Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
Thread: Symptoms of a Bad Throttle Position Sensor
  1. #26
    Jun 2014
    Nairobi, Kenya
    1995 E34 525i (M52B28 Sw
    What happens if you unplug the TPS harness when the car is still on? Should it shut down or continue running but roughly?
    I'm thinking I have a big issue since my idle is a bit high, at 1200rpm and when I replaced the ICV and cleaned the adjacent pipes, idle went down to 1k rpm but I'm thinking the TPS is the fault or am I missing something?
    Well, Better to Burn out, Than it is to Rust.
  2. #27
    Aug 2018
    Berkshire, United Kingdom
    2011 118D
    Sorry to resurrect an old thread. If I change the position sensor over on my 2011 E81, will I have to sync it at all? There are no error codes at present. Hoping it’s just plug & play.
  3. #28
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    This is the E34 forum, better ask for your 2011 E81 in that forum. https://www.bimmerforums.com/forum/f...8-F20-F22-F23)
