Butterfly valve is exhaust cutout
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
I can tell you really missed the ol' e36.
What do you guys think, bag A or bag B...
I replaced all of mine with "b"
97 M3 formerly AASC now Technique Tuning Stage II (thanks to Got PSI, Shuasha, BMWPerson, M3 Madbimmer and 99MPower)
Cut Ring HG | Eboost2 | Aquamist HFS-6 | 6-speed | EVO3+DSSR | 3" Vibrant Exhaust by LukeG | FX-R Retrofit | AST 4100 | TMS Sway Bars | Dynaudio Set 360 | Arc Audio | Pioneer DEH-80PRS
Originally Posted by MatutinoMe too!!Originally Posted by acastillo
However, with my old thick AA cast manifold. I had to back the studs out a little because the nuts were not grabbing enough.
Plus, if you ever have to remove the manifold in the future, it will be do nice to remove the entire stud for more room.
Hence, my vote is bag B.
This is my signature....
You got more work done in a week than I did in a month.
How do the rings fit in the gasket this 2nd time around? Loose or snug, and any different than last time?
2 full weeks on my cut ring and I'm so happy I can boost without worry of pressurizing the cooling system .
THey fit snug/tight as before.
I know the feeling, I had it with my Hellrot after doing the cut ring HG
I was going to do the HG today but my air compressor decided to stop working on me... that + my helper called in sick .
So decided to do the interior instead.
I have it all ready to go tomorrow, should be up and running this weekend
I also have to do all the electric installation for the gauges (routing etc)
Almost there!
fantastic progress! Everything looks great! I love that cut ring. Im doing that when I swap out bottom ends. If anything just for piece of mind.
I have the ZR-2 multi gauge and the ZT-2 logger so everything is real easy. But there are inputs for all of the mentioned sensors in the actually logger (ZT-2). I just bit the bullet and ordered the fuel pressure sender and boost/vac sender from zeitronix. Then for the fuel pressure I modified the incoming line for fuel under the manifold and put the sender inline there.
For rpm and TPS, which are an absolute must, I spliced in to the DMW wires. Just broke out my bentley wire diagrams and figured it out. Works perfect. I absolutely LOVE my zeitronix setup. Especially with the black box. I turn it on every time I drive.
Having the logged afr, boost, rpm, and tps in WOT street pulls and in daily driving and in idle, it really helps out the remote tuner such as TRM etc.
Thanks will do
Some more progress, got the AFR and true boost wired along with oil temp, oil pressure and water temp
Some more pics through out the day.
I also finished doing the last torque sequence for the ARPs.
Cams are also installed along with the SPA turbo manifold, VANOS and radiator
Tomorrow Ill be installing the GT35R and do some piping...
Getting there
Im almost done! She should be up and running by Wednesday
A few more goodies arrived today
I also was able to find an arm rest, bought it online and should be arriving by the end of this week.
Im full speed ahead trying to finish the turbo installation. Im almost done, missing a few things here and there but the majority is done.
I have to install the down pipe, waste gate and boost controller.
Here is how she seats tonight
Almost done yesterday must mean that you're done now.
So now we have 3 cut-ring users on the forums. Assuming that your gasket works, it will be 3 for 3 for the cut ring!
PT6262 - SPA Mani- NickG Tuning - TiAl - CES Cut-Ring - Blood Sweat & Tears
PT6262 Budget Build!! | CES Cut-Ring Install Thread
Why 2 water temp gauge senders (the blue adapters)?
Too much fun with the Buy Now button I think.Originally Posted by BadBoostedBmwM3
Do I count twice as this is my 2nd cut ring?
One is 36mm and one is 38mm
yup, we all know it!
Got another goodie today
I then proceeded to install the brain of this little monster.
to then test how well I did...
Getting oil pressure...
[ame]http://www.youtube.com/watch?v=Z4Wf4EUkRI4[/ame]
First attempt...
[ame]http://www.youtube.com/watch?v=O99mzAfjIhM[/ame]
And... I didn't do so good.. still lots to get done, I have to change the oil feed line to the turbo, waiting for one more reducer from TRM to connect the intercooler with the cold piping, fix fuel leak which I have to replace a fuel hose under the manifold so the intake manifold must come out again and finally fix a small oil leak from the oil block adaptor.
Then I have to install the Walbro fuel pump.
Should be done by Friday so I can get the exhaust and clutch done
