic Blue/Carmel - SOLD I'm not sure why
2011 M3/4/7 ZCP Lemans / Black /Slicktop - SOLD
1999 M3 Fern GTS-3 Race Car/Track car - SOLD
2003 M3 Stahlgrau/Schwarz - Track Car - SOLD
2001 Euro Imported Slicktop MtechII Touring - S54 6sp
2005 M3 TiSilver/Schwarz - sold
2004 330i 6sp Grey/Black - sold
2003 M3-Sedan Hellrot wGrey/Black Indv Int - DD
2001 M3 Wagon Orient Blue/Red Fox - FOR SALE
looking good man.
-Justin-
~94 BMW 325IS~
~03 Chevy 2500hd~
I'm surprised to see no X brace, any reason you aren't running one? I would suspect you are getting some significant flex with the coils and sticky tires.
You are doing well.
― George Orwell
Thanks for the info. Keep up the good work.
"Now all glory to God, who is able, through his mighty power at work within us, to accomplish infinitely more than we might ask or think."
Thanks! I've probably removed another 20-30lbs since I weighed the car. The weight should be around 2780lbs + driver when I track it since I will be on a 1/2 tank. I plan on doing a single 3" exhaust sometime around December.
I can't wait to see how it looks with the risers on! If you have any questions when you start your build, let me know.
Looks good! Install a X-brace it makes a huge difference on these cars and saves your oil pan from death.
1996 328i (m52B28US) OBD1 euro ZF 5spd. 3.23LSD conversion / Chem. PnP Head/ DINAN stg.2 CHIP/ VAC race valves/ S52 cams/ A/C delete/ fan delete/ Washer Fluid resv delete/ ARP head studs/ Cometic 140MLS / VAC Solid Engine/trans Mounts/ CAI / 2.5"Borla race exahaust/ NGK R spark plugs, M50 Mani, S50 Oil Res, Riot Racing HFTB, SAMCO Hoses, JBR FW, X-Brace, Mtech Front Bumper, RE RSMs, stoptech SS lines, Bilstein sports, H&R Race Springs, S52 Reinforcement plates, Kosei K1 w/ bridgestone RE960as, Brembo/stoptech slotted rotors, M3 Trailing arms, M3 Calipers, M3 Axles, ACS strut brace, weight reduction.
http://mbuild.blogspot.com/
Looks tough... nice one.
Update from the shop
This picture displays the bolt that had originally given me so much trouble. The tech that initially aligned the car described it as "frozen." This troublesome bolt prevented the car from staying aligned, according to the tech. I can't wait to see how the car performs now that I will have a proper alignment!
