Page 2 of 10 FirstFirst 12345678910 LastLast
Results 26 to 50 of 226
Thread: rebuilt injectors blowout prices 19-20-22-24-30-34#s
  1. #26
    bavaria tx
    91 e30-07 350Z -E63 AMG
    all pms replied --- all orders filled.
  2. #27
    bavaria tx
    replied to even more pms that came in
  3. #28
    bavaria tx
    everything is in stock ready to ship ... ALL units are Bosch Design III .... I dont bother with bosch design I or II. Get the best at the best prices around!!!!!!!!
  4. #29
    May 2012
    Louisville,KY
    97 328i
    Have any pinks for a 97 328i in stock?
  5. #30
    Sep 2008
    Houston
    1998 M3, 1996 240sx
    I will take a set of pinks if you have them in stock.
    98 M3/4 Cosmos
    96 240sx - snail powered
  6. #31
    bavaria tx
    pinks are now sold out. Thanks to the guy that bought 3 sets .
    Plenty of everything else. I should have more pinks by Monday though.
  7. #32
    Miami, Florida, USA
    '94 325i '04 Cooper S
    Hey, are the pinks good for a 325 with just pulleys and intake- maybe exaust?
    Sent from my SAMSUNG- Infuse using BF.com
  8. #33
    Oct 2008
    PDX & Hermiston, Oregon
    98/M3/4, 05 M3 Vert
    So these go through exactly what the witchhunter.com guy does?
  9. #34
    bavaria tx
    Quote Originally Posted by SmokedBMW23 View Post
    yes its standard method to rebuild/clean. However I dont bother with design 1 or 2 injectors.
    tell me what you are in need of sir.
  10. #35
    bavaria tx
    slow past few days. all items are priced in sets of 6 but I have available in 4,6,8,12 etc........
    lets see what we can do for you.
  11. #36
    Oct 2008
    98/M3/4, 05 M3 Vert
    Quote Originally Posted by e30ultimate View Post
    What do you mean by design 1 or 2 injectors? Pardon my ignorance. I'd be interested in Pinks for my s52
  12. #37
    bavaria tx
    Well Design I injectors were introduced in the mid 70s and design didnt change till about early 1990.They were basicly all metal with plastics tops and a single pintle.Most bmws that were non dohc came with these until the design II
    Design 2 and 3 changed to a four nozzle design that atomized the fuel instead of simply squirting it in.Both are plug and play.Both designs are 4 nozzle but design III are one piece all plastic housing manufactured to within 1% of specs vs design II half metal/halfplastic housing manufactured within 2% of specs. basically design III are same flow just longer lasting tighter specd injectors.Also set of 6 is a full 1/2 lb lighter then set of design II. So you also get weight savings! fur raze car!
    I dont bother with design 1s because the cores are likely almost 30 yrs OLD! Design 2s probably no newer than 15 yr old cores......... so I only design 3........ newer more reliable design and takes the same amount of work as the others to rebuild.
  13. #38
    Jan 2012
    sf bay area, ca
    95 Cosmos M3
    pm sent!
  14. #39
    bavaria tx
    commonly asked Question 1--- why are there different flow rates for the sme injector.
    Answer ---- most injectors are referred to their flow at a common bar (psi) such as 3 bar(43.5psi) but they are capable fo flowing more or less by simply changing the bar(psi). or in most cases not all cars used a 3.0 bar fuel pressure regulator they varied from 2.5-4 but can be tuned up to 10 bar with a adjustable fuel pressure regulator. so to let the buyer knwo what to expect on their car I list the different flows for the SAME injector using higher/lower pressure.
    Question 2 --- whats the difference for bosch design 1 vs 2 vs 3.
    Answer ---- Well Design I injectors were introduced in the mid 70s and design didnt change till about early 1990.They were basicly all metal with plastics tops and a single pintle.Most engines that were non dohc came with these until the design II.
    Design 2 and 3 changed to a four nozzle design that atomized the fuel instead of simply squirting it in.Both are plug and play.Both designs are 4 nozzle but design III are one piece all plastic manufactured to within 1% of specs vs design II half metal/halfplastic housing manufactured within 2% of specs. basically design III are same flow just longer lasting tighter specd injectors.Also set of 6 is a full 1/2 lb lighter then set of design II. So you also getfur raze car!
    I dont bother with design 1s because the cores are likely almost 30 yrs OLD! Design 2s probably no newer than 15 yr old cores......... so I only design 3........ newer more design and takes the same amount of work as the others to rebuild.
  15. #40
    bavaria tx
    Fathers day weekend bump!!! Tell the wifey/GF/mother/sancha that you need these. Ill give you my best price if paid this weekend.
  16. #41
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    Are these oem injectors?
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
  17. #42
    bavaria tx
    Quote Originally Posted by CMG View Post
    these are bosch design III found on numerous marquees that are an upgrade for the bavarians.No physicaly modifications needed for these to work ---flows listed for various bars.
  18. #43
    SD, Cali, USA
    Are the pinks 21.5 sold out still? That's what i need.
    95 BMW M3 Alpine-
  19. #44
    bavaria tx
    All PMS replied . Lots of sales made today...dont miss out on yours!!
  20. #45
    bavaria tx
  21. #46
    Savannah, GA
    1987 325is/s52 swap
    I just sent a PM regarding pink top's. Still have any?
  22. #47
    bavaria tx
  23. #48
    NY/FL
    '08 G35S, '98 M3/4/5
    Bump for a good seller! Top notch!
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  24. #49
    bavaria tx
    Quote Originally Posted by Da Infammus 1 View Post
    Thank you good sir! another happy customer........ its your turn folks!!! get your order in!
  25. #50
    Mar 2002
    Raleigh, NC
    so many BMW's
    Just received my 24# blue's. Quick shipping, good communication. I haven't installed them yet, but they look good.
    1995 Alpine III M3 Track Rat
    1989 Alpine II 325iC
    2004 M3 Daily
