Page 100 of 104 FirstFirst ... 507590919293949596979899100101102103104 LastLast
Results 2,476 to 2,500 of 2596
Thread: Should I or should I not do it...
  1. #2476
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Installed the 276 and the car is a rocket from 4500 and up but not so happy under.
    I spoke to VAC and they offered me their turbo cams 270/246, they said bigger intake cams and smaller exhaust to help spool, these appear a combination of the 276 and stock cams... hmmmm not sure at the moment.
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  2. #2477
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    good info
    Interested to see if what VAC says is ...true
  3. #2478
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    You could experiment with degreeing -- altering specs to improve spool. Chikinhed may have ideas. I skipped the 276/270 since I rev only to 7200 max and like response. If I was a racer who lined rowing the gears and had a 7600 red line, I might have tried the 276/270. I think they would gain almost twice as much power as the 264/256 -- maybe around 40 rwhp instead of 2latoind 20 rwhp at 25 psi from a big turbo. But I can just raise the boost ibstead.
  4. #2479
    May 2003
    Irvine
    VAC said the turbo cams should yield 60rwhp, also said if I retard the exhaust cam by 1.5 degrees it should help spool and HP, seems like a big intake cam and small exhaust cam is the ticket for a turbo set up.
  5. #2480
    Jun 2005
    New England
    Generally you multiply NA gains by the increase in atmospheric pressure.
  6. #2481
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by milKt View Post
    good info
    Whats with all the coherent and lucid posts lately? Are you in a rehab clinic?
    The correct use of punctuation and capitalization is freaking me out a bit.
  7. #2482
    milKt's Avatar
    All posts use words relative to the topic
    and proper use of prepositions.
    Find me a post that confuses you.
  8. #2483
    Louisville, KY
    turbo m3
    Quote Originally Posted by Matutino View Post
    Installed the 276 and the car is a rocket from 4500 and up but not so happy under. I spoke to VAC and they offered me their turbo cams 270/246, they said bigger intake cams and smaller exhaust to help spool, these appear a combination of the 276 and stock cams... hmmmm not sure at the moment.
    Wow! Didn't George from ICS (years ago) always say that he had great results out of both schrick options...?
    Who else had turbo cams... Bav Sol and edge Motorsports or something like that. But, they were wild (290/270 or something like that).
    This is my signature....
  9. #2484
    May 2003
    Irvine
    The car pulls harder as I swap cams with more aggressive ones, I'm sure 276 will yield the highest rwph, I'm not after the highest number but the most power under the curve, the 276 are violent above 4500rpm!
  10. #2485
    Jun 2005
    New England
    Quote Originally Posted by BadBoostedBmwM3 View Post
    Wow! Didn't George from ICS (years ago) always say that he had great results out of both schrick options...?.
    Back then Schrick did not sell the 276/270. But George probably tried other cams that were more aggressive than the Schrick 264/256
  11. #2486
    Louisville, KY
    turbo m3
    I understand that.
    Good point, I know there were 2 options. I wonder what they were. IIRC, evolve was the company that sold the big turbo cams.
  12. #2487
    milKt's Avatar
    Never heard of them here on the forums.
  13. #2488
    Louisville, KY
    turbo m3
    You are right.
    E something.
    Evosport maybe?
  14. #2489
    May 2003
    Irvine
    276/270 are a beast above 4500rpm!
    I'm getting VAC turbo cams next week, will be able to test all cams available.
    I'm out of town but found this pic from last week, it's been a while since I felt the need to drive the M, I guess 24 PSI gets addicted!
  15. #2490
    Mar 2012
    Renton, Wa
    98 m3
    Yeah i always agreed with everyone about the smaller cam... more usable more time spent there... blah.. but i couldnt go back.. the 276s rolllllllll and that .01s of extra fun seems worth it
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  16. #2491
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    You timing these cams with the blocks? What about the turbo cams, gonna time those with the blocks or what?
  17. #2492
    May 2003
    Irvine
    I manually timed the 256/264, I used the blocks for the 276/270 and will be manually timing the turbo cams as they don't have the ability to use the blocks.
    I'm deciding if I should get the aggressive grind or mild gind from VAC.
    Video of the aggressive turbo cams
  18. #2493
    Apr 2006
    Minnesota eh?
    86 325es
    If I could make my car sound like the ICS car above I would gladly give up 50 hp everywhere.
  19. #2494
    May 2003
    Irvine
    There is a 1/4 mile event tomorrow so I went shopping...
  20. #2495
    Jun 2005
    New England
    If you have E85 why not tune the car to run it?
  21. #2496
    Mar 2012
    Renton, Wa
    98 m3
    Id guess thats 286 duration cams at 1100rpm. My 276s sound pretty close in the low 1ks..
    1989 535i - sold
  22. #2497
    May 2003
    Irvine
    Is an option, E85 is recently been poping out around, currently have 2 new stations within 15 miles.
  23. #2498
    Vancouver, B.C., Canada
    '97 M3
    So, are the 276/270 cams worth the top end for what you lose down low?
  24. #2499
    May 2003
    Irvine
    Quote Originally Posted by chikinhed View Post
    Over 4500 great under not so much, I'm going to be installing stock exhaust cam next.
    I'm in my way to the track, let's see if I can hit 130mph
  25. #2500
    NY
    skateboard
    Next it will be epic motorsports cams for you I thought
    ― George Orwell
