The MINI guys have a pretty good Wheel FAQ here: http://www.mini2.com/forum/faq.php?faq=faq_wheels_tyres I think something like this would be a good start. They also have links to Tirerack's website for some good technical info about wheels/tires.
I found it to be very helpful when I was trying to find out more info about winter wheels/tires for my car. And when I started shopping for nicer summer wheels.
4) M coupe (front) 18x8 et35 245/35-18, (rear) 18x11 et13 295/30-18, TCK S/A coilovers. No rubbing, no spacers.
http://i295.photobucket.com/albums/m...e/P1000249.jpg
http://i295.photobucket.com/albums/m...e/IMG_8448.jpg
2002 M coupe - Imola/Imola, 18" BBS LM, Wilwood BBK, TC Kline S/A coilovers, Supersprint V2 stepped headers, SS Section 1 race cats, SS Section 2 X-pipe, SS Race exhaust, 3.73 differential, Sport mode, Dinan ECU
2008 M3 sedan - Melbourne/Black, 6MT, AA test pipes, Dinan exhaust, BPM Sport tune, Dinan intake, Swift springs
many people might define their setup as "perfect", but that's going to vary by opinion (some people prefer flush, poke, tuck, etc...)
so we should make sure all things are defined; ride height, exact tires used, camber settings, and definitely very good measurements taken to define how many mm the wheel/tire is poking/tucking
it's easy enough to post up a wheel/tire setup and say it fits/looks good, but detailed pics/specs/measurements are going to make the sticky more valuable
Perhaps we could have a standard "form" that you fill out before you post up your setup, as well as a standard set of required pictures?
Any roadster with x8.5 or x9 front and x11 or 10.5 rear??? Or the roady is the same fitment as the coupe?
What are you referring to a "wide-body" Z3? 4cyl v 6cyl? pre v. post facelift?
All the 6 cyl non-Ms should be the same as far as fittment, but stock sizes on those varied quite a bit. The 4cyl, 2.3, and some 2.8s came with 16"s. 17s were optional on the 2.8, standard on the 3.0.
Finally, and great idea!!!
I do not think we need an exhaustive list of all setups that work. What we need is a stock and 'aggressive' setup for each model. Anything more will be too confusing and too hard to search through. If you are between stock and aggressive, it works.
Should include Stock specs and then the most aggressive setups that don't rub/still look normal. This can include aftermarket suspensions, spacers, wheel width, offset, tire size, camber plates. What i mean by still look normal, i mean don't require fender rolling or exhibit 'poke' or stretched tires. Those could be other categories.
After having typed that, maybe we need a stock/aggressive per model/suspension. For example:
M, stock suspension
1. Stock offset/fitment
2. Aggressive offset/fitment
M, TCK Suspension
1.
2.
M, TCK w/ camber plates
1.
2.
So on and so forth for all models.
Oh, and I love this site for selecting tires for aftermarket wheels.
http://www.net-comber.com/tirecalc.html
Yes, the 16x7 stock wheels are 46mm offset. The staggered 17" stock wheels are 41mm.
Stated very explicitly, the following are the stock sizes for all Z3s. Doesn't matter what style/color wheels you got, these were the only size combos.
16x7 ET46 225/50-16 F&R (standard all non-M '96-'02 except 3.0i - that's '96-'98 1.9, '97-'00 2.8, '99-'00 2.3, '01-'02 2.5i)
17x7.5 ET41 225/45-17 F (standard '01-'02 3.0i, optional elsewhere)
17x8.5 ET41 245/40-17 R
17x7.5 ET41 225/45-17 F (standard '99-'02 M)
17x9 ET8 245/40-17 R
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
ok, so it goes like this right?
Rear fitment:
-4cyl = narrow fenders + short axles
-6cyl = wider fenders + longer axles
-M = wider fenders + shorter axles (hence the crazy low factory offsets)
Front fitment on all Z3s is the same, regarding actual bodywork or axle length?
dion
'00 M roadster, modded
'98 SVT Contour, lots of mods
'04 Sienna XLE LTD AWD
'08 MB C300 Sport, P1, 18's
Tamiya TA05, Evolution IV MS, CR-01
Kyosho MP777 SP2
Losi BK2 and MRC
Traxxas Slash, hopped-up.
newest toy is the Tamiya TRF801XT
Would any discussion of spacers be appropriate to this thread or are there too many variables?
TIA
Meh I think it can be summed up to anything over 5mm you will want it to be hubcentric or you may experience vibration.Originally Posted by paul4223
Honestly we don't need setups that work just the basic off set info for the 3 models and a thorough explanation of how offset works.
I believe it has already been said but I just wanted to reiterate the point.
thanks; not sure why i typed it like that
somebody already mentioned jonesmechanical, but yeah, seems like i've seen other threads where he's got all the data figured out for maximum backspacing, ideal offsets, tire sizes, etc...
Between him and Asim's RS builds, seems like they've kinda got the maximum ideal setups figured out without being crazy aggressive (excessive camber, pulled fenders, removed fender liners, etc...)
I'm pretty curious about Ghery's 12.5" rear setup, but he's keeping the specs secret
Spacers are more of a band-aid to incorrect fitment wheels, I think the goal of this thread is to achieve ideal fitment without spacers.
Theres not much to be discussed regarding spacers, but im sure if you have nice fitment with spacers we would love to hear your specifications and spacer info.
PRICE CUT on ALL FABRICS
Please include a noobie explanation of what each term means and how each variable changes with wheel size. I think I know what they all mean but I wouldn't feel comfortable calling up someone to order anything.
1999 M Coupe Boston Green, Beige, H&R/Bilsteins, Underdrive Pulleys, Euro 6 speed, UUC SSK and Randy Forbes in the back
2002 2.5 Z3 roadster Oxford Green, auto, all stock
2013 Ram 3500 Crew Cab Dually 385 HP, 850 ft lbs torque at 1600 rpm, all stock and staying that way
2004 Mini Cooper Chili Red, daily driver, modified almost daily
Yeah, ideal offsets are ideal offsets, regardless if spacers are used to achieve that, or if you're using custom 3 piece wheels, so there's not a lot of worthwhile discussion regarding spacersOriginally Posted by blackxs
Wow, great responses, thank you.
I envision this as a pretty basic document particularly if I have to maintain it. So besides what listed below, I think I will add some links and maybe embelish the text a bit. I like the idea of Known Working Offsets to list a mild, average and maxed-out example, for say...16-19". Before we define that, please continue to supply (formatted) info on your set-up.
Suspension. Yeah, fit/no fit data is based around a given suspension set-up but there are too many variables. Maybe we can include that in a suspension sticky at a later date.
Pictures, Yes. I'd be looking for pics that capture different drops and wheel gaps. Detailed info on the set-up is required.
Stock Offsets
General
Front fitment on all Z3s is the same.
Rear fitment:
-M = wider fenders + short axles
Known Working Packages
1) M-Roadster (front) 18x8.5 et+32 235/40-18 (rear) 18x10.5 et+14 295/35-18 tire. Fender roll might be necessary.
2) M-Roadster (front) 17x8.5 et+40 255/40-17 (5mm spacer) (rear) 7x8.5 et+40 255/40-17 (30mm spacer). TCKline SA coilovers. Will Rub the front Fender liner a bit!
3) M-Roadster (front) 18x8.5 et+43-10mm spacer to +33mm et, 255/35-18, (rear) 18x10.5 et+30-18mm spacer to 12mm +et, 295/30-18, TCKline D/A with TCK camber/caster plates, slight rub on front liners.
4) M Coupe (front) 18x8 et35 245/35-18, (rear) 18x11 et13 295/30-18, TCK S/A coilovers. No rubbing, no spacers.
5)
etc.
Terry
Stuff. I got stuff.
I has no spacers
well this is what I'm running for what its worth... had to do with what the wheel sizing is...
M Coupe (Front) 18x8 et 49, 10mm spacer 245/35-18 (rear) 18x10 et 24, 5 mm spacer, 285/30-18 HR/Bilstien
B!
Active HKS Stage 1 S/Crrrrr: m50 intake: Euro Oil Cooler: AA Exhaust: H&R/Bilstien
T T T.... bumped
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
Im running CCW LM20's. Suspension is KWV3 coil over at front. Front is 18x8et32 235/40-18. Rear is 18x11.5et24 315/30-18. At the rear I had to take some material off the trailing arm and the inner part of the liner at the back to clear the tyres. Fronts clear the coil overs by a few mm. No spacers fitted. Car is Z3M 1998.
Sent from my GT-I9100 using Tapatalk
Material off the physical trailing arm? Seems like a bad compromise...
