Page 1 of 6 123456 LastLast
Results 1 to 25 of 130
Thread: The schwarzes loch build - supercharged e36 convertible
    Los Angeles
    '96 328iC, '89 325i
    Talking The schwarzes loch build - supercharged e36 convertible
    Schwarzes loch - black hole....... this build and car has become a black hole
    So I bought the car in the fall of my senior year of high school. I had been saving for it for about 5 years and it took me a good year of searching before I found the right combination of model, color, condition and !!transmission!! I was very very particular with my specifications… it had to be either silver, black or blue, 5 SPEED MANUAL (no negotiation on that one), black or grey interior (or beige if it fit right), not more than 100,000 miles, and either a 328is or 328iC in very good condition or an M3 in decent condition. Well, after about a year of looking at cars in poor condition and priced too high, I saw an ad in the NJ BMW CCA classifieds for a 1996 328iC black on beige, manual, looking to be in good shape, but just a bit too expensive. Checked back a month later and it was still listed, but for LESS!! So I immediately called and it was MINE!!! (I did go and see it/drive it before buying, and it was in very good condition)
    Small issues were a little dent in the nose panel, which also broke the grill on the left side and a very small, unnoticeable dent in the hood (all from the same incident), a small piece of the rear bumper, behind the left rear wheel was cracked, some badges were faded, soft top dog ears were hanging, headliner was sagging, radio and climate control displays were faded, some light wear on drivers bolster, suspension was meh, clutch was ok… blah blah all the normal stuff was wearing out for a 15 year old e36.
    Bear with me on the pictures please, I know nothing about photography and all the shots were with a point and shoot. I tried my best.
    Pictures of when I bought it:
    Before I go any further, I would like to make a huge shout out to my friend Ray (SirDrippington on the forums) who helped me A LOT!! with everything. Without him or his generous help, most of this work would not have been possible, or at best, it would not have been easy. And Ray, you need to post some pictures of your beautiful alpine sedan!!! It is one of the cleanest I have seen.
    Since buying the car, I have been slowly addressing everything, first with the small things (radio, headliner etc.) and then onto upgrades and new replacements parts for stuff that broke, or was wearing out. So in no particular order is the list of repairs/replacements/upgrades to date that I can remember.
    Ground control street kit
    koni yellow sport shocks
    eibach springs 450f 550r
    4 ride height adjusters
    Ground control camber plates
    Lemforder control arms
    Lemforder tie rods
    Meyle FCAB brackets
    Powerflex FCABs
    Eibach Swaybars 28mm F, 21mm R (installed about 1000 miles before)
    Lemforder M3 RTABs
    Rogue Engineering RTAB bushings
    Rogue Engineering RSMs
    Rogue Engineering RSM reinforcement
    Lemforder upper and lower outer trailing arm bushings (all 4 upgraded to ball joints)
    Eibach aluminum strut brace
    Shark Injector
    AFe cold air intake
    Samco silicone intake boot
    M50 intake manifold (not pictured)
    ASC delete
    M3 exhaust
    Bavauto spark plug coils
    NGK spark plugs
    Fan clutch delete
    Cruise control delete
    New OEM clutch and flywheel (I really wish I had gone lightweight flywheel here for better throttle response)
    Aluminum water pump and thermostat housing
    New continental extreme contact DWS tires
    New OEM Nose Panel
    New OEM grill (not pictured)
    OEM Mtech side trim
    New door handle trim
    New windshield/windshield wiper trim
    OEM leather mtech shift knob
    OEM leather shift surround
    Painted brake calipers black
    Painted exhaust black
    Carbon fiber emblems
    Radio backlight fix
    OBC backlight fix
    Ipod integration
    Bavarian soundwerks speakers
    Convertible “dog ears” fix
    Shadow black “328i” rear badge
    Turner Motorsport racing aluminum pedals (black anodized)
    Light smoked Depo corners, side markers, taillights
    Superbrightleds 45 led tower type amber bulbs in corners and tails
    Superbrightleds 45 led tower type white bulbs in brake light
    Superbrightleds 5 led wedge amber bulbs in side markers
    (and all appropriate resistors to avoid bulb out warnings)
    (I also mounted all the extra fuses and relays in the fuse box, and rewrapped all the oem wiring together with the added wiring for an oem look and for a “professional” finish. I wish I had pictures of it because it was a lot of work that I think people on the forums would appreciate)
    ZKW foglights with light smoke laminx and 5000k HID
    Depo (Hella style) headlights retrofitted with TSX projectors (color modded)
    low beams - 6000k morimoto 5Five 50w bulbs and morimoto 5Five 50w ballasts
    Khoalty led angel eyes (with remote fade on/off)
    Future Plans:
    Wheel spacers
    Style 32s (17”/18” not sure)
    or CCWs
    or BBS RK
    Full catback
    M3 front bumper with slats or pre-facelift bumper with ac schnitzer lip (not sure)
    M3 steering wheel
    In any event, I plan to keep this car until the day I die. Maybe someday when the engine starts to go, an s54 will find its way in . . . . . . .
    Pictures of how it sits now:
    First round of pictures and initial mods/changes (mainly cosmetic)
    Hahahaha 4x4 mode
    Second Round of changes
    Some winter shots from 2010/11
    See my dad’s 330ci in the top right covered in snow . . . hehehe . . . the vert gets the garage ftw
    '96 328iC, '96 328i, '89 s52 swapped 325i
    Shadetree30
    Los Angeles
    '96 328iC, '89 325i
    My custom ipod holder and placement
    During suspension work:
    That tie rod was a b**ch to remove . . . See Ray's sedan in the background
    IT’S FLYING!!!!
    That bump stop was like swiss cheese. See how rusted the strut was at the threaded end. The bump stop was actually fused to the rod. Looks like it was truly time to replace the suspension . . .
    Rear springs were quite broken . . . that might have been the occasional rattling I was hearing lol
    Figured out a way to keep the dust covers
    My hands got dirty. Just the way I like them.
    So now here are pictures of how it sits now (minus the m50 manifold, ASC delete, samco boot, and new front grills)
    Shadetree30
    Los Angeles
    '96 328iC, '89 325i
    Constructive comments and criticism are welcome! I hope you like!!!
    Shadetree30
    Pittsburgh, PA
    Give me headaches
    NIce progress man! I like where you've taken it and it's nice to see it kept so clean. Good job.
    Current: e24 - e28 - e34 - e36/8 - 993 - 914 - w124 - w210 - urs6 - P71 CV - t100
    Mar 2011
    OK
    e30, e61
    Thank you for doing things right. Inspiring to see hard work and commitment to detail.
    Compactive's Avatar
    Compactive is offline Helpful. BMW CCA Member
    Moderator
    DMV
    3x 318ti
    some hard work there, keep it up, definitely going in the right direction
    Want a custom signature? Post requests here, or PM me here | My Flickr
    Sep 2011
    Philadelphia, PA
    135i, VF SC E92 M3
    Great progress!
    1000's of parts in stock. Race Shop, Machine Shop, CNC Manufacturing, AWD dyno and more!
    Est. 1984 | Follow us on Facebook! | VAC Blog | mike@vacmotorsports.com | AIM: MichaelAMalloy
    Apr 2006
    Houston, TX
    95 M3, 99 528i M, 98 e39
    very clean. i like it. Very nice car. keep up the good work
    1995 M3 Vortech Supercharged
    Apr 2009
    Houston, Tx
    Non-Practical M52B28
    I like where this is going!...
    I have the same iPhone adapter but this is where I am running mine... (Phone sits in the sun glasses "pocket")
    Keeping OEM radio FTW
    Maybe, consider disengaging the low beam angel eyes and running the high beams only?... Looks more aggressive ... Just a thought...
    Andy
    '98 328Is Arktissilber l OZ Futura 17x9 et18 & 17x10.5 et37 l BC BR
    BC Racing l ECS Tunning l TheBMWPartsStore.com
    Louisilanta
    hybrid
    Great progress, the car is really coming along. I really appreciate/like modded vert's especially.
    If it were mine i'd go ahead and throw wheel spacers on it to get that slightly wider stance, and change out the seats to something with some support. I think this would definitely give it a beefy/badass/manly look and the seats will bring it down to coupe weight. Not to mention you could use/will probably need spacers on your new wheels if you go with something aggressive
    Alpha-N ///M - Youtube
    Daly City, CA
    '02 325ci
    I'd say throw the ambers back onto the front, or even clears. Contrast is a good thing.
    Beautiful car, though! Truly inspiring.
    '02 325ci 5MT
    I take pictures in the San Francisco Bay Area.
    www.eluisphoto.com
    Upton, MA
    e39 540i/a, e30 325i
    Looks good man, reminds me of my first car:
    Just keep yours nice and don't let it look like mine:
    Seriously though, clean ride. Its nice to see someone take care of an e36 and learn on it!
    Tulsa, OK, USA
    97,98 E36 M3
    Great build so far
    98 M3 Coupe
    intake/muffler delete/M50 Manifold/Tuned
    97 M3 Sedan
    intake/X-pipe/ weight redux
    Sold Cars
    99 M3, 95 M3, 92 325i, 95 325i, 09 135i, 96 328i
    Aug 2008
    Rochester, NY
    89 325m50 / 97 328ic
    need an M3 front bumper in the worst way... but I am a little biased.
    2002 BMW X5 4.4
    1997 BMW 328ic 5spd sport Moreagrun Metallic
    1989 BMW 325is 5spd with a M50 swap
    2006 audi a3 apr stage 2 DSG
    Santa Barbara, CA
    '14 Tacoma & '88 300e
    Lookin' good but I hate the smoked/blacked out lights and corners you need some contrast not just an all black blob.
    Feb 2004
    under the bridge
    Racecar
    Quote Originally Posted by cpalella View Post
    I think every owner of an e36 say that at one point
    I like 2nd round, I'd ditch the halos, and get either a lip or an m3 bumper
    Northeast NJ
    X5/5MT || Z4MC
    Tasteful mods, clean car. I'm not partial to the pre-facelift front, but to each their own.
    Past Builds:
    S54 E36 Compact Build|Thread|IG|@_goldfinger|
    Current Fleet:
    Z4 M Coupe - Black Sapphire Metallic over Black
    Stratford, NJ
    '93 325is, '05 Accent
    Must have been nice to put that top down this week in Jersey! I was wishing I had a vert. Nice progress! Good to see people doing it right the first time mechanically.
    Jan 2006
    Ellicott City, MD
    '99 M3 TT stg II
    car looks very clean, great work. That suspension was ridiculous!
    oh, ditch the smoked/blacked corners ASAP. Get OEM clears and call it a day.
    Jul 2011
    Eugene, Oregon
    1992 525i/5
    Clean tasteful mods, good job. Not a huge e36 fan, but I like yours.
    Jan 2005
    Yukon
    '13 VW GLI, sold E36 328
    Quote Originally Posted by WTFPENGUIN View Post
    you are right....however some of us end up getting rid of it
    looks good due, keep up the good work
    BMWMOFO OG. Wetdub OKC Enthusiast. E36(sold), 08 Mazda3(totaled), '12 VW Jetta TDI(buyback)
    , current: '13 VW GLI
    "Horsepower is how fast you hit the wall. Torque is how far you take the wall with you"
    - Jeremy Clarkson -
    Mar 2006
    Colorado
    E36 M3
    looks good... Arnt the ground control pretty low? You dont wanna lower it more? I think a little lower will make it a little more aggressive. Looks pretty good
    Quote Originally Posted by Bane2000 View Post
    I live where this is going!...
    That doesnt look very clean. I like the OP's version better. Even my setup is cleaner than that
    Montecito/CulverCity, CA
    2006 325i, 1978 320i
    Great car and great work you've done to it. This is basically what I'm looking to buy for a more economical DD, but in coupe form.
    Los Angeles
    850X2/Z3X3/1 Ser/3 SerX4
    Looks good... and good upgrades so far
    Mar 2010
    Vancouver,WA
    Avus M3, dumped e46 323i
    Follow klove83s footsteps, god damn his vert is clean..
