Page 4 of 42 FirstFirst 123456789101112131429 ... LastLast
Results 76 to 100 of 1027
Thread: Diagnostic program with realtime graph view
  1. #76
    Phoenix, AZ
    Which day of the week?
    I think you'll be able to find enough interested people to put together an open source project. I'm glad there's a free option. There always should be.
    Thank you.
  2. #77
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by WayneC View Post
    There is a terminal program I found a while back specifically intended for use in debugging serial streams
    Never used it but it may be what you are looking for to enable people to capture streams and send them to you
    See real term at sourceforge (realterm.sourceforge.net) sorry cant post direct links at the moment
    This program has the features that would come in handy in debugging streams but unfortunately the driver to enable so called Spy mode is not. Seems you have to donate first in order to get the driver.
    Anyway debugging streams can be done with help of tool32 so that's not really a problem.
    E61 520d LCI
    Check out TestO - free datalogger for BMW. Includes support for: AEM, PLX, 14point7, Innovate (through SDK)
  3. #78
    Mar 2011
    Germany
    e39 m5
    There is a free tool called DataLogger which works with nearly all older bmws
  4. #79
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by starshy View Post
    never heard that. Do you have a download link?
    E61 520d LCI
  5. #80
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Watched some real-time lambda oscillations in a graph and it seems my both lambdas are in quite good shape. Compared to MS42 readings oscillation was much slower.
    Also when watching lambdaintegrators values while spraying brake cleaner to intake manifold tell that I still have tiny vacuum leak in the back plate.
    And had some time to code and did actually communicate with my ecu straight from serial port without Ediabas. Read 40 bytes from memory in one reply which contained info for about 9 values: lambda voltages 1&2, lambda integrators, etc. Some values need to be fetched from ADC controller, like TPS and MAF voltage.
    E61 520d LCI
  6. #81
    Jun 2012
    Shanghai, China
    2012 BMW E90 320
    Thanks so much for the amazing works! Just wonder if it's possible to add the feature to record the CAN BUS frame?
  7. #82
    Pittsburgh, PA
    E36 M3 / 2.0T WRX
    Quote Originally Posted by pheno View Post
    Very cool! Let me know if I can help do any MS41 testing.
  8. #83
    GER
    E91
    Hi Pheno,realy nice tool,big thanks for that, working fine with DDE606 .Can t say that the readout is to slow.
  9. #84
    Nov 2012
    Karlstad, Sweden
    BMW 328i 2000
    Great software. Now we just need a logviewer to analyse.
    Would it be possible to change the filesaver so we can use it with megalogviewer ?
    Best regards
    Jonas
  10. #85
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by homebrew View Post
    Best regards
    Jonas
    Hejssan !
    I had a look at that megalogviewer earlier but I could not find the format of the log file that it expects.
    Can you find me the description of the log file that megalogviewer reads ? I can implement testo to produce such file if there are no other restrictions..
    E61 520d LCI
  11. #86
    Nov 2012
    Karlstad, Sweden
    BMW 328i 2000
    Hejssan !
    Yes i think we can work something out. Send me an email at svetsjonas@gmail.com and ill send you some stuff over the email.
    Best regards
    Jonas, Sweden
  12. #87
    Nov 2009
    USA
    2000 328Ci AW
    datalogging software
    smooth11981
    check your PM
    So that other people can know, does this software enable us to monitor the knocksensor live data along with ignition timing and lambda? This would be perfect for dyno tuning. My DME is the Siemens MS42
    Let me know
    Regards,
    Mark
  13. #88
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Just a general question to everybody:
    Is there some value you would like to watch or log but you can't find it in your ecu jobs list ?
    For example DDE 4.0 has bunch of values available but they are not shown in jobs list.
    Thank you.
    E61 520d LCI
  14. #89
    Sep 2010
    england
    1998 bmw m3 coupe smg
    id be interested in any smg info for the e36 m3 ms50 mate.
  15. #90
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by jamie123 View Post
    Have you tried smg.prg ? do you want me to convert it for you as .BIV file ?
    it has 'status_io_lesen' with bunch of values.
    E61 520d LCI
  16. #91
    Mar 2003
    Winnipeg, Manitoba
    1997 BMW M3
    I wonder if one could cobble scripts together using something like netcat and perl.
    Is there an english api document for ediabasapi.dll somewhere?
    It seems like this is the wrapper for much of the comms.
    If you put up a network sniffer on vmnet1 you could capture the chatter between the software and the hardware pretty easily over tcp/ip.
    I'm still catching up and waiting on hardware orders but it seems like there's quite a few people working on this from several angles right now.
    97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
  17. #92
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Just updated a new version of Testo. Haven't had much time to devote to this so nothing special new in the GUI area but...
    It now has a feature that runs a set of status jobs against your ECU and saves a trace file. From 'Debug' menu select 'Trace' and a dialog will appear. Select your ECU from ECU list. Then press 'Run trace' and wait it to finish. Then press 'send log files'.
    You will need working EDIABAS/INPA install. DIS is not required.
    If you want faster logging for your ecu please send the trace files to me by pressing 'send log files' when connected to Internet or email them to me. Do it as many times as you want. The more the better. Without your help faster logging won't happen. Trace files can be found in 'DebugLogs' folder.
    This is the first step (getting large amount of trace files) of various ECU's to have direct com port reading/writing implemented in testo.
    Files are in plain text format so there you can see what is going on. Heck, maybe someone else will start decoding them too !
    So take those trace files and send them over here. Thanks.
    E61 520d LCI
  18. #93
    Jun 2008
    EU
    bmw
    Question question [request]
    Hi,
    All parameters one by one, I can see with program Tool32. No prblem.
    Even, these can be recorded.
    Not need the graphics on the screen. Only write data to file. "Time" and 4 - 8 parameters.
    Suggest a format, which uses a program VAG-COM[VCDS].
    You can?
  19. #94
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by kanon View Post
    The MAIN question is writing a log file !!!
    I need to write data to file. Only "Time" and 4 - 8 parameters. Fast and many.
    Very IMPORTANT recording format.
    I would suggest a format, which uses a program VAG-COM[VCDS].
    There is a very good program "dp_logview" to view "VCDS" logs.
    Can I hope that my dream has come true ?
    Hi Kanon,
    Thanks.
    This program can record a CSV log file.
    First select the jobs you are interested in and then start logging from menu 'File Logger' --> 'start'.
    If you want faster logger you can help me by taking a trace file and sending it to me.
    What cars are you working on ?
    E61 520d LCI
  20. #95
    Jun 2008
    EU
    bmw
    Hi,
    I understand how to work with the program.
    Now I can`t work with the program - it should be easy to work with log files.
    If something like VCDS - the program will be good
    What level "Trace" you would like ?
  21. #96
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Hi, pheno !
    If something like VCDS - the program will be golden/world-class.
    Now more specifically, what level "Trace" you would like ?
    Kanon, Thanks. Let's see what we can do about that.
    [ It sounds I'm going to have to buy a car from VAG Concern just to try out this golden program called VCDS ]
    Ok, back to the business. Taking the trace file is easy. I told already how to do that.
    Here are the instructions:
    http://forums.bimmerforums.com/forum...6&postcount=92
    Is this OK ? You don't have to play with trace files at all.. is this easy enough ?
    You can send these trace files also by email - just send me private message to get my email.
    E61 520d LCI
  22. #97
    Jun 2008
    EU
    bmw
    Hi,
    You misunderstood what I meant. Sorry.
    OK.
    Good luck
  23. #98
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Some information for you: - VCDS with VAG concern not related.
    VCDS developed enthusiasts like you ....*
    OK. I understand your humor ...
    Good luck
    What diagnostic values would you like to log for M47 or M57 ?
    Tell also PRG names you use.
    E61 520d LCI
  24. #99
    Pittsburgh, PA
    E36 M3 / 2.0T WRX
    If you want to help to enable faster logging for your ecu please send the trace files to me by pressing 'send log files' when connected to Internet or email them to me. You can run it as many times as you want and send too. The more the better. Files can be found in 'DebugLogs' folder.
    Sounds like you've made some significant progress on this! I will send some MS41 Trace files soon.
  25. #100
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by mrf View Post
    Thanks. I appreciate that.
    In the meantime I'll add a possibility to add parameters to a job. Newer ecus like MS43 have a job that will return values you have requested in parameters - in one reply.
    E61 520d LCI
