Table of Contents:
Sister threads:
http://forums.bimmerforums.com/forum....php?t=1825409
http://www.e30tech.com/forum/showthread.php?t=113388
http://www.sr20-forum.com/members-ri...k-m-coupe.html
1) Introduction
2) Up-to-date price record
3) Up-to-date fuel economy record
4) Up-to-date maintenance/modification record
5) Original sale listing pictures
6) "Taking delivery"
7) Katie driving and other pics
8) Random pics
9) Rear view mirror replacement (due to de-laminated LCD)
10) Replace rear Konis with proper height dampers, and install Ground Control rear shock mounts.
11) Windshield crack filled
12) Track day - Virginia International Raceway (VIR) South course
13) Seat belt height adjuster fixed
14) Rear tire punctures
15) Driver's seat damage
16) The daily hangs out with the track car
17) Fender bender and repair
18) Install grills and badge
19) New rear tires
20) New front brake pads arrive
21) Whalen aluminum hood release handle arrives
22) Another rear tire puncture
23) New front tires arrive
24) First oil change
25) Car wash
26) Fender bender #2
27) Front brake job with euro rotors
28) Measuring brake clearances for new wheels
29) A/C recharge and assessment
30) Installing Doug Whalen's aluminum hood release handle
31) Install new front tires
32) 2013 National SR20 Convention
33) 2013 National SR20 Convention (Katie's pics)
34) Low beam replacement
35) Dressing the hood
36) Touching up the side gill area
37) Gear oil (transmission fluid) change
38) Driveshaft flex disc (giubo) inspection
39) Mechanical radiator fan removal
40) Brake dust comparison
41) Jonathan Thayer's (mcoupemindy) seat tilt mod install
42) 130,000 miles
43) Windshield washer fluid leaks - attempted fixes
44) Interior light dimmer bypass
45) Glove box knee crash plate removal
46) Adjust sticking HVAC blend door
47) Track day - Virginia International Raceway (VIR) Full course
48) Covered in leaves
49) Loose hatch latch
50) Hide dash cam wiring
51) Oil change
52) Replace magnetic spats
53) Hooning in the snow
54) Rear tire swap
55) New Apex ARC-8 wheels arrive
56) Track day - Barber Motorsports Park (BMP)
57) New front tires arrive
58) New rear tires arrive
59) Raise the rear with thicker spring pads
60) Document the stock undercarriage
Introduction:
Facebook album permalink (in case the images don't show up in the future).
2000 BMW M-Coupe
Research thread: http://forums.bimmerforums.com/forum....php?t=1518166
Original listing: http://forums.bimmerforums.com/forum....php?t=1798519
M-Coupe Buyer's Guide listing: http://listings.mcoupebuyersguide.co...?ListingID=785
Production information (rarity): http://listings.mcoupebuyersguide.co...CM9346YLC62163
BMW VIN lookup link for my records: http://www.rubmw.ru/vincode/eng/
For as long as I knew this car existed (might have been 2003 when I was clued in) I've been thinking about eventually owning one. It quickly reached the top of the list as most attractive car ever made in my opinion. How great would it be to actually be able to own what you consider to be the best looking car? Pretty cool I say. So, eventually I was in a position where I was seriously looking starting about a year ago. After doing some initial research in the research thread linked above, I realized I did want an M coupe, and Jon Martin's amazing web site was actually a big reason for that simply because they were much easier to find than a non-M.
So I was looking for a black car, with probably a black interior, and if I could possibly manage it, no sunroof. It also needed to be affordable. Each month that went by the budget raised and more options were opening up. I was interested in a few cars but nothing came to fruition and they all had sunroofs. When I saw the listing for this car with a reasonable price (the highish mileage really meant nothing to me, same as the cosmetic stuff) and no sunroof I had to have it. The pictures of the grey interior were a little worrying (it looks a bit too light for me) but with the black exterior and no sunroof I was basically sold. The detailed maintenance history and the care with which the seller treated the car and the no-nonsense listing were all icing on the cake. I believe I got an amazing deal with this car. As it turns out the grey is much darker in person and I think it is now my favorite interior color (for a black car at least).
I won't get too much into the pleasantries anymore because I'm sure the rest of the car needs no introduction to this crowd.
I'll just get straight into the specifics of this particular vehicle, partly for my own records.
The good:
- Extremely well cared for by previous owner
- Extremely well described in sale listing; much appreciation to the seller!
- Aluminum radiator, t-stat housing, metal impeller water pump (Link)
- Very clean interior (Link) (minus one issue, see below)
- Relatively decent exterior for the price (Link)
- Already lowered on decent suspension (TC Kline kit - H&R springs and Koni dampers)
- The clock doesn't work! I don't have to get nagged by Katie for us being late for work!
The bad:
- The rear Konis are set to full stiff which crash over bumps, need to find out how to access the strut tops to adjust them
- Scratch in paint on right side of hatch (Link)
- Scratch in paint above driver on roof (Link)
- Fading on stock rear spoiler (Link)
- Stock wheels (I'm not a fan, but it could be worse)
- Tiny windshield crack near bottom (Link) (might not have been there during sale)
- De-laminating rear view mirror (Link)
- The window tint is showing some age
- The windshield fluid reservoir won't hold much fluid, might have a leak
The ugly:
Driving impressions:
So you know where I'm coming from, I've driven a large selection of sports cars or sporty cars. I used to work at a shop doing interior work on mostly dealer cars and have helped relatives shop for sports cars which have provided me a lot of opportunity to test drive lots of various sporty cars. I've also had a good bit of time (weeks at least) behind a couple of serious performance cars, both modified and stock. I like a light, toss-able car (even at the expense of rigidity) with exceptional outward visibility and I'm extremely picky when it comes to pedal feel/placement, and shift lever feel.
So I don't go on forever, let me just quickly explain the car as if I were giving a quick synopsis to a potential buyer. The chassis is unflappable if a bit heavy. The ultimate lateral grip with stock sized rubber is huge, I haven't even found the off-throttle limit yet.
The seats are among the best in any car.
The outward visibility is not great, but much better than I expected once the seating position is adjusted for my height.
The interior secondary controls all make sense and haven't been ruined by modern "designers".
The driving main controls are all pretty well placed. The shifter sits in the right spot for me. As many would agree, a smaller steering wheel and possibly even a quicker ratio steering rack is not a bad idea. I've always had issues with BMW throttle pedals and this is no exception. The accelerator pedals on these cars are too stiff, and I don't like them being floor mounted. They are also not well placed for heal-toe action as far as I'm concerned. Much better than most cars, but not up to the placement of even the B13 Nissan Sentra. I am getting used to it though. The brake pedal action is firm and what you'd expect from a decent sports car. The clutch pedal is a bit stiff, but overall offers good feel. I'm actually surprised it is so stiff, being a hydraulic actuation. I'm also surprised it provides so much feel, so I guess it is a wash. The shift lever action itself (I think I could write books about each vehicle shift action I've driven so I'll try to keep this brief) is decent over-all. One of the main things that can kill a driving experience for me is a bad shifter. The Coupe has a very direct gate, it is not vague at all like a FWD VW cable shifter if you've experienced them. While I do like a good bit of effort (the S2000 and RSX-S are too light to be ideal if you've driven those) the Coupe really has taken effort too far. The worst part for me is how notchy the shifter is. Again, I do actually like to feel when I've encountered the sycnhronizer(s) and I like to feel when I've left them behind but this Coupe's shifter takes that too far. If I had to describe shifting this transmission right now it would involve some type of bag-of-rocks metaphor. The transmission was completely replaced 45k miles ago (at 75k miles) so I'm not sure what to think. It also doesn't feel quite like the 2.8 Roadster and 3.0 Coupe I've driven in the past either, so I'm thinking a fluid change is in my near future. I'm aware of the shift pin issues. I'll keep my eye on it.
The power output is surprisingly peaky. That might not sound right, but compared to the cars I'm used to driving, the Coupe feels an awful lot like an S2000 to me (which is not a bad thing). As some of you may know, I'm not really a fan of torque and so I'm not really bothered. I did expect the car to move with a bit more authority from low rpm in second gear, but I will just get used to dropping it all the way down to 1st just like I did with the SE-R when it was N/A.
The traction control is surprisingly more performance oriented than the traction control in the 2.8 Roadster I drove for a bit. I guess the M division has a different algorithm for the traction control and at the least the heuristics for giving power back are much better. The non-M roadie would cut power for whole seconds it seems. The M just seems to keep you in line. Regardless, it gets turned off every time the car gets started.
Future plans:
Basically the car is going to be my new daily driver. I'm so sick of driving around the girlfriend's VW Beetle. It has served us well, but I wanted to daily something that was a bit more my style since I do 95% of the driving. There were thoughts of replacing the front bumper with a non-M bumper, but seeing those winglets/flippers in person I've decided they don't look too bad. They are a lot smaller in person than they look in pictures. Along with that I was going to get some non-M fender gills, since I think the M gills are a bit flashy and I really like the non-M versions better. That may happen, it may not. I was thinking of making them functional too, but after seeing the frame rail and fuse boxes behind them I'm not sure that's happening either.
I need to loosen up the rear dampers, and eventually replace that damaged interior trim piece with the two holes in it. I want to get some new wider, lighter wheels with matching summer rubber. I'm pretty sure I know which wheels, I just need to get the money together.
I'm pretty sure an M50 intake manifold is in my future, and something like the Shark Injector(?) ECU to smooth out the fuel delivery and raise that rev limit a little bit. I'm not sure if I'll do headers, but we'll see. The exhaust from the cat-back is going to stay stock, especially those cans out back.
I'm thinking a clutch delay valve delete needs to happen, and I need to raise up the clutch grab point if I can. Also need to make sure the throttle stop isn't set incorrectly. The thing feels a little slow.
An electric radiator fan is also in the plans. Whatever makes sense to free up some power and gain some efficiency without sacrificing reliability and drive-time I'm all for it.
I'll get more into detail as this thread goes on, but for now I'll stop. As always stay tuned for updates as things happen and any questions or advice is always welcome. Cheers!
Previous owner's title: Front Back
Bill of sale: https://sphotos-a.xx.fbcdn.net/hphot...68748057_o.jpg
Property tax: Bill Receipt
Up-to-date price record:
$14,000 - used 2000 BMW E36/8 (Link)
$339 - sales tax (capped in SC at $300) plus misc fees
$264 - property tax (Link)
$95 - Sybesma's Electronics replacement rear view mirror (Link)
$264 - Rear Koni shocks (Link)
$114 - Ground Control rear shock mounts (Link)
$80.34 - Windshield repair (Link)
$20.60 - Tire puncture repair (Link)
$403.71 - New OEM body and trim parts for body repair (Link)
$1,300 - Body repair work (Link)
$156 - Replacement kidney grills (Link)
$235.20 - New rear tires, mounting, and balancing (Link)
$99.87 - New front brake pads (Link)
$30 - Whalen aluminum hood release handle (Links 1 and 2)
$183.81 - New front tires (Link)
$86 - Oil change with filter (Link)
$374.16 - New OEM Euro E36 M3 2-piece floating brake rotors (Link)
$21.96 - New front brake pad wear sensor (Link)
$41.30 - Mount and balance new front tires (Link)
$11.87 - Low beam replacement (Link)
$45 - Amsoil transmission fluid. (Link)
$199 - Lukas LK-7900 dash camera. (Links 1 and 2)
$44.90 - Spat (fender guard) replacement (Link)
$41.30 - Swap rear tires (Link)
$1,001 - Apex ARC-8 wheels, concave, hyper silver, 17x9 and 17x10.5 (Link)
$372.93 - New Dunlop Direzza ZII front tires (Link)
$210.84 - New Sumitomo HTR ZII rear tires (Link)
$43.96 - New 14.5mm rear spring pads (Link)
Total: $20,175.75
Up-to-date fuel economy record:
11.74 mpg - Worst track economy
12.52 mpg - Average track economy (Raw - 37.57/3)
13.44 mpg - Best track economy
13.16 mpg - Worst city economy
15.61 mpg - Average city economy (Raw - 795.97/51)
17.68 mpg - Best city economy
15.64 mpg - Worst mixed economy
19.84 mpg - Average mixed economy (Raw - 476.19/24)
24.65 mpg - Best mixed economy
19.70 mpg - Worst highway economy
23.02 mpg - Average highway economy (Raw - 230.21/10)
25.50 mpg - Best highway economy
Up-to-date maintenance/modification record:
Previous owner's maintenance history records:
My maintenance history records:
~2012-05-26 ...... 121,xxx ...... Replace de-laminated rear view mirror with Sybesma's Electronics replacement
~2012-09-16 ...... 123,xxx ...... Replace rear shocks with proper height Konis
~2012-09-16 ...... 123,xxx ...... Replace rear shock mounts with Ground Control solution
~2012-09-16 ...... 123,xxx ...... Patch rear tire punctures
~2012-11-25 ...... 124,xxx ...... Have windshield crack filled
~2013-01-06 ...... 126,xxx ...... Fender bender repair
2013-03-27 ........ 127,xxx ...... Replace rear tires with cheap Sumitomo summer tires
~2013-04-15 ...... 128,xxx ...... Patch rear tire puncture
~2013-05-01 ...... 128,329 ...... Oil and filter change with Amsoil Synthetic European 5w-40
~2013-05-17 ...... 128,xxx ...... Replace front brakes with Hawk HB135Z.770 Performance Ceramic Pads and OEM Euro E36 M3 2-piece rotors (34112227737 left, 34112227738 right)
~2013-05-20 ...... 128,xxx ...... A/C recharge and assessment (no leaks, A/C compressor on its way out)
~2013-05-22 ...... 128,xxx ...... Install Doug Whalen's aluminum hood release handle
~2013-05-27 ...... 128,xxx ...... Replace front tires with cheap Sumitomo summer tires
~2013-07-15 ...... 129,xxx ...... Install Jonathan Thayer's (mcoupemindy) seat tilt mod (passenger side only)
2013-08-10 ........ 131,xxx ...... Bypass the broken interior light dimmer
~2013-08-17 ...... 131,xxx ...... Remove the glove box knee crash plate
~2013-08-17 ...... 131,xxx ...... Adjust the sticking HVAC blend door
~2013-10-15 ...... 132,xxx ...... Replace original transmission fill with Amsoil Synthetic Manual Synchromesh Transmission Fluid (5W-30)
~2013-10-22 ...... 132,xxx ...... Remove the OEM mechanical fan
~2013-12-05 ...... 133,xxx ...... Properly tighten the rear hatch latch
~2014-01-15 ...... 134,xxx ...... Install Lukas LK-7900 dashboard camera
~2014-01-22 ...... 134,675 ..... Oil and filter change with Amsoil Synthetic European 5w-40
~2014-01-23 ...... 134,xxx ...... Replace the aging and poorly fitting spats (fender guards) with new, better ones from Roadster Solutions
I usually take a little bit of time to get around to hosting pics and updating my build threads. I picked the car up about a month ago. I really can't say enough good things about the seller. Everything went off without a hitch and I'm very happy.
Awesome, fuel economy sucks though, and when you want to upgrade you gills, let me know. I want the stock M ones.
What color are yours Amuro?
If I get in the painting mood, I'll let you know. For now, I'm going to sit tight. Maybe I need to get those exterior blemishes taken care of sooner rather than later, and have the bodywork all done at the same time. I'll let you know if I plan on doing that any time soon. I move kind of slow. =/
Me too, but if you want to sell them outright, let me know.
Congrats. Jealous of the sunroof delete.
Makings of a great thread. I was next in line for the car, and emailed about it, only to be told someone else was ahead of me. Congrats!
Congratulations....I've read some post on here that indicate rear view mirrors in the condition yours is in could leak fluid and damage the finish on the dash.....
Congrats and that is a fine looking vehicle.
Sorry about that.
Thanks for the heads up. I'll keep an eye on it. I heard by the seller that there is someone on here who fixes or sells replacement mirrors? I hear you can't get them from BMW anymore? I'd like to get this fixed. And permanently?
Good purchase. Look up Dr. Colorchip for paint if you want to do some touchups. A couple hours spent was well worth the effort on my front end.
"If the Corvette is a rebellious child of the extended automotive family, the M coupe is the blackest of sheep." - via Car & Driver
Your are correct on all points. I have read a post about some one repairing these mirrors. Some people have opted to use a smaller rear view mirror account the original is SO large that people have complained that it obstructs your forward vision. While my 98 M has the smaller mirror installed when I purchased my car. I'm not sure which mirror is used as a replacement. I still have my factory mirror and It shows no sign of damage. I'm guessing that when installed the heat coming thru the windshield damages the factory mirror.
Thanks for the link! That's exactly what I needed.
Congrats! Also slick top M coupe, it's like a dream come true!
It sure is a dream come true. I am loving it. I tried to get the GF prepared for it but she couldn't believe that even the first day out we had some 6-year-old asking us all about the car through his rear passenger window.
Here's a company that will send you a refurbished oem mirror.http://www.sybesmas.com/home.html
They remove the fluid and change the internal parts so that it still provides auto dimming. I have one of these mirrors and am very happy with it.
I recommend taking care of this issue soon before the fluid destroys your center console. I wasn't so lucky
-Phil
Don't worry, thanks to stamosenvy and post #19 I've already removed the mirror from the car and am going to ship it out to Sybesmas later on in the week. I confirmed over the phone that they still do this, and it's still $95. Worth every penny if you ask me.
