I am not 100% sure on offerings with that specific backing plate, DTC-60's would likely work better, just trying to prepare you because I have seen multiple DE cars that require more than the HT10's can provide, if you are at the pointy end of your DE counterparts, you will probably be looking for new pads soon. Consider pad changes, street and track in lieu of a "compromise pad." Good Luck, Nate.
I actually have the stoptech front's that came with the kit, so I could just run those on the street. Maybe you are correct about swapping, I'm going to look into that tonight. Thanks!
If that is what he wanted to know, the answer is because that would be very difficult and costly. I feel that I have all the power that I need for now.
Found some time to do a little work on the car last night and got the fronts done. I still need to do the rear pads next weekend. Very impressed with the quality of these brakes.
The bridge slides right out upon removal of two bolts. This will make it much easier to change out pads when the need arises, and because of that, I decided to put the stoptech street pads in. I will just throw in the HT-10's when I'm about to head to the track.
Stock vs. Stoptech
Passenger side complete.
New stainless steel lines.
Stock drivers side rotor and caliper.
I had to grind the spindle down a bit on the drivers side, but not on the passenger side.
The pads just slide right in.
Bleeding the brakes
Finally done
awesome!
I have the PowerSlot discs and ST pads on my E36, and I've been nothing but happy with them. I plan on doing this to mine in the future, and I'm glad it's not that difficult of a job. Looks great!
Looks good! Brake upgrade is a must
1996 328i (m52B28US) OBD1 euro ZF 5spd. 3.23LSD conversion / Chem. PnP Head/ DINAN stg.2 CHIP/ VAC race valves/ S52 cams/ A/C delete/ fan delete/ Washer Fluid resv delete/ ARP head studs/ Cometic 140MLS / VAC Solid Engine/trans Mounts/ CAI / 2.5"Borla race exahaust/ NGK R spark plugs, M50 Mani, S50 Oil Res, Riot Racing HFTB, SAMCO Hoses, JBR FW, X-Brace, Mtech Front Bumper, RE RSMs, stoptech SS lines, Bilstein sports, H&R Race Springs, S52 Reinforcement plates, Kosei K1 w/ bridgestone RE960as, Brembo/stoptech slotted rotors, M3 Trailing arms, M3 Calipers, M3 Axles, ACS strut brace, weight reduction.
http://mbuild.blogspot.com/
Great build. Enjoyed reading it so much that you got my first ever post!
You need to get a set of ITB's like we have over here in the UK on our E36 M3's :-)
The brakes are finished. Really loving how easy the pads are to swap in and out of the stoptech caliper. I currently have the stoptech street pads in the front and HT-10s in the rear, but I will swap the front HT-10s in before I head to the track. While installing the rear pads, I noticed a hairline crack in the rotor, so I'm probably just going to upgrade the rear too.
Beau.Ti.Ful.
Hello awesome build thread.
I was wondering what size tubing and wall thickness was used on the roll bar.
Awesome build! Want to build an e36m3 for HPDE and such in the future. Your build will probably be the basis for mine if I ever do get one.
Went to the shop today to do a little work on the car. Had the ignition coils replaced, swapped out the expansion tank, and installed the Hardmotorsport coolant blockoff plate. I am now waiting on the bimmerworld strapless clutch, bimmerworld race shifter, bimmerworld solid engine/trans mounts, gold heat wrap to line the exhaust/transmission tunnel, and still trying to decide which brand gauges to get.
At the shop
Blockoff plate
The guys helping me out
New decals
Got the carbon fiber PTG wing, reflective heat wrap, and bimmerworld solid mounts in.
I also Bimmerworld strapless clutch on the way. These will be the last parts I order for a while, as I'm going to try to put all the money going forward into track time (at least for the summer). The race shifter, heat wrap, and solid mounts will go in when I do the clutch.
Between this and instagram and facebook we have way too many conversations going on, but where did you get the wing from?
Nice build! Like the new cf ptg wing?
That front lip is sexy
great build, I will be def using ur build for guidance as I wanna to start HPDE, My DD GTI is not cutting it and have been searching for 2nd car (e36 m3). Will be def pulling the trigger when things are in order
