Page 6 of 42 FirstFirst 1234567891011121314151631 ... LastLast
Results 126 to 150 of 1034
Thread: Diagnostic program with realtime graph view
  1. #126
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by WayneC View Post
    Ediabas has full trace capability, simply edit the ini file, it is quite well done and very useful, I would expect it to assist in what you are doing
    Yes, the Ediabas has good enough trace capability but it can not associate execution of particular job and job results with the raw output.
    All I need now is trace files from bmw drivers.
    E61 520d LCI
    Check out TestO - free datalogger for BMW. Includes support for: AEM, PLX, 14point7, Innovate (through SDK)
  2. #127
    May 2010
    Sydney,NSW,Australia
    316 Compact
    Appologies if I am incorrect but ediabas can give Device to PC raw data, perhaps I misunderstand what you are referring to as raw output
  3. #128
    Pittsburgh, PA
    E36 M3 / 2.0T WRX
    Quote Originally Posted by pheno View Post
    It would be nice to get traces for MS41 ECU: MS410DS0, MS410DS2, MS410DS3 then all MS41 variants would be supported. Not sure about mrf's MS41.2 though
    Also more traces from S52, S54 like E39 M5 and E46 M3and also M62 engines would be nice. It takes only about a few minutes and won't do any harm to your car.
    I've already solved most important from MS43, MS42 and MS41 (DS1 variant) and some variant of M62 (ME7.2)
    Look at the OUTPUT line: 12 means ecu index in the K-bus, 1D is message length, A0 means "OK". from byte 3 starts data.
    Between <jobstart> and <jobend> is issued one job from EDIABAS. The trace file generation is done by me. EDIABAS does not have this kind of trace file generation.
    We will get one decoded value from EDIABAS (which means in EDIABAS terms 'job result', for example STATUS_MOTORDREHZAHL_WERT) at the end. And we also get the output that contains (somewhere) this value. As I said before value is decoded by taking a byte and multiplying it with value a then summed by value b. You just have to find out what are the values a and b. EDIABAS and .prg files do not tell you all of the details.
    Interesting. Thanks for explaining.
    I really need to get the trace file from my MS41.2. But I really don't want to buy a $100 ADS cable just for this. If this can be done with a cheaper cable I could look into it. Or maybe I can find someone local who has the cable and borrow it.
  4. #129
    Nov 2007
    Finland, Europe
    E61 520d LCI
    WayneC, you're 100% right. Sorry If I mislead you. I just wanted to tell that EDIABAS trace file's "raw output" does not contain decoded values only bytes in hex form which as such won't tell much. Sorry about my english....
    E61 520d LCI
  5. #130
    May 2010
    316 Compact
    No worries, I did not appreciate your utility was doing the decode and you are/were looking to pick up the errors/differences from each ECU type, now I understand it
  6. #131
    Sep 2010
    england
    1998 bmw m3 coupe smg
    hi pheno,
    i have sent you 2 smg trace files today,are they any good? ive got a spare couple of days to spend time on testo so can send more trace files if you want?
    j.
  7. #132
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Updated Testo today with some small corrections to the file logger.
    Jamie: please send some traces from your ECU. Thanks.
    E61 520d LCI
  8. #133
    Sep 2010
    england
    12 files sent
  9. #134
    Phoenix, AZ
    Which day of the week?
    What's the most commonly requested DME for support right now?
  10. #135
    Pittsburgh, PA
    E36 M3 / 2.0T WRX
    MS41.2
    Not that I'm biased or anything...
  11. #136
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by smooth11981 View Post
    Do you mean "faster live data" kind of support ? Well, only a few. I guess most people are not even aware of that. I've been working on ECU datas just on my own and for the fun of it.
    Edit: sorry did not answer your question Right now there seems to be demand for MS42 and M62TU ME7.2
    E61 520d LCI
  12. #137
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Updated Testo. You can now watch a bit faster live data for these ecu: MS41 (DS1), MS42, MS43 and ME7.2
    It reads '(serial)' at the end of these ecu names that support faster live data.
    Check testo.ini and change com port to correct.
    E61 520d LCI
  13. #138
    Pittsburgh, PA
    E36 M3 / 2.0T WRX
    updated testo. You can now watch a bit faster live data for these ecu: Ms41 (ds1), ms42, ms43 and me7.2
    it reads '(serial)' at the end of these ecu names that support faster live data.
    kickass!!!
  14. #139
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by mrf View Post
    kickass!!!
    Hey, you can try MS41 for your car. It should work but values other than RPM most probably won't be correct.
    E61 520d LCI
  15. #140
    Pittsburgh, PA
    E36 M3 / 2.0T WRX
    Will do! I really need to get off my ass and send you the trace files. I have an ADS cable now.
    Wish there were more hours in a day...
  16. #141
    Nov 2007
    Finland, Europe
    E61 520d LCI
    I am going to take a look at S50 next. Jamie, this is for you
    I wonder what method smooth1 has used to figure these oit..
    E61 520d LCI
  17. #142
    Pittsburgh, PA
    E36 M3 / 2.0T WRX
    Pretty sure he's using the same method as you... Run a list of all jobs, then decode the output. His software can poll the ECU the same way through the serial port and each command returns a whole bunch of values that have to be parsed into human readable format.
  18. #143
    Sep 2010
    england
    thanks mate!
  19. #144
    Phoenix, AZ
    You don't need to run a list of jobs, but that'll definitely help you procure info for the different DMEs.
  20. #145
    Nov 2007
    Finland, Europe
    E61 520d LCI
    If you downloaded 21-April version please download newest (22-April) version. Previous had a "small" bug with serial port based ecu's. Gotta love C++ and locales..
    E61 520d LCI
  21. #146
    Denmark
    2012 BMW F31 330d
    Any way you could stuff in some more readouts for my Non-EWS 540i/6 from december 1994? Especially Lambda/Oxygen sensors...
    Oh, I see you need some trace files.. Will make some for you tomorrow - what do you need me to do with the car running to get something out of it?
  22. #147
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by puttitat View Post
    first.. Could you try if 'std:obd' setting works instead of 'ADS'. I assume you're using that mode
    menu: Debug-> trace
    select your ecu (m60_338k) and then press 'run trace'. If OK then the trace file should be found from DebugLogs dir.
    problem is that I don't know how to do correct initialization on L-line which I believe is needed with your ecu.
    Can somebody confirm this?
    E61 520d LCI
  23. #148
    Denmark
    2012 BMW F31 330d
    STD:OBD doesn't work on my car, that's why I bought the ADS interface in the first place :-). When I need to communicate with IKHA, ABS and so on, ADS is the only thing that works... I get API-0006 error (in Testo) when I've opened COM1 under debug->serial port, and API-0013 if I don't do that first. :-( So no luck today. I guess I've done something wrong messing with GT1 yesterday, as INPA couldn't communicate with the car either. Format C:, and a fresh install - then I hope to be ready for some testing again. :-)
  24. #149
    Sep 2010
    england
    hey mika, were the lastest ms50 trace files of use? j.
  25. #150
    Northern CA
    1998 M3/4/5
    menu: Debug-> trace
    See http://forums.bimmerforums.com/forum...ds%20interface and http://www.bimmerforums.co.uk/forum/...lained-t85191/
    Basically - send on L, receive on K.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
