Results 1 to 25 of 59
Thread: Bosch plugs
    May 2010
    CALGARY,ALBERTA,CANADA
    1990 BMW 850I V12 5.0
    Bosch plugs
    WHICH IS THE BEST TO YOU ON THE E31 M70
    *Bosch Super Plus Spark Plug - FR8LC+
    *Bosch Platinum+4 Spark Plug -FGR8DQP
    *Iridium OE Finewire - FR8LII33X
    I HAVE THE Bosch Platinum+4 Spark Plug/FGR8DQP IN MY CAR NOW I WANT TO BUY NEW ONES AND WONDERING IF THE Iridium OE Finewire/FR8LII33X ARE THE BETTER PLUGS TO BUY THANK YOU
    Dec 2007
    orange, ca
    '91 e31
    none of the above-
    plain-jane copper core plugs (LOTS of discussion on this here btw...)
    May 2010
    Bosch Super Plus Spark Plug - FR8LC+ ARE THE COPPER CORE OEM
    AND THE Iridium OE Finewire - FR8LII33X HAS COPPER CORE ALSO SO WHY YOU SAY THESE ARE NOT GOOD AND WHAT ARE THE plain-jane copper core plugs
    Toronto
    330i ZHP, 850i, 92 318iC
    F8LCR is the plug you want stick with the copper core like was mentioned prior
    Greater Seattle Area
    '93 850Ci,'01 X5
    Search is your friend, I bought the NGK 7558, lots of discussion on this topic as rockytt suggested.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Quote Originally Posted by RAFFEAL View Post
    upgrade your coils and you might be able to get away with using any of those, don't upgrade coils and you'll find out why everybody is telling you those are all wrong.
    NONE of those are the same plug as the original F8LCR plugs. Resistance matters... I know, it *shouldn't* but it DOES.
    Northern WA USA
    91 850i +++
    And, just to beat a dead horse, neither are the NGKs 8^)
    How come the middle half of any project always takes the most time?
    '93 850Ci,'01 X5
    Quote Originally Posted by Max Lumens View Post
    Dammit! I guess I should've searched deeper.
    Jul 2011
    Finland
    2010 325i e93
    NKG BKR6EK and/or BK6EQUP will work.
    Resistance is 1k ohm.
    Regina SK. Canada
    1991 850i / 6
    RAFFEAL , have a talk with Max Lumens about upgrading to 40k volt coils , and
    maybe upgrading your ignition wires to Magnecore . Then you should be able to use platinum or iridium plugs .
    Jan 2012
    Baltimore, Md
    95 240SX SE, 95 E31 840
    ngk plugs are awesome.
    would run them any day over any bosch crap currently available.
    columbus, ohio
    E31, E65, F01
    Quote Originally Posted by JTM850 View Post
    yep!
    Northern WA USA
    91 850i +++
    Great info, thanks. Been looking for 1Kohm plugs for a while. Did you test them to see if they were within spec?
    Those are some funny-sounding plugs. Double and quadruple electrodes?
    http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
    Jul 2011
    Finland
    2010 325i e93
    I have heard that these NGK plugs are recommended also by BMW to replace the old F8LCR plugs and they are also the closest matching plugs out there to replace it.
    I installed NKG BKR6EK to my M70 and it runs idle smoothly and goes like a charm
    Aztec,NM,USA
    1996 850ci
    Anyone ever used the Autolite Copper ones from Autozone in an M73?
    http://www.autozone.com/autozone/par...er=117687_0_0_
    1996 BMW 850ci
    2012 Duramax
    1974 Camaro
    Sep 2011
    Los Angeles, CA
    94 840, 68 911, 73 450SL
    Just remember... that although copper core plugs fire better, give you a little smoother idle, and may give you tiny bit more umph, they will not last as long...about 15K. I'm lazy and I don't want to change plugs again so used the oem NGK BKR6BEQUP...and I'm willing to sacrafice that little missing umph.
    Jan 2012
    Baltimore, Md
    do not fit autolite plugs to anything, quite possibly some of the worst plugs i have used in any motor.
    only fit for garbage domestics...use quality plugs in a car you care about.
    May 2010
    OK THANK ALL OF YOU FOR TO HELP OEM BOSCH F8LCR WINS, WHY CAUSE I HEAR SOME OF YOU SAY
    '' NKG BKR6EK and/or BK6EQUP will work.
    Resistance is 1k ohm.''
    ALSO
    ''Just remember... that although copper core plugs fire better, give you a little smoother idle, and may give you tiny bit more umph, they will not last as long...about 15K. I'm lazy and I don't want to change plugs again so used the oem NGK BKR6BEQUP...and I'm willing to sacrafice that little missing umph.
    ONE MORE THING I BUY TWO BOSCH COILS 2011 BUT I HAVE THE Bosch Platinum+4 Spark Plug -FGR8DQP IN MY CAR FROM THEN TOO THIS MEANS WHEN I BUY THE NEW PLUGS I HAVE TO GET TWO NEW COILS ALSO FOR HE SAID
    ''upgrade your coils and you might be able to get away with using any of those, don't upgrade coils and you'll find out why everybody is telling you those are all wrong.
    NONE of those are the same plug as the original F8LCR plugs. Resistance matters... I know, it *shouldn't* but it DOES.''
    Jan 2012
    Baltimore, Md
    bosch platinum +4 plugs are terrible in any car...marketing hype right there.
    just fit fresh factory spec plugs or the ngk equivalent and roll with it.
    Aztec,NM,USA
    1996 850ci
    Quote Originally Posted by BlackBox Tuning View Post
    I guess we have to agree to disagree on this part... I use autolites in my 600hp blown camaro difference of opinion I guess
    1996 BMW 850ci
    2012 Duramax
    1974 Camaro
    Jan 2012
    Baltimore, Md
    lol, they work well in domestics...just not in imports for whatever reason.
    but yes, agree to disagree
    '93 850Ci,'01 X5
    Quote Originally Posted by Talisman850 View Post
    I've used autolites before and they did work out in my "domestic" either. For domestics I'm a Champion man. Euro, NGK's
    Sep 2008
    Santa Barbara
    ALSO
    OK, just so you fully understand...
    Bosch F8LCR plugs were discontinued long ago, what Bosch says is a suitable replacement - is not, as many folks have found out. Some get away with using the higher resistance plugs, most do not - hence the upgraded coil comment. Upgraded coils refer to a higher output coil, NOT the OEM Bosch units... 10Kv vs 40Kv... that makes a difference.
    So, if you want to run the stock ignition system with Bosch coils, great... but use some of the 1k resistance plugs mentioned above (that ARE still available) or, if by some magic you find some real F8LCR's... otherwise, with uprated coils, you can run just about anything you want (meaning, any flavor of plug in the correct range and physical dimensions).
    May 2010
    Brentwood, NY
    BMW 850
    To make sure you are utterly confused, I am running Denso equivalent. I prefer them over the NGK mentioned above. I ran NGK for about 1000 miles then switch. The copper plugs are cheap enough for you to try 2 or 3 brands before making a decision...
    May 2010
    ok thanks i will sreach for those bosch ones
