They are kind of in the way, but with some patient wiggling you should be able to get it out without taking them off.
Try to clear the passenger side first, according to Ice's writeup. I don't remember how I've done it.
It should just come up well push it toward the fan and pull up its just the plastic air ducts that won't let u pull it up freely but just pull it and it will come out
I was putting rubber mounts on yesterday with the fan shroud and everything on it just lifted it up And moved it toward the engine it was pain in the behind to get the driver one in but did it with our pulling radiator out.
I tried removing the radiator without the cooler lines and was not successful. Since you probably drained most of the fluid, not much should come out of those lines. Be ready with a pan/bucket and you should be alright.
This will give you the opportunity to replace the 2 seals for the cooler lines as well.
-Messan
The above is my 2 cents. Take it or leave it.
01 Shorty Sporty BLK/BLK
I didn't unplug any tranny lines radiator should just come up its gonna be super tight in there but I just pulled it up and it came out.
Good luck
Power steering has been drained not tranny. But I will replace the cooler line for the PS fluid to resivoir as it appears to be leaking now is a good of a time as any.
Aren't they too small for the lines? Or did you tape them on to keep them sealed?
Pulling up just hits the lines.
Wiggle it, twist it and pull it while holding your mouth just right. It comes out without taking any of the lines out.
Jack
Be Kind To The Elderly. Life Without Parole Means Nothing To Us.
Have you ever looked around at the group of people you are in and thought, "If the Zombie Apocalypse happens right now, this is what I have to work with."
It does.
i gotta put my new rad in aswell,maybe this weekend if im lucky.i want to put my ae's in while i'm at it
I was told u can remove the radiator without disconnecting the PS lines but on my 01 740i it was not possible. As the TIS says, disconnect the PS lines and catch the oil that drips out in a bucket below. I didn't bother trying to plug them - you will loose less than a quart of transmission oil. Its a good idea to replace the o ring on each hose before you reconnect them. After you do this the radiator will lift right out. There's so many plastic pieces under the hood it is not worth trying to squeeze it out and end up breaking something.
Jack
Im 43 and retarded, and I did the write up in the DIY forum w/o doing this on a 01 740.....
I'm 62, this is my first automatic and my first V8 and hope I dont have to do it for quite some time.
I have been tinkering with cars most of my adult life and have found that it is frequently quicker to do a bit more disassembly to keep the job moving.
Good luck!
I have replaced radiators on both 740 (M60B40 & M62TUB44) and a 750 - I did not have to disconnect the PS lines. I removed the fan and clutch and the shroud and the radiator pretty much came right out. Of course you disconnect the coolant hoses.
Your car and my car are obviously different. I can assure you that if the radiator could have been removed without removing the PS lines I would have done so. Why do you suppose the BMW TIS says to disconnect the PS lines to remove the radiator? I was simply sharing my experience and didn't expect to be ridiculed for doing so. It takes all of 10 mins to disconnect the PS lines and reconnect them/top off the fluid.
As far as I'm concerned it is a lot like trying to replace the water pump with the aluminum tube in front of it - sure it can be done without removing the tube but removing it takes just a minute and makes the rest of the job so much easier.
Your car and my car are the same, I had no trouble and was crippled at the time. It doesn't lift straight out, it requires a twist and a turn and the new one went in easier than the old one came out. I understand everyone's skill level is different, but this wasn't hard.
Jack
u don't need to disconnect those hoses
Mods: 19in Staggered Style 89s, HR sport lowering springs/Bilistein HD shocks, Tri-stitched M steering wheel, Leather Dash, Custom two tone leather interior (euro 750i) Euro-clear tails, AE's, OEM Xenons, Smoked side markers, PWR- folding mirror retrofit, Wood seat backs, Leather grab handles, "porn" lights, Shadowline, Tint, Electric rear sunshade retrofit, LED interior lights, Alcantara Headliner etc.Maintenance: Complete power steering hose rebuild, complete front suspension rebuild, rear ball joints replaced, inspection II, synthetic oil every ~6k, magnetic drain plug, expansion tank replaced (twice) aluminum throttle cables, etc.
