I guarantee asgainst DOA and full a full year. They should last a good 6-8 yrs before needing another rebuild.
address is e30ultimate@gmail.com
--please put a memo so i know which ones to ship out as I have several orders coming in.
State: Texas
Will Ship: Continental US Only
Price: 1+
I have many sets available at blowout prices. Prices below are shipped in the USA for a set of 6 injectors. if you need other sizes or quantities please let me know.
Match up the number with pic at bottom for full specs.
Every injectors is:
- -Fully disassembled
- -Cleaned in a chemical bath
-Sonic cleaned
-Impedance Checked
-Cycled with compressed air
-Rebuilt with all new components (filters, Viton orings, spacers, ect)
#1 Yellow Tops -- 19# 55 shipped
Flow Rates (Aprox.):
- 3.00 Bar/ 43.5 PSI --- 19.40 lbs/HR --- 205cc/min
- 3.50 Bar/ 50.7 PSI --- 20.94 lbs/HR --- 220cc/min
- 4.00 Bar/ 58.0 PSI --- 22.40 lbs/HR --- 235cc/min
- 2.50 Bar/ 36.3 PSI --- 17.72 lbs/HR --- 186cc/min
#2 Dark Blue Tops -- 19s+# 60 shipped
- 3.00 Bar/ 43.5 PSI --- 19.81 lbs/HR --- 208cc/min
- 3.50 Bar/ 50.7 PSI --- 21.43 lbs/HR --- 225cc/min
- 4.00 Bar/ 58.0 PSI --- 22.86 lbs/HR --- 240cc/min
- 2.50 Bar/ 36.3 PSI --- 18.10 lbs/HR --- 190cc/min
#3 Pink Tops -- 22lbs $68 shipped
- 3.00 Bar/ 43.5 PSI --- 22.50 lbs/HR --- 236cc/min
- 3.50 Bar/ 50.7 PSI --- 24.30 lbs/HR --- 255cc/min
- 4.00 Bar/ 58.0 PSI --- 25.98 lbs/HR --- 315cc/min
- 2.50 Bar/ 36.3 PSI --- 20.55 lbs/HR --- 216cc/min
#4 BLUE Tops 24lbs -- $70 shipped
- 3.00 Bar/ 43.5 PSI --- 24.00 lbs/HR --- 252cc/min
- 3.50 Bar/ 50.7 PSI --- 25.90 lbs/HR --- 272cc/min
- 4.00 Bar/ 58.0 PSI --- 27.70 lbs/HR --- 290cc/min
- 2.50 Bar/ 36.3 PSI --- 21.92 lbs/HR --- 230cc/min
#5 Red Tops 32lbs --- $85 shipped
- 3.00 Bar/ 43.5 PSI --- 32.00 lbs/HR --- 330cc/min
- 3.50 Bar/ 50.7 PSI --- 33.93 lbs/HR --- 356cc/min
- 4.00 Bar/ 58.0 PSI --- 36.29 lbs/HR --- 381cc/min
- 2.50 Bar/ 36.3 PSI --- 28.72 lbs/HR --- 301cc/min
#6 White Tops 34slbs --- $95 shipped
- 3.00 Bar/ 43.5 PSI --- 33.34 lbs/HR --- 350cc/min
- 3.50 Bar/ 50.7 PSI --- 36.00 lbs/HR --- 378cc/min
- 4.00 Bar/ 58.0 PSI --- 38.48 lbs/HR --- 404cc/min
- 2.50 Bar/ 36.3 PSI --- 30.45 lbs/HR --- 320cc/min
Click on picture for larger image
commonly asked Question 1--- why are there different flow rates for the sme injector.
Answer ---- most injectors are referred to their flow at a common bar (psi) such as 3 bar(43.5psi) but they are capable fo flowing more or less by simply changing the bar(psi). or in most cases not all cars used a 3.0 bar fuel pressure regulator they varied from 2.5-4 but can be tuned up to 10 bar with a adjustable fuel pressure regulator. so to let the buyer knwo what to expect on their car I list the different flows for the SAME injector using higher/lower pressure.
Question 2 --- whats the difference for bosch design 1 vs 2 vs 3.
Answer ---- Well Design I injectors were introduced in the mid 70s and design didnt change till about early 1990.They were basicly all metal with plastics tops and a single pintle.Most engines that were non dohc came with these until the design II.
Design 2 and 3 changed to a four nozzle design that atomized the fuel instead of simply squirting it in.Both are plug and play.Both designs are 4 nozzle but design III are one piece all plastic manufactured to within 1% of specs vs design II half metal/halfplastic housing manufactured within 2% of specs. basically design III are same flow just longer lasting tighter specd injectors.Also set of 6 is a full 1/2 lb lighter then set of design II. So you also getfur raze car!
I dont bother with design 1s because the cores are likely almost 30 yrs OLD! Design 2s probably no newer than 15 yr old cores......... so I only design 3........ newer more design and takes the same amount of work as the others to rebuild.
