Results 1 to 25 of 29
Thread: Need the procedure for EWS align with INPA
    Vermont
    97 328i Vert, 98 M3 Vert
    I have a 97 328 vert and I'll be doing a manual/auto tranny swap soon. I want to use the DME out of a 96 328is 5 speed car so I have less issues with the swap. Its the same DME so Im not worried about that part. I have the DME and EWS module and one chip from the key from the 5 speed car so they all match. I want to realign the EWS with MY two keys after I install it so I swapped that chip from the 5 speed car into one of my keys and tried to align it with my car using INPA.
    Hope that all makes sense. I will be using the 5speed key and EWS module so I can be sure I can drive it arond after the swap but I really want to be able to realign my two original keys to that new DME when Im done.
    I got everything in INPA communicating. It recognizes the existing DME and the existing EWS module. It even reads the coding info off the new chip. I tried using the ACTIVATE button from inside the EWS module display and INPA switched to the ACTIVATE screen but it just sat there. Two little dots in the upper left corner were kind of flashing and it said Working in green on the bottom of the screen.
    Did I do it right and just not wait long enough? Did I do it wrong? I waited like 5 minutes and the screen never changed.
    Has anyone successfully used INPA to realign an OBDII e36 EWS?
    I would love to know what the procedure is and how long it should take.
    My current version even saw the different chips in the key. The car starts with the correct chip but it wont align to the new chip.
    Just an update: I did more research and found I may only be able to attack this one way. Here's what I have to work with:
    My existing DME
    My Existing EWSII module
    2 keys linked to those items
    DME from a 5 speed
    EWSII module from the 5 speed
    1 key chip from the 5 speed
    I was told the chip and key are linked and can't be separated. So i will have to just insert the new DME and link it to my current EWS and keys. I need the procedure for that on my e36.
    Feb 2009
    Arizona
    1998 e36
    I can turn off EWS on both of your DMEs, original and spare, so you don't have to worry about key alignment and EWS modules
    Sep 2003
    Birmingham, UK
    M3 3.2 in bits and a 540
    Try reading the ISN from your ecu, and then writing to your EWS module/
    If that doesn't work, get easy DIS v44 working, and head to programming, DME-ews aligning.
    Giftschrank Projekt
    Vermont
    Yeah Id rather not go that route. But just in case...whats it cost?
    After doing a few MORE hours of research it turns out I need to transfer the ISN from the DME that's going ito the car to the existing EWSII module and I'll be all set. i guess that's what the sync/alighment process does
    I'm hoping with all the years of knowledge here that someone can tell me if its possible with INPA and how to do it.
    Sep 2003
    Birmingham, UK
    It's possible with DIS in seconds, so if you can get that working, you will be able to sync them.
    Giftschrank Projekt
    Vermont
    Quote Originally Posted by enda320 View Post
    I appeciate that and I may be giving DIS a try but right now I'd like to see if INPA can do it. I got to the EWS module and got to "Activate". I press F1 like it said to and it get a dialog box asking for some input in this format 0000-FFFF and the default entry is 0x1FF. I'm assuming I need to enter the ISN as a hex code but that's as far as I can get.
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    INPA should read the ISN number from the DME, but to my knowledge you will need to use DIS to write it to your EWS.
    Vermont
    thank you david. The more time I spend using INPA the more I'm thinking the same thing. Ive searched every posible function and test that might have anything to do with this and I just don't see a function for syncing the DME to the EWS. I can indeed get the ISN off the DME.
    It looks like I'll have to get DIS up and running. I don't suppose it runs on Win98? I have carsoft and INPA running on an old laptop I got that has a serial port. Its dedicated for stuff like INPA but it will never run WinXP.
    Sep 2012
    Accra gGana
    1997 BMW E38 (725 TDS)
    INPA can easily syncronize the DDE/DME with the EWS. First get the ISN from the DDE/DME from the coding section of the control board by pressing F3 (atleast by my program). write off the ISN then go to the 'activate' part of the EWS. Press F1 (Writing ISN) and simply type the characters you read off the DDE/DME. Press OK and voila!! the EWS and the DDE/DME are synced
    Mar 2012
    Blakeslee, PA USA
    1995 bmw 740IL
    Great Info.
    Apr 2009
    Vancouver Isl, BC, Canada
    09 335, 98 Evo M3, 01 M3
    the Keys and EWS units are a fixed link, you cannot add keys to an EWS unit without expensive RFID reading/writing hardware.
    The only things you can link are the EWS module(along with any keys that are already linked to it) to your DME.
    If you need a new key, the only way is to order them from the dealer with the Vin of the car the EWS module came from. This could be challenging if you don't have proof of ownership of the car that the module is from.
    Current:
    - 09 335i
    - 98 M3 Eurospec
    - 01 M3
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    Quote Originally Posted by legoman67 View Post
    So if my current EWS2 module is bad and I want to replace it with a working used module from another car, I cannot get it aligned with the current keys I have with my car?
    I thought that each EWS2 module could have multiple keys aligned to it and I could just add my current keys to the module.
    Oct 2017
    Dinuba, Ca.
    2000 BMW 540i
    Quote Originally Posted by hakentt View Post
    Do you still turn off ews I have an issue with a no start how much do u charge?
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    I can remove ews from any ecu you need it done on. PM me if you still need help bud
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
    Manila, Philippines
    2005 BMW X5 4.8is
    Hi all,
    Am working on a 1996 E36 320i here in Manila, Philippines. We determined that the ECU is bad so we bought a used ecu on eBay - a similar Siemens M41.0 no index, B label. The ECU came with a key so I assumed it would work as long as I transfer the key transponder to my old key which will then match the 'new' ecu. So, we install the new ECU and transfer the new key transponder to the old key. We try to start her but no crank. I tried the wire splicing/jumping at the yellow EWS connector and that at least enabled a crank, but no start.
    After this, I figured I needed an EWS DME alignment so I put back the spliced/jumpered wires back to original and tried to do an news align using Progman. This is the guide I used: http://site.ecudoctors.com/tech-data...nt-process.pdf
    However, it seems I did not have the exact same steps mentioned in the guide available to me. So, in Progman, I choose Option 2, Software Loading which has an EWS section but no "EWS Calibration" but rather "EWS Adjustment" so I choose that. The sequence for the Wait 25 seconds was also not the same for me. I was advised by Progman to switch the key to the Off position which I did and then I clicked Continue. After I clicked Continue, there's a message saying 'Waiting 25 seconds' so I wait but then Progman continues to proceed with the adjustment as displayed on the screen. But there was no advice to switch to On position. After a while, I get a message that the adjustment failed.
    Any advice?
    Thanks,
    Philip
    Jul 2004
    Houston, TX
    MCoupe, 328is, Z3, TDI
    Quote Originally Posted by phildg2000 View Post
    Hi all,
    Any advice?
    Thanks,
    Philip
    Use old key transponder.
    -Abel
    - E36 328is ~210-220whp: Lots of Mods. RomRaider self-tune work in progress.
    - 2000 Z3: Many Mods.
    - 2003 VW Jetta TDI Manual 47-50mpg: Many Mods ~300ft/lbs tq, diesel, daily beater. Love/Hate relationship.
    - S52 Estoril M Coupe
    - 2014 328d Wagon, self-tuned, 240hp/400ft-lbs
    Manila, Philippines
    2005 BMW X5 4.8is
    Thanks Abel. You mean I should put back the 'new' ecu, splice/jump the EWS connector wires again and try to start it with the old key (with old transponder intact)?
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    Progman is JUNK for this procedure on an e36 unless you are using a yellowhead diagnostic tool.
    Manila, Philippines
    2005 BMW X5 4.8is
    Now that I've figured out what you mean, I was happily on my way to finally aligning the DME and EWS with PA Soft 1.4. First, I try to do it through the EWS Programming section where there is a button labeled "EWS-DME adaptation". So I press that but it tells me to use the function from DME control module. Always willing to oblige, I do what the computer tells me and proceed to the DME Programming section where I was happy to find another 'EWS-DME adaptation' button. I press that, I get some activity . . . green status bar . . . status bar turns to yellow . . . and i get a "EWS-DME adaptation fail (E = EWS1, DME1, DME2, DME3). All my excitement down the drain
    Any thoughts why the adaptation failed? Do I need to Unlock the EWS first before doing the adaptation? There is a button in the EWS Programming section labeled "Erase/Unlock EWS" and another "Lock EWS".
    Help!
    Apr 2009
    Help!
    If you are trying to do this on the x5 in your profile info then it wont work. It has a newer version of EWS that doesnt allow for re-alignment of mismatched DME's. That feature is only there to reset the rolling code system on an already matched set.
    Current:
    - 09 335i
    - 98 M3 Eurospec
    - 01 M3
    Manila, Philippines
    2005 BMW X5 4.8is
    Sorry for the confusion, no I'm not doing this on my X5 but on a 1996 E36 320i.
    Apr 2009
    Are you using an ADS interface?
    Ive never had much success using anything but DIS for EWS alignment.
    Current:
    - 09 335i
    - 98 M3 Eurospec
    - 01 M3
    Manila, Philippines
    2005 BMW X5 4.8is
    Sorry, what is ADS?
    FWIW, I amusing the 20 pin round diagnostic connector as that is what this E36 has.
    What version of DIS works for you?
    Manila, Philippines
    2005 BMW X5 4.8is
    Sorry, what is ADS?
    Jul 2004
    Houston, TX
    Have you seen this?
    https://www.bimmerforums.com/forum/s...0-vagcom-cable
    It makes it easier to sync ews
    -Abel
