Results 1 to 16 of 16
Thread: Registry Error? INPA
    Aug 2002
    San Jose, CA
    E36/E46 M3 - E46 323ci
    When I start
    I get this error:
    Registry Value failed in SubKey :
    'HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services/Serial'
    May be there are problems!
    How do I fix this?
    Apr 2008
    Brooklyn, New York
    BMW
    YOu need to goto Ediabas/hardware/obdsetup And run the program. That will get the registry set but if it still shows warnings or missing variables, you need to actually goto into the registry and change or add some variables to it...
    To go into registry you goto the start menu and under search programs type REGEDIT....Then goto 'HKEY_LOCAL_MACHINE/CurrentControlSet/Services/Serial'
    There you will find all the values from the OBDsetup. Make changes to it accordingly to make all the values say "OK"
    Aug 2002
    San Jose, CA
    Quote Originally Posted by cn555ic View Post
    I was able to change the Value Start to 1 but there are still several items that "failed". How do I fix that?
    Windows 2000 Version 6.0 Build 6002
    Installing OBD driver...
    SubKey 'SYSTEM\CurrentControlSet\Services\Serial' allready exist !
    Reading values of the key ...
    Value Type = 1 Expected = 1 Ok
    Value Start = 1 Expected = 1 Ok
    Value Group = Extended base Expected = Extended base Ok
    Value ErrorControl = 0 Expected = 0 Ok
    Read value 'Tag' failed !
    Read value 'ForceFifoEnable' failed !
    Read value 'RxFIFO' failed !
    Read value 'TxFIFO' failed !
    Read value 'PermitShare' failed !
    Read value 'LogFifo' failed !
    All done.
    Press any key to continue ...
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    Don't worry about the script content unless it prevents the program from running.
    Apr 2008
    Brooklyn, New York
    BMW
    Quote Originally Posted by JetBlackE46 View Post
    All done.
    If those are your values there will be no connection and it would definitely not work...Here is a picture of the correct values...Go into the registry like I posted earlier and make the correct changes to them..Once you get to the serial registry you need to look at the values I posted on the pic and make the changes to it...If you have to add a value use the top right and press edit and make changes.
    Aug 2002
    San Jose, CA
    It worked, thanks!
    Apr 2008
    Brooklyn, New York
    BMW
    Glad u got it working!
    Jun 2013
    Los Angeles
    530i
    Thank you this was very helpful.
    Feb 2013
    Korea
    '07 320i E90
    Recently I had gotten the same error message in INPA, but had no problems checking for errors on my car. I looked in the registry and could not find
    I just checked and realized that I had left EDIABAS 6.4.7 in the C: drive after using DIS, then forgot to switch EDIABAS to 7.3.0 for my INPA(version 5.0.6). I just switched over to EDIABAS 7.3.0 and upon opening INPA(version 5.0.6), the error did not appear.
    Just my 2 cents.
    Feb 2012
    Ukraine, Lviv
    2001 BMW 540iA M Technic
    Thank you, it works !
    Jun 2019
    Charleston, SC
    2012 BMW x5 xDrive 35i
    INPA Installation Error
    All done.
    I'm getting the same error. I'm running windows 10 on my computer. Can anyone help me with the installation? I will really appreciate the help. I bought the CD online and I don't know if INPA 5.01 is compatible with windows 10. Thanks for your help.
    Nov 2019
    Toronto
    X5
    Nov 2019
    Tilburg, The Nederland
    e60 530i 2006 MysticBlue
    Quote Originally Posted by x5xDrive35i View Post
    Hi,
    You pay for INPA?? Whaaat... somebody f**ck you up. And to reply for your question, for sure INPA 5.06F will run smootly on Win10.
    Remove all those shit what you have, clean registry, download whole package from here, install and enjoy:
    https://mega.nz/#F!zw5V0IrD!08GgdgH0AtxZcWh62_76xA
    In case you can always pm me, or I can help you via Team Viewer.
    If my answers help you to FIX your problems with car, you can always donate me using PayPal :
    https://www.paypal.com/cgi-bin/websc...MNN&source=url
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by wjgud123 View Post
    Hi,
    My virusscanner wasn't happy with some "Dr gini.exe" file inside this archive. Also never heard of anything Gini inside a BMW Tool setup.
    IG:
    The Netherlands
    I have to ask, but does the reg entry of "Serial" (HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services/Serial) interfere with any ADS setup?
    Or is this strictly for the "USB Serial Port" devices?
    I have an USB OBD setup on COM3 (and set as such in OBD.ini) and an ADS setup on COM1/IRQ4/03F8.
    Changing anything in any of the port settings (send/receive buffers) does not seem to change the reg settings. Kind of confusing what interface links to what reg entry.
    IG:
    Oct 2021
    Dalfsen
    2001 BMW 320 coupe
    i have the same problem but i can not go to HKEY_LOCAL_MACHINE/CurrentControlSet
