I have a 95 840. Some of the windows will go up when they are activated to go down. The drivers seat will go forward when it is activated to go backward. Does anybody have any idea why this is happening or could you direct me to a thread that addresses this issue?
Bimmerman44
Start by getting the batteries fully charged - or replaced if they are not holding a charge.
My BMW Repair YouTube Channel
My steering wheel does the same thing- up=down, out= in and vice~versa. New batteries not withstanding.
Regards,
M.R.
2000 740i Sport Anthrazit Metalic M62TU 4.4 V8/M-Pars 214K Miles!;
2011 Cadillac CTS-V Coupe 6A Raven Black/ 6.2L Supercharged/556HP;
'06 Dodge Magnum SRT-8 Inferno Red/ 6.1L Hemi/ Dyno-368HP / 371lb-ft; ;
SOLD'91 850i Calypso Red M70 5.0 V-12;
SOLD'95 540i Schwartz MetalicM60 4.0 V8;
SOLD'85 635CSi Cosmos BlauM30 3.5 I6;
SOLD'97 Lexus SC400 Maroon/4.0L DOHC V-8.;
1970 Torino. 351C-4V/ 3.71Locker/ C6. Yeah, I'm workin' on it...;
91 Honda CR500 (2stroke,liquid cooled MXer)/230lb/60hp/3.8lb per HP./ FMF Gnarly pipe. Top speed 105mph...in the dirt;
1950 International/Farmall Model-M Top Speed-17mph in 5th. It's a tractor, Bish!
Going into year two with this issue...
Same issue on my drivers seat.
I am thinking of switching the wires to fix the issue.
Yes, but are they fully charged? What is the termianl voltage at the moment with the car not running?
I've asked this on multiple occasions in the past but never got a clear answer:
For those with BMW DIS and experiencing the mystery reversed operation on some components... What happens if you monitor the inputs of the faulty module while operating the window switches, steering column adjustment stalk, mirror adjustment switch or seat adjustment switches (depending on fault)? Does DIS show the correct directions? In other words, are the inputs right or wrong?
Secondly, what happens if you activate the component through DIS (sadly not possible for the windows, but the steering column, mirrors and seats can be operated from within DIS)? Is this operation reversed as well for the faulty components? In other words, are the outputs right or wrong?
Did anyone ever find a fix for the seat reversed polarity problem?
Is it happening after the car has been in use for some time or directly after having the batteries disconnected?
It’s happened since I’ve own it. I have changed the batteries, both are brand new.
This is a growing problem with out 80's era electronics, the variant programming within a module is being lost or corrupted - and this can reverse the action of the seat, same on the steering column - it causes battery drain on GM and TRANS FAIL-SAFE on the gearbox EGS!
