I've removed radiators 4 times from the e38 and in no instance did I have to disconnect anything but the radiator hoses to get the radiator out. No other fluid or AC lines had to be disconnected.
Sent from my iPad using BF.com
1996 BMW 740iL - NEX SS Coilovers - Style 95's - Drilled/Slotted Rotors - Clear Corners - Suede Headliner/Pillars/Rear Deck - Modified MAF - Modified Intake - Front Plate Delete - Cat Delete - Slammed
You are retarded! 'Originally Posted by IcemanBHE
http://s434.photobucket.com/albums/qq67/mcallister95/
production date: 01/95, DUDMD engine chip, Dinan transmission chip, Dinan CAI, Beyern Multis, Magnaflow cats, mufflers, 3" down turn tips. Bilstein shocks, struts, H & R stage II springs, strong strut brace, pornlights, wood ashtrays, leather/wood seatbacks, euro lighted headrests, 750 kidney grills, wood handles, wood maplight, b-pillars out of a 750, Ford Mustang injectors, "E's" AE and LED 3rd brake light special, cats delete, Magnaflow X-pipe, 199K miles
although I haven't done it on the E38 I did pull the radiator on the E39 which is tighter without removing those lines. As others have said, it can be done. It is a PITA you just have to wiggle, tilt, push, and pull numerous times. It might seem impossible and then all of the sudden you will accidentally position it perfectly and it'll be out of there.
i dont know what any of you all are smoking when you say it comes out...those lines are blocking it. on the other side, i have no room to wiggle because of the AC line.
i just disconnected the Trans lines, plugged them up, and it came out within seconds.
i got to see my brown tranny fluid in the process...servicing will be in order at this point.
It's a mass hallucination, those who claim to have done it all experienced that same hallucination at different times over many years. I suspect alien intervention because the radiators got pulled out and new ones put in.
Go over Iceman's DIY again carefully, it comes out, I promise, I did it while crippled and you are young and strong. I have faith in you. :-)
Jack
Be Kind To The Elderly. Life Without Parole Means Nothing To Us.
Have you ever looked around at the group of people you are in and thought, "If the Zombie Apocalypse happens right now, this is what I have to work with."
I'm glad you got it out, keeping the job moving is important.
