I have a 97 528i and I need to replace the auto trans. I notice there's a difference with the last letters on the trans part number for different build date. Mine was build 10-96. And I find a lot of trans from 97 but they said its for 02-97 build date and up. They are same A4S 310R trans, so what's the difference and what will be the problem if I use a later build date?
Can anyone please verify if I can use a later build date? Or any A4S310R transmission. 328i also use the same trans. Thank you in advance.
You can use the 328 tranny but you will have to modify it because the "switch" is different meaning you will have to use the switch from the old tranny.
A4S310R has two oil pans, you can use any 97-98 528i and select 328i with 2 pans.
manual transmission?
E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
PANAMA, CIUDAD DE PANAMA
Can you please verify? I have 97 528i build date 10-96 and the trans is coming from 97 528i build date 02/97. I just wann make sure it will work. Let's keep 328i out of the story. I know they have manual mode switch and 528i doesn't so there's modification there. But 528i is straight no other buttons. I just wanna know if later build will work.
Thanks guys
Anybody???
02/97 build date will work. You can verify this by looking for the double oil pan.
Some changes are so minor you won't see them, and they are interchangable. Some difference are major (gear ratios, torque converter) and can not be interchanged. *I* do not have a definitive list of what changes happened when with which ID codes. The factory has never released this information.... believe me, I've tried to get it. You are only guaranteed a proper exchange if you use the same transmission code. Yours would be a PF. The donor should be an SC.
I do not have a crystal ball to predict if it will work or not without totally disassembling and inspecting both units.
/.randy
I am going through the exact same deal. I realize this is an old post and you probably have either gotten rid of the car or it’s running. I have a 1997 528i build date 6/96. I got a donor transmission from a 528i with a post or after 1/97 build date. Everyone said it would work. After going through putting it in......it does not. If your car is a 12/96 or before build dat you have to have the same build date transmission. Hope this helps. Best of luck.
Having said all that, does anyone have a 1997 528i build date prior to 12/96 transmission they want to get rid of? My car is still broke on the lift. Waiting for a transmission. Thanks to all!
