Originally Posted by
westlotorn
Follow up to above note. Everything is now fixed and working great on the 2005 N62 4.4L X5. The oil smoke from the exhaust is gone. The engine is running good as new. The problem mentioned above was caused by one mistake, the drivers side electircal plug in was not fully inserted in the Vanos plug in. At one point we talked about taking that side apart again and my son had actually started taking that side apart by unplugging the Vanos Control. Once it was plugged back in everything purred. Without it plugged in the car would run great until you put a load on it and it would switch into limp home mode and cut the power to near zero while throwing no codes.
For all those replacing valve stem seals, please do yourself a favor and look into the PCV system on these cars. Check to see if your engine is fully sealed, no air leaks before spending money. Again, the Spark plugs will show if you are burning oil because of valve stem seals, read them before moving forward to change seals. If one or more spark plugs show heavy oil deposits those are the cylinders to look at for valve stem seals. If some are bad change them all. They typically age at the same rate in all cylinders.
If you put your car in a shop to get valve stem seals they will tear it down and end up replacing all the gaskets we replaced and in most cases fix your issue because of the new gaskets and Orings most lilely not because of the valve stem seals. I hope this saves some people money. Many on this forum have helped us fix our cars in the past so I hope this returns the favor.
My wife and I just picked up an X5 so now we have 2 X5's in the family but we sold off two really nice cars, our 2002 530i at 89 K and the 2001 525i at 150K.
Extra benefit: The MPG has jumped back to 20 + on Hwy at 75 MPH like it did years ago. Recently with the smoking exhaust and vacuum issue it would barely make 18 MPG on same trip.
Thank You for taking time to respond with great advice, we changed the parts listed except for the valve stem seals. The Spark Plugs that came out looked great, no sign of oil burning, no carbon build up, no deposits.
For this reason we ruled out valve stem seals and focused on the PCV system, I think BMW uses another term but funciton is for Crankcase ventilation.
FYI, did you now that the reason the pan is exposed to full manifold vacuum in these engines has to do with piston rings, racers found they could run lighter tension oil rings on the piston, less friction and more HP if they put vacuum in the oil pan, it helped the oil ring funciton. Another way to maken an engine more efficient. This was new tech to racers in the 90's but now used in pass car engines.
