I don't recall saying any such thing. I haven't had to order rubbers, I've only replaced the metal band part of the strap. My post was meant to comment on the function of the rubber part of the strap being the same function as the rubber pads on the top of the tank.
Go ahead and bite. Plenty for everyone.
Anyone know which of the 3 part numbers listed in the diagram I need for these straps? Thanks.
The funniest part? You're stressing the hardest over the dumbest thing. The difference between the two is 70mm. They're the same price. Order the long one and trim it to the length you need.
Reviving an old PSA here... While chasing down a fuel tank leak (boo!!!), I loosened up a tank strap, and while snugging it back up it snapped (double boo!!!) The offending strap is on the driver side. The passenger side strap looks pretty new (as does my donor car passenger side strap).
My question is: what the heck happened to the price of these straps? Based on searching old posts it looks like a few years ago these straps could be had for about $20. A quick search for PN: 16111179160 shows prices in the $80-120 range... pricey, and with no aftermarket alternatives. Triple BOO!!!
Rick
1993 325is - The New Daily?
1998 323is - The Daily Beater
1995 530i - The Alternate Beater
1995 540i/6 Touring - Lord Borthwick
1995 540i - The Donor & Parts Locker - Finally sent to the Crusher - RIP
yeah, i posted about this couple weeks ago. It is crazy how people bought them for around $30 few years ago and now each costs $ 80-120 as you have mentioned. I looked around but couldn't find anything. I guess you can buy a strip of metal and bend it yourself. I didnt have the ability to do that nor the time so I had to buy a replacement (just one). Now I need to go ahead and get the other one since it is fairly rusted and bent.
Rick
Yea, I am ordering the other side today too. I went ahead and got new bolts with it as well.
$85 later, I received and installed the new driver side tank strap. I reused the rubber piece that attaches to it, but first a coated the side that is against the strap with black roofing silicone to prevent moisture from getting under there ever again. In this pic you can see I have also removed the passenger side strap to prep it for re-installation and to address the leak (passenger side front seam; upper left seam in pic).
Here is a close up of the where the leak was coming from. As you can see it is on the seam. There is a plastic "edge protector" that mounts in that location; it looks like that edge protector held in moisture and rubbed those spots in the seam. Also, FWIW, on the bracket above the tank you can see the rectangular hole where the tank strap hooks in and the two studs where a heat shield mounts.
I cleaned, wire brushed, and sanded the spot, used some JBWeld, then sanded again and painted the area. I will take a few pics tonight when I reassemble.
Rick
Got any pics of the the new strap? They can't be hard to fabricate, even with just a pair of pliers and some patience. I replaced one before and remember thinking that there is really nothing to these straps and that they were overpriced at $30. I need to do one on my sedan and would like to take a stab at making my own.
--EDIT--
Maybe I should finish my coffee and fire up the Google before asking for pics:
Rick
I'll probably throw money at it when it comes time for the touring. Right now, this DD sedan I've been working on has been a bit of a practice/experiment/letseewhatwecangetawaywith kind of thing for future work on the touring. When I get to working on it, I'll update this thread with my attempt at making a strap, good or bad.
Funny; my 530 sedan has been the same thing to me. I have learned so much working on that pig... Anyway here is my patch job. It's not so pretty but it looks like it may actually hold up well:
In the center of this picture is the plastic edge protector I alluded to in a previous post:
Here is the edge protector in place:
Rick
LOL, I didn't realize the two were related.
Let's see, a gallon of gas weighs in at about 6.3 lbs. Tank holds about 17 gals so it comes out to 107 lbs. I guess each strap needs to support about 60 lbs. Easy peasy to fab.
demet
Does anyone know where to buy the e34 fuel tank straps? One of mine failed after I filled the tank up last weekend. It seems that the straps used to only cost about $10 but now the only ones I can find online are over $100! That seems steep for a couple strips of sheet metal.
I got mine for around 15-20 each a couple years ago, but it seems to be a classic case of supply and demand. Gotta pay to play these days. Its an OEM only piece, and mark up tends to be similar at most online retailers, so i doubt there is a far cheaper option that the prices youve seen.
-Alex
They can certainly be fabbed. Its the "hook" end nearest the diff that would be the most difficult to replicate, but if youre fancy with a welder, i cant see why one wouldnt be able to reuse that end, or both ends, and just replace the "middle" of it.
Found a brand new pair of them in the trunk of an e34 at the junkyard a year and change ago. Told the guy exactly what they were and he took 10 bucks for them. Gave them to a friend of mine.
-Alex
Measure them and search for universal straps. I don't know the measurements but a quick search yielded some 42 inch long ones in mild steel or stainless for about $15 each.
I ordered a new fuel tank strap for the driver side of my car, as mine broke last weekend. It should get delivered on Saturday. If anyone would like me to take more detailed photos of the part or mesurements before I install it then let me know. It seems like a very simple part.
Yes, please do!
I got the new part today for the driver's side strap for the fuel tank.
Here are some up close photos:
Hope the photos are helpful. Now I need to try to find the strap for the passenger side of the tank as well. It was just the driver's side strap that broke, but I am assuming the other one is in rough shape too.
