Page 92 of 104 FirstFirst ... 4267828384858687888990919293949596979899100101102 ... LastLast
Results 2,276 to 2,300 of 2596
Thread: Should I or should I not do it...
  1. #2276
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Yes.
    How do you like it, how is boost lag
    Where did you get yours, I'm looking to buy one to replace my current gt35
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  2. #2277
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I think it has good response (seems about like my old gt35r or efr8374 on open manifolds) but have been so busy I have put only a couple of thousand miles on it and have not really beaten on it ir had time to dyno. I did a test a while ago for response. 2000 rpm in 4th steady cruise. Floor it. Lift at 3000 rpm. I did it a few times and eboost2 peak hold showed 18 psi. Check with chikinhed. He has same turbo and ts steed mani and just got his running. He has proper data logging stuff.
  3. #2278
    May 2003
    Irvine
    What would be the downside to go with a t3 adapter and getting a t3 divided .82 ar...
  4. #2279
    Manchester, N.H.
    96 332IS 6466 turbo
    What's wrong with 1.06 ? For divided you usually want
    1.0X AR.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  5. #2280
    May 2003
    Irvine
    I spoke to several people and they all say 1.06 is not ideal and will experience lag.
    I want to go back to .82 or in between .82 and 1 ar
  6. #2281
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    1.0X AR.
    Who is "you"?
    Explain this please
    and show data to support.
    A five (5) paragraph essay will do, citing references.
  7. #2282
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by milKt View Post
    Who is "you"?
    Explain this please
    Generally the divider is not accounted for. Therefore running a 1.00 AR is in the ballpark of a 0.7X to 0.8X AR open. So running a 0.8X AR divided would be like a 0.6X AR open. Good for spool, but hurts topend flow significantly.
    1996 332IS
    Built 3.2
  8. #2283
    milKt's Avatar
    Understood,
    but TWINSCROLL turbos STILL perform better across the board even with the same AR (all things equal) where's Kam
    This article documents the advantages well.
    http://dsportmag.com/the-tech/twin-s...-great-divide/
    Please don't use the "KA24" engine will react differently than our inline six platform excuse.
  9. #2284
    Manchester, N.H.
    96 332IS 6466 turbo
    Understood,
    Agree
    1996 332IS
    Built 3.2
  10. #2285
    May 2003
    Irvine
    I'm going for it, pulling the trigger buying the adapter and t3 .82ar divided turbine housing, will be good for testing.
    I also got the TIAL 44mm today, will be installing tonight.
    I'm waiting for Chikenhed to do some logs and get some data on his turbo, more than likely will be buying one of those as well.
  11. #2286
    NY
    skateboard
    The pursuit
    ― George Orwell
  12. #2287
    May 2003
    Irvine
    Anyone knows the part # for the correct fitting for the TIAL MVR... the one I got is not thick enough, after installing it the actual fitting keeps moving freely, as you can see the one that comes with the waste gate is thicker and allows the fitting to make pressure against the head bolt and wastegate
  13. #2288
    milKt's Avatar
    tialwgaf10
  14. #2289
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    make sure you got an authentic Tial. The ones usually sold on Ebay are Chinese knockoffs.
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  15. #2290
    Manchester, N.H.
    96 332IS 6466 turbo
    I'm running stainless steel lines off the gate, you want a 10mm 1.0 to 4AN or 3AN whatever your using.
    I tried using what your attempting years ago, you can make it work if you cut the threads down a little.
    1996 332IS
    Built 3.2
  16. #2291
    Jun 2005
    New England
    You would need 4an male to 4an female adapter to space the banjo up. Did not look to see whether such adapters exist.
  17. #2292
    Apr 2006
    Minnesota eh?
    86 325es
    stack the extra washers off the taller one on the shorter one to make it thicker. Done.
  18. #2293
    May 2003
    Irvine
    Small update.
    I installed the TIAL, although a little better still having spool lag per say, I don't see 10 PSI until 3500rpm and full boost by 4k ash... spoke to John at CES, compared with his recent GT3586 with stock wheel and cams and Im 300rpm off, he seems to think as well as others that is normal.
    Now, fast forward to today, I decided to do a boost leak test in section, first turbo piping all the way to the TB but not including it, all normal; then from cold piping (after IC) forward and dear god, found 2 massive boost leaks, first one at the pre TB meth injector and 2nd at the TB elbow, the latest was massive !
    Im fixing it now and will do a test drive, will see if I notice any difference.
  19. #2294
    Aug 2008
    Calgary, Ab
    E30
    I have a Gt3582r T3 1.06ar on my S50. With electronic boost control I hit 15psi around 3800rpm. EBC off just spring pressure hits full boost a little after 4000rpm. So doesnt seem like your to far off.
  20. #2295
    May 2003
    Irvine
    Quote Originally Posted by Boosted E30 View Post
    That along bigger wheel seems about right as I have a GT3586R
    Are you running stock cams?
  21. #2296
    Manchester, N.H.
    96 332IS 6466 turbo
    The thing is, this steed speed is a spool monster. So while your numbers seem fine for an open manifold, we all are experiencing crazy spool with V2 twin scroll.
    I'm going to get some logs tomorrow. We should start a zetronix thread to share logs.
    1996 332IS
    Built 3.2
  22. #2297
    Aug 2008
    Calgary, Ab
    E30
    Quote Originally Posted by Matutino View Post
    Yes stock cams.
  23. #2298
    May 2003
    Irvine
    Tonight I found some issues, some easy to fix some not so easy. The Maf wiring appears to be rubbing the hood and the wires are coming apart, I bought a new maf pigtail and re doing the connection. Now the last time I went for a ride I saw some smoke coming out near the turbo area, I first thought it was the new wrap around the waste gate tube that was burning, after further review it appears oil is coming out of the turbo, I can see the turbo blanket covered with oil, I need to find out where the turbo is leaking and why.
  24. #2299
    Vancouver, B.C., Canada
    '97 M3
    There ya go, an excuse, a faulty turbo, replace with EFR 9180
  25. #2300
    Jun 2005
    New England
    Might just be the oil line.
