Page 1 of 4 1234 LastLast
Results 1 to 25 of 81
Thread: Timing, VANOS, 1 tooth offset to crankshaft
    orlando, fl
    750li, RR SC, ML350
    Unhappy Timing, VANOS, 1 tooth offset to crankshaft
    I'm at a lost here, I'm getting the following error on the bank2 inlet VANOS
    2A8F CDKNWEKW2 - intake camshaft 2, cog offset of crankshaft (DIS translates it to, 1 tooth offset between the camshaft and the crankshaft.)
    Engine is also hesitating when cold, once warm it is fine.
    I have used the timming jigs on both banks and they both are at the correct timing (only bank2 is on error). I read the TIS and it says that the VANOS can be freely set in relation to the crankshaft, you only need to se the timing between the inlet and outlet VANOS, but yet I'm getting this error.
    - Checked inlet and oulet VANOS timing and it is ok
    - Checked for vacum leak and can't find anything
    - Spark plugs are new
    Can the selenoids create this issue? (DIS suggest that either the timing is wrong, the selenoids is bad or the oil is low (checked and oil is a correct level))
    I'm gonna say the timing is off, the solenoid is bad, or the vanos gear itself is bad.
    Sep 2008
    alabama
    2002 bmw 325
    its been a while since i have fooled with a N62 engine, but can you swap the solenoids from left to right banks. If you can and the fault moves, than you know its a solenoids.
    02 BMW 325
    13 MB GLK350
    94 GMC sonoma 4x4 - hpd30/8.8 - toy
    15 MB GLA250 (wife's)
    01 Pontiac WS6 - Garage Queen
    12 RAM CC Hemi powered - new DD
    GOIN BROKE BUT N STYLE
    Yeah, all 4 solenoids are the same.
    Jan 2012
    granada hills ca
    07 B7 , 91 E30 (m102)3.5
    ok .. listen carefully
    have you opened it up before this happend or one day u came and it happend
    does the code say anything like camshaft output stage ..
    if so there are a few things to check ..
    1.eccentric shaft sensor ..
    if eccentric shaft sensor checks out
    2. input stage is intake output stage is exaust depending on that code look into that camshaft actuator .. if you clear the code and it comes back after the second start
    its eighter a computer issue ( btw theres an update available for the valvetronics)
    theres in a cut wire ..
    NOW for what ive seen and repaired
    output stage cam code .. did the software update via our shops autologic
    second did a visual on the actuator wires and turns out the plastic connector chiped and one wire was sticking out of the connector housing .. could be tricky to fix specially if you call bmw they will want to sell you compete harness..
    i used a older bmw wiring harness and matched up the wires and walla
    did a syncro of the cams before starting and adjusted the mininum stroke to .08 the car has never idled smooth in its lifespan ..
    goodluck i kno my writing is everywhere
    but what do you expect from a mechanic lol spend my time in the shop more than english class
    orlando, fl
    750li, RR SC, ML350
    Thanks alpinaman for the sugestion. Yes the car was opened since i had to change the dreaded valve seals. I'm telling you, the car does not want to be fixed
    The funny thing is that it is only bank 2 the one with the problem.
    - changed the 2 selenoids, input and output
    - changed the vanos adjustment unit
    By reading more about the VANOS what it looks like is that the VANOS moved the intake foward or backward to compensate for the car starting, but now it can not move it back to the original position, so the car hesitates until it warns up.
    you can see it by looking at the VANOS adaptation for the inlet (using DIS)
    - cyl 1-4 is at 121.10 cr
    - cyl 5-8 is at 109.40 cr
    when i changed the adjustment unit the adaptation for cyl 5-8 was at 126 cr, but it then moved back to 109.40 cr
    Jan 2012
    granada hills ca
    did you learn the position of the eccentric shaft?
    maybe the connectors are reversed
    orlando, fl
    750li, RR SC, ML350
    I didn't check on that one, I will tonight when I get home
    I don't have any 750 available to validate, but the cable for the selenoids for bank 2 looks like should be coming thru the right side, and the cable is setup in a way not to place them in the wrong way, unless the cables come in from the left side of the block, but I will try that tonight too
    Jun 2012
    , Other
    mmm
    the vanos gear itself is bad.[IMG]http://www.**********.info/7.jpg[/IMG]
    Jan 2012
    granada hills ca
    switch the wires i kno its a tight space but swap them and try it ..
    orlando, fl
    750li, RR SC, ML350
    I tried that but they are correct. When it is backwards the car hesitates hard.
    Is there a way to verify that the eccentric sensor and the camshaft position sensor are good, to rule those out?
    One thing, does the eccentric shaft has a spring on it? Before, turning it felt like there was a spring holding it back, so it turned hard when manually turning it via the hexagon nut. But now it is a lot easier to turn.
    Robertson233,
    When you say the VANOS gear, you mean the adjustment unit?
    orlando, fl
    750li, RR SC, ML350
    Ok, so I changed the following but still no luck. This is driving me mad..
    - New VANOS adjustment unit
    - Swapped cam sensor to other bank, error did not moved
    - Swapped eccentric sensor to other bank, error did not move either
    Nashville, TN
    02' 745Li, 03' X5 4.6is
    Possible you may have a bad valvetronic control module. Have done a couple.
    Jan 2012
    granada hills ca
    theres a update on the valvetronic module .
    has that been executed?
    orlando, fl
    750li, RR SC, ML350
    All the systems were updated to the latest version.
    Does the VVT also controls the adjustment units? Can it be that the VVT is going bad even though I get no errors about it? One of the symptoms I'm getting is that when cold, it hesitates when approaching the 2k revs, but once warmed up and after a second restart it goes away. I need to restart it twice when cold, but if hot then I don't see the issue.
    Jan 2012
    granada hills ca
    sounds internal bro ,
    valve clearence
    orlando, fl
    750li, RR SC, ML350
    That's what i was starting to think, it feels like either gas or air cutoff, but since the VVT also controls the valve lift/clearance for the intake, I was thinking it could be it. One strange thing was that i did the re-learn VVT start/stop procedure by doing the key and start button, without presing the brake pedal, and then started it and it worked fine, only once :-( so i then did the re-lean VVT via DIS to see, but it looks like it didn't work. when hot the engine revs and runs/acelerate perfect and there is no vibration, sometimes it feels like the engine is off (just like it should) it is the damn, hesitation and one tooth off issue that is driving me nuts.
    I let DIS do the testing, where it brings the cam from 60 to 120 degrees of the crankshaft and a noticed a funny thing, bank 1 (not showing an error) flutuates back and forth betwwen 119.7 and 120 degrees while bank 2 stays at 120 degrees. i think that might be the 1 tooth off, but not certain.
    Jan 2012
    granada hills ca
    and you said you replaced the eccentric shaft adjustment unit ?
    the one bulgy looking thing by the top of the valve cover
    orlando, fl
    750li, RR SC, ML350
    The one I replaced was the vanos adjustment for the inlet, the one with the tooth that attaches to the timing chain
    Jan 2012
    granada hills ca
    ok i bieleve your eccentric shaft needs to replaced the one im talking about
    number 11 befopre pulling them out you need to use the scanner and press "remove eccentric shaft "
    that will unwind it all the way so you can replace it
    when you realign the eccentric shafts it should take NO longer than 10 SECONDS
    orlando, fl
    750li, RR SC, ML350
    Is there a way to know which one of the two needs to be replaced? I have use DIS to remove it, but when removing it, there is one that unwinds faster and harder the the other one. Is that the one which is probably having issue or is it the other one?
    Jan 2012
    granada hills ca
    previously you stated that you had no problems on bank one
    but you also said that theres a fluctuation on the bank two
    from what you said from your diagnosis sounds like you need to change bank two eccentric shaft adjuster
    New York
    335i
    hey guys, i'm a bmw tech and i've seen this issue before.
    since noone posted a fix... i will
    usually this fault comes up if debris got into the oil system usually from replacement of the valve covers. debris will get into the vanos gears and solenoids.
    i would remove all four solenoids and blow shop air through them and reinstall. then clear all adaptations and clear the DME ram. There is a function in the GT1 software. They removed this function in the new ISTA software. You will have to run the test plan oil disturbed test plan to do this.
    If that doesn't fix the issue, you will have to replace both VANOS adjustment gears on the bank that is having the issue.
    Good Luck
    Jan 2013
    belleville
    toyota
    what fixed the car i have one with same problem. cant seem to fix it
    Canada
    750 F01, 850i, LR3 HSE
    Cam Crank timing is still off. This happens when the Vanos adjustment unit is not put in it's initial position before setting the timing with the jigs.
    If you pull it apart and set the jigs on you will find that the tool will not set flush for the intake cam (more than 1mm).
    Ensure the gasket on the slide rail is always replaced (11 317 501 735) this is an oil channel the the adjustment units.
    The adjustment units rarely fail on this N62 motor.
    Ensure the crank pulley is locked in place with the correct size tool, not something that just fits loosely.
    Mark.
