Results 1 to 25 of 62
Thread: Changed my rear shock mounts today - here is some pics
    Oct 2003
    South Africa - Pretoria/Randburg
    2004 Mini Cooper
    Amazing how such a smal thing can make a change, I took the car for a ride after I was done, and the car definatly felt more...."solid on the road", pretty glad I installed new RSM's
    Still have a sqeeking sound in the back thought...think it might be a worn shock.
    First things first, jack the car up and take the rear wheel's off and make sure the car is SECURE, you are going to stick your head into the wheel well, you don't want the car to come crashing down on you.
    Standard disclaimer applies, if you break soething or hurt yourself, it's your fault, not mine
    1/14 Pull out boot carpet
    Oct 2003
    2004 Mini Cooper
    2/14 - Unscrew and unclip piece of plastic
    Oct 2003
    2004 Mini Cooper
    3/14 - Pull out side carpet, give it a slight yank to get it out.
    Oct 2003
    2004 Mini Cooper
    4/14 - Side carpet off revealing a 2nd carpet, looks like a sound damping carpet to me.
    Oct 2003
    2004 Mini Cooper
    5/14 - Remove sound dampening carpet to reveal shock mount. Notice new shock mount next to it.
    Oct 2003
    2004 Mini Cooper
    6/14 - un-screw the two bolts holding the shock mount to the shock tower ("strut tower")
    Oct 2003
    2004 Mini Cooper
    7/14 - Shock is loose
    Oct 2003
    2004 Mini Cooper
    8/14 - To remove shock completly the bolt at the bottom of the shock needs to be removed. Quite hard to get loose
    Oct 2003
    2004 Mini Cooper
    9/14 - Shock finally completly out
    Oct 2003
    2004 Mini Cooper
    10/14 - Shock free wheel well
    Oct 2003
    2004 Mini Cooper
    11/14 - Clamp onto the top of the pin sticking out and undo the bolt holding the shock mount on the shock.
    Oct 2003
    2004 Mini Cooper
    12/14 - shock mount off lying next to the soon to be fitted new shock mount
    Oct 2003
    2004 Mini Cooper
    13/14 - Clean the shock while it's out:
    Oct 2003
    2004 Mini Cooper
    14/14 - re-install shock with new shock mount.
    Now just do the same for the other side.
    Oct 2002
    Buenos Aires, Argentina
    5/94 Euro 325i coupe
    Great job!!! :
    How much did you spend on the parts?
    Quote Originally Posted by ClintonM3 View Post
    the Audi A4 is a tweaked, cosmetically enhanced, cross platform, put-together overnight VW.
    Quote Originally Posted by joeuser528e View Post
    Staggard setups are for cars that you park at show meets. They go well with 5 screens and 3 12"s.
    Oct 2003
    2004 Mini Cooper
    Originally posted by Daved
    Great job!!! :
    R76 south african rands. It was R38 for one shock mount.
    It's roughly about $10 us dollars
    Jan 2003
    vancouver
    E36 Bmw
    nice write up..
    guess its bout time i did this too..
    -nathan
    Mar 2002
    Des Moines, Iowa
    current: e30 325i 1989,
    good write-up
    "Our national leaders are sending U.S. soldiers on a task that is from God."-Wacky Gov of AK
    With President Obama: $13,368,918,981,408.64
    With President Bush II: $9,688,683,116,728.96
    With President Clinton: $5,676,989,904,887.12
    With President Bush I: $4,643,382,826,714.94
    Feb 2004
    VA
    Integra & Swapped Honda
    haha rands
    good job
    Sep 2003
    Newport News, VA. (JMU for school)
    94 318i
    is that an oriental rug that you do your car work over? heh
    if there is a sqeaking sounds when i step out of the car, does that mean the rsm should be replaced, or is that somthing else?
    Nov 2002
    So.California
    1995 M3
    IN the 9th pic it looks as if the car is resting with the suspension/rotors on the carpet.
    What are you using for support?
    Walk a mile in my shoes and you are a mile away in someone else's shoes.
    Goodridge*UUC sways* Black TME's and mounts( switched from Red)* x-brace*brembo rotors*Zimmerman rear*Pagid*Kumho Ecsta SPT's* Roja Formula 7's (Bronze)* Stromung*Powdercoated AA DSB* OMP strut bar*GC RSM's* M3 alum/leather knob*JTD underpanel *Traffic PRO (sold) *Black hella Ellipsoids w/celis rings * ACS Pedals*ACS handbrake*RE Octane SSK*Wheelskins Eurotones S/ Wheel Cover( tossed-replaced with new one)* Totally Covers Front seat velour covers with custom styling *Rieger roof spoiler-lost it on fwy Stock A/B*URI CP (ditched years ago)*540 HFM (sold) Stock HFM (BeckArnley)*FMS 24 lb inj*Alum rad and some other stuff*Konis w/adj rr's*Vogtland springs ** Passport 8500(sold)*Passpprt 7500 (sold V1-1.8 with POP) No detectors at all.
    Coming...nada
    BMWCCA-303681
    Nov 2002
    Fort Wort, TX
    '96 318ti, '15 Focus ST
    good job man. im doing mine this weekend putting in new springs while im at it.
    BMWMOFO C6MPACT
    Socal
    Mmm
    I changed mine without taking the shock off. And also without taking off the bottom carpet or 2nd sound deadening.
    As for teh squeeking when stepping out of your car - thats your ebrake most likely. Rear shock mounts make this jiggling rattling sound when the shocks are loaded (ie driving over bumps, taking corners, etc).
    Apr 2003
    Fair Oaks, CA
    2003 M3 Coupe 6MT
    no Z3 reinforcement plates? should of put those in ...
    Oct 2003
    2004 Mini Cooper
    I have two pyramid jacks, one at each side under car.
