91 octane with meth and will be mixing e85
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
Drove the car roughly 60 miles... feels great, other than missing the wastegate dump... cough cough Chris cough cough... is all ready to go.
I also got the smog check done, after 15 months Bee is smog legal AGAIN.
Next, gotta do another 240 miles, do coolant flush and oil change.
I was on my way back home today 6th gear around 2900rpm went WOT and pulled 7PSI instantly... cant wait to do some test pulls and datalogs.
1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
Stock motor
1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
build thread:
http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
While wait for the wastegate pipe, I removed the wastegate to find out why was leaking at idle, seems like the fire ring did. OT seat well, put it back together and leak went away.
For those running cams, I got Shrick 256/264, what's your vacuum at idle, I'm getting 13, highest is 14 after warm up.
The increase in overlap is causing your decrease in vacuum. Now, if you were to adjust your cam timing by degreeing your cams to reduce the overlap you will increase your idle vacuum and you will get faster spool and transient response. I see about 16-17 "Hg with the same cams.
PS I told you so
My warm idle vacuum with schrick 264/256 is about 17.
It would be nice to have cam timing blocks that had the degrees difference compensated for in them. Then we could ship them around the country so the guys that don't want to learn could set their timing up differently.
My vacuum might be higher than 16-17, I haven't driven my car since November.
That would be nice, you seem like a handyman... should be easy for ya
Hmmm... OK, hopefully it shows up when I do the vacuum leak and is a simple fix. I'm going to see what my log shows, I learned a while back my true bossy was reading 2psi lower, maybe is doing the same with vacuum.
I designed some cam timing blocks but I couldn't get any feedback from anybody to got some pictures or measurements as to if they would fit in an E36 or not so I lost interest.
I have this one for my car that people can use but it only fits in an E30 or with the motor out of the car. The cowl on an e36 is in the way.
I'm like 19-20 in vac at idle schrick 264/256
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Tested with 2 gauges abs both read roughly the same.
I did a boost leak and all seems right... next I'm going to check timing.
Next time, I'd recommend just buying straights and U's or UJ's. It will save you a bunch of cash.
^^Yeah you can get any angle you want out of a 90 or 180. A lot cheaper buying 90s or 180s and cutting out what you need. You could have gotten those two 90s and two 45s out of two 180s and still had another 90 or two 45s left over.
UJ seems like a good deal. I bought one for my WG pipe.
1996 332IS
Built 3.2
TiCon?
To boost , or not to boost that is the question
― George Orwell
