Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 74
Thread: SR20det E30 GT28 E85 v2 aem ems
  1. #26
    Apr 2012
    New Zealand, Masterton
    1999 BMW 326t
    Quote Originally Posted by Jaze View Post
    Toyota JZ are much more reliable and require no sump modification to be fitted. I'd like to see what you did with the sump and oil pick up to get it in a e46
    Im from New Zealand and thankfully we have some good engine fabricators here that sorted that out for me. The place is called RIPS and they made a custom rear pan baffled sump with custom pick up
    Quote Originally Posted by rpm620 View Post
    Pics???
    I havnt figured out how to upload them?
  2. #27
    Mar 2011
    Seoul, phoenix, missoula
    galant vr4 S13
    Quote Originally Posted by imaiami View Post
    sup dude, long time no talkies.
    I hear the beast is a movin these days if I'm not mistaken.........
    hope all is well senor....
    not quite rolling yet, soooon though
  3. #28
    Mar 2011
    galant vr4 S13
    Here is what has been eating up ALL of my time...
    Last race of the season early Dec. and then i should finally have some time for the Bimmer again.
    Full story of the DC5 touring car here: Buddy Club and Brewed Motors team up for Thailand touring car project
    Or just watch the video of the DC5 trading paint on the circuit!
    [ame]http://www.youtube.com/watch?v=K1V0lm1lZfw[/ame]
  4. #29
    Mar 2011
    galant vr4 S13
    Tie rod spacers almost finished up.
    using E46 lower control arms, e36 rack and tie rods (inner and outer)
  5. #30
    Mar 2011
    galant vr4 S13
    well a slight change of plans do to a bad front wheel bearing. I've been looking for an excuse to do this any way.
    Picked up a set of e36 (non M to the best of my knowledge) knuckles/brakes fit them on the E30. Modified the coilovers and top of the strut (moved forward to help the caster issue) car is also fitted with the E46 lower arms.
    While the current solution works i'm not terribly happy with it and will be building a new strut tower/plate that will allow for proper tuning. The "lolly pop" also needs some attention ie: adjustable in order to really be able and dial in the front.
    Test fit a 17x8 38mm wheel and to my surprise the fenders did not agree. A quick snip and i was able to make plenty of extra room for $0 Now just a bit of fiber work to tidy things up.
    **fail, thought i had a picture or to on my computer already. pic tomorrow
  6. #31
    Dec 2011
    Staten Island, NY
    92 E36 325is
    looks good man!
  7. #32
    Lake Orion, MI
    1986 325e
    Awesome. Looking forward to more pics. That's quite a large work space you have there....
    86 325e
    scrape, scrape, boom, hiss..........................
  8. #33
    Mar 2011
    galant vr4 S13
    super SH** I pod picture outside my old Apartment but it gives you an idea of how the fender was treated
    I'll be doing a bit of fiber work as well, nothing as in depth as the cyber evo but these pics will give you a good idea of what the finished product will resemble. (again nothing as extreme for the e30 at this point!)
  9. #34
    Mar 2011
    galant vr4 S13
    Looking forward to taking delivery on some Ar. gas this week to get my weld on!
    Will be keeping things simple just a matter of finding the correct DOM material over here.
  10. #35
    Nov 2012
    Everett, WA
    BMW e30m50
    looking really good
  11. #36
    St. Louis MO
    1987 328i (track car)
    looks good, I might be doing an sr swap on my e30 as well. Seems to be a solid build!
    Speed>Elegance
  12. #37
    Mar 2008
    Bunker Hill, WV
    95 M3, 07 Titan, 96 XJ
    love this build....
    E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
    Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
    *RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
    Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
  13. #38
    Mar 2011
    galant vr4 S13
    New year causing some delays...
    can't find anyone to deliver DOM (or even order it until after the new year)
    Shop with the plasma cam can't seem to use my cad drawing of the exhaust flanges needed. Anyone here familiar with "turbonest" software?
  14. #39
    Sep 2012
    Connecticut
    1997 328is
    Quote Originally Posted by tunermt View Post
    The S15 turbo at 25-30 psi for mid range rpm will be fine, i suspect i'll be able to make 380-400 torque with it. I agree though at high rpm i'll have to tapper the boost down to around 18-20 by redline if i don't want a bunch of hot air.
    This will actually be a very similar set up to what i did for the 4g63 in my VR4
    300 torque max if your lucky with that turbo. Running 18 psi or 30 psi will make the same power probably a little less since the compressor will be so far past the efficency zone it will be just a hair dryer heat soaking your intercooler. Realistic out put number at 18 psi are 300 hp and 250 ft/lbs.
    Sick build by the way!
  15. #40
    Mar 2011
    galant vr4 S13
    It all depends on the set up and how much boost you make at low rpm when it comes to the torque. You can absolutely squeeze over 18psi out of the S15 turbo on an SR in the mid range to make more than 250 torque.
    I do agree the 300hp and 250 torque #s would be realistic for pump gas and 18psi, with better fuel and some fine tuning there is more power to be had
    With that said I may not even end up using the s15 turbo if all goes as planned in the next 3 months.
  16. #41
    Nov 2012
    Hawaii
    1986 E30 325es, 2003 GTI
    sick
  17. #42
    Mar 2011
    galant vr4 S13
    putting a bit of metal back into her
  18. #43
    Mar 2011
    galant vr4 S13
    updates coming again one day soon, just no time to play with my personal car at the moment...
  19. #44
    Mar 2011
    galant vr4 S13
    recently had some time to add a little strength and caster adjustment to the front strut mounts.
  20. #45
    Mar 2011
    galant vr4 S13
    bit more from today
  21. #46
    Aug 2009
    Arizona
    e36 m3 rip, e36 truck :D
    oooohhhh la la.
    lookin good
    VROOOOOOOM
  22. #47
    Mar 2011
    galant vr4 S13
    More metal...
    Front strut towers
    Tubes to front frame rail
    Tubes to lower frame rail under drivers/passengers feet. *still need to add gussets to a few places on these*
    Repair/re-enforce/replace frame rails
    Added "sub frame connectors (these basically run wheel to wheel (front to back) along the pinch welds and have a few cross bars) *will be incorporating trans mount and drive shaft hoop in the cross bars*
    Sheet metal patch/re-enforcement **as you can see in the pictures rear of the front wheel wells still need some sheet metallove**
  23. #48
    Nov 2011
    New Jersey
    96 M3
    holy shit. give me a lift
  24. #49
    Mar 2011
    galant vr4 S13
  25. #50
    Mar 2011
    galant vr4 S13
    E34 complete subframe swapped in along with rear coilover set up.
    I also had some time to start on the cooling system, still have to add a few breather fittings/lines before she's complete
