Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 54
Thread: Intake Manifold gaskets
  1. #26
    Sunny Cali,
    6.5 second 69 Camaro
    +1
  2. #27
    Oct 2016
    Montgomery, AL
    '92 850i 6-speed (SOLD)
    Quote Originally Posted by dragon850 View Post
    As far as I.M.G. are concerned I highly recommend going the RENZOSIL route and re using your old gaskets. Take them off, clean them well as well as mating surfaces. Apply black RENZOSIL to head and runner surfaces and install the gaskets. Never had a leak on any of them. That stuff is amazing!
    Could you describe your technique of applying RENZOSIL to your old IM gaskets. Exactly how much do you put on (light, heavy)? Do you smear it with your finger or just leave a thin 2mm bead and let it spread out when you tighten the bolts? I remember reading somewhere that you should wait a bit before tightening the bolts because you want to give the sealant a chance to set up. How long do you wait?
    I'm hoping to get a bit more detail than just "apply RENZOSIL." If I ever have to do this job I don't want to do it twice because my RENZOSIL application method was poor. Thanks for your help.
    Sean
  3. #28
    Jun 2008
    TT Cayenne / SC 850
    Quote Originally Posted by Sniff38 View Post
    I'm hoping to get a bit more detail than just "apply RENZOSIL." This is one of my upcoming jobs and I don't want to do it twice because my RENZOSIL application method was poor. Thanks for your help.
    Sean
    I apply a light to medium amount, smear it with your finger, I wait 5 min before installing manifolds and tighter bolts immediately going from inside out.
  4. #29
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Bascially the complete procedure is on my website, see fixes>>>engine general>>>top end overhaul, Excellent write with lots of photos large PDF file Goerge Fontes once send me, 68 pages , overall general cleaning and resealing intake manifolds, safety-wiring oil spray bar banjo bolts, replacing hoses & valve cover gaskets. There are pics how much Hylomar he applied, I do it similar with liquid seal
    and here another one by Sean750 http://bmwe32.masscom.net/sean750/V1...ughIdleFix.htm
    BTW: just got info from someone, the silicone seal set from Max is now $120/set http://bmw8.us/Silicone%20IM%20Gaskets.JPG
    SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
    http://twrite.org/shogunnew/topmenu.html
  5. #30
    Sunny Cali,
    Great info, Question? Is there no need for a healing seal if the gaskets are used?
  6. #31
    dancerst's Avatar
    dancerst is offline life is a dance... BMW CCA Member
    Virginia Beach, VA
    E36 SC,E31 840ci,740iL
    Why not getting new gaskets?
    How this method is better?
  7. #32
    Jun 2008
    TT Cayenne / SC 850
    Quote Originally Posted by dancerst View Post
    $600 worth of gaskets vs $7 in RENZOSIL.
    Same result. 0 leaks verified with smoke machine, several cars over many years.
    Do not use hylomar on there. Does not seal properly at least for me.
  8. #33
    Jan 2005
    Japan
    Just finished to re-seal my M70 intake gaskets 2 weeks ago with liquid seal (we use here in Japan a liquid seal from Toyota, as that is easiest to get for us). No problem at all with liquid seal, last week we made another Alpina B12 M70 engine the same way with liquid seal + also the timing adjustment as per the info in the DIY section.
    No need to get new expensive gaskets, liquid seal works perfect.
    For the nuts for the intake I used a magnetic socket insert for the tool, bought a set 10-19mm from U.K. Ebay cheap, incl. shipping abt. $ 15, search for AK27095 Sealey Magnetic Socket Insert Set 10pc Metric
  9. #34
    Dec 2013
    San Antonio
    850i, '76 2002, '76 530
    Thanks to the E31 members for detailing the process of removing intake manifolds to reseal gaskets. I am in the process of this job now and its been a great help to have this forum as a resource.
  10. #35
    Dec 2013
    San Antonio
    There sure are some worn out parts in my car! I do have a new ignition wire set on hand but it looks like I need to order a couple of crank sensor wires. I dont see how PO owner could even drive this car considering poor condition of fuel and ignition systems.
    Do you guys toss out the fuel rail insulation material and run without it?
  11. #36
    Nov 2011
    VA
    Want 850
    Mine does not have it, nor did it come with it. (That I know of)
  12. #37
    Dec 2013
    San Antonio
    Can someone point me to directions for replacing the crankshaft sensors? I did a search and looked at some other threads but I still haven't found directions on replacing the leads. Thanks,
  13. #38
    San Jose, CA USA
    JFP30, do be careful and gentle with those connectors coming from the engine wire harness that connect to crankshaft sensors. If there are any kinks/breaks somewhere along those leads, you will experience all sorts intermittent LHM problems.
  14. #39
    Dec 2013
    San Antonio
    [QUOTE=ChrisFuture8;29863201]JFP30, do be careful and gentle with those connectors coming from the engine wire harness th
    Thanks, Chris!
    I need to go through harness carefully because I saw some exposed wiring and then i will re-wrap harness with some silicone tape.
    I removed manifolds yesterday so I will pull valve covers in the next day or two and look over top end. Car has 120K miles on it so I hope I dont find and worn cam lobes.
    I will drill banjo bolts for safety wire. Not sure I want to tackle seals at this time.
    I noticed that injectors are mis-matched some with open hole and others with 3-hole nozzles. Wondering if I should buy Bosch replacements 62415 or upgrade to 62429 pieces.
  15. #40
    Jan 2005
    Japan
    Maybe that will help you, I have on my website a very detailed write up with lots of pics, see fixes>>>engine-general>>>top end overhaul, about 70 pages
    M70 TOPEND RECONDITION, Overall general cleaning and resealing intake manifolds, safety-wiring oil spray bar banjo bolts, replacing hoses & valve cover gaskets.
    no, because it is a noise suppressor http://bmwe32.masscom.net/sean750/V1...Suppressor.jpg
    BTW: what is the part number for these 2 noise suppressor parts? Can't find them in the parts catalog, which section?
  16. #41
    Nov 2008
    Maryland
    not enough
    Quote Originally Posted by shogun View Post
    I don't think those are factory. The only one I "thought" had heat shield material in the fuel rails were the alpinas (I'm very hazy on that one, I could be wrong).
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
  17. #42
    Jan 2005
    Japan
    for sure these silvery noise suppressors are factory, even each intake has the 3 brackets for the bolts bolding these under the intakes. http://bmwe32.masscom.net/sean750/en...70/Image12.jpg
    Have never seen an M70 (at least on an E32) without these noise suppressors. There are 3 6mm socket bolts on each set
    I mean the noise suppressors located underneath each manifold
  18. #43
    May 2013
    Stamford, CT
    1991 BMW 850i
    On my 91, there was nothing on the fuel rails (just did my intake gaskets this spring with the toyota stuff mentioned earlier). I am pretty sure I am the only one that has been in there since I bought the car with 32k on it (and have had it for 17 years).
    My Cars - 1991 BMW 850i - mine for fun, 1993 Saab 900c - mine for fun, 2008 Lexus is250 - my daily driver, 2003 Dodge Durango - my wife's, 1994 Acura Legend - gave it to kid
  19. #44
    Dec 2013
    San Antonio
    [QUOTE=shogun;29863760]Maybe that will help you, I have on my website a very detailed write up with lots of pics, see fixes>>>engine-general>>>top end overhaul, about 70 pages
    Thank you, Shogun! I have your instructions saved on my desktop.
    I got valve covers off and thank goodness, cams like fine. I don't see any noticeable wear or grooves. Banjo bolts are tight but I will remove and drill them for safety wire.
    I still haven't decided how I will finish the valve covers. I am tempted to have them powder-coated. Can the stud sleeves be removed from valve covers before they are refinished?
  20. #45
    Dec 2013
    San Antonio
    Method of repairing broken leads
    Quote Originally Posted by ChrisFuture8 View Post
    I noticed some broken insulation and exposed wires that were probably shielded also. What method do you suggest for repairing bare spots in wiring? I thought about using small amounts of silicone rubber wrapping, maybe E6000 glue, but I am not sure this will be sufficient. Thanks,
  21. #46
    Jan 2005
    Japan
    Then better buy one, that was was standard from start to end ,11611729659 Sound insulation From:01/01/1990 To:- Weight:0.059 kg Price:$100.25
    Supersedes: 11611718392(06/01/1987 — 08/04/1994), Part 11611729659 was found on the following vehicles: •7' E32   (11/1986 — 03/1994) •7' E38   (11/1993 — 07/2001) •8' E31   (07/1989 — 05/1999)
    Part 11611729659 was found on the following E31 vehicles:
    •8' E31, 850Ci, Coupe, M70, MANUAL, EUR, (EG11) : Engine acoustics
    •8' E31, 850Ci, Coupe, M70, MANUAL, EUR, (EG12) : Engine acoustics
    •8' E31, 850Ci, Coupe, M70, MANUAL, USA, (EG13) : Engine acoustics
    •8' E31, 850Ci, Coupe, M70, AUTO, EUR, (EG21) : Engine acoustics
    •8' E31, 850Ci, Coupe, M70, AUTO, EUR, (EG22) : Engine acoustics
    •8' E31, 850Ci, Coupe, M70, AUTO, USA, (EG23) : Engine acoustics
    •8' E31, 850Ci, Coupe, M73, AUTO, EUR, (EG41) : Engine acoustics
    •8' E31, 850Ci, Coupe, M73, AUTO, USA, (EG43) : Engine acoustics
    •8' E31, 850CSi, Coupe, S70, MANUAL, EUR, (EG91) : Engine acoustics
    •8' E31, 850CSi, Coupe, S70, MANUAL, EUR, (EG92) : Engine acoustics
    •8' E31, 850CSi, Coupe, S70, MANUAL, USA, (EG93) : Engine acoustics
    http://www.realoem.com/bmw/enUS/show...50#11611729659
    limited qty sale right now here, $53.01 https://www.ecstuning.com/b-genuine-...h/11611729659/
  22. #47
    Oct 2016
    Montgomery, AL
    Are the thin seals that Max Lumens sells (mentioned by Shogun in Post #22) really necessary if you go the REINZOSIL only route to seal your IM gaskets? It seems to me these seals would be redundant as several have claimed REINZOSIL alone applied to your original IM gaskets is sufficient to stop any leaks.
    Sean
  23. #48
    Jun 2008
    TT Cayenne / SC 850
    Sean
    Reinsosil only is more than enough.
  24. #49
    Northern WA USA
    91 850i +++
    Au contraire, mon frere. I've had old intake blocks fail using Reinzosil, Toyota gasket, and Hylomar. The silicone gaskets haven't failed yet. The new ones will be gray instead of orange.
    How come the middle half of any project always takes the most time?
  25. #50
    Jun 2008
    TT Cayenne / SC 850
    Quote Originally Posted by Max Lumens View Post
    Bill, I am sure your gaskets are top notch and will work very well. So far I had very good luck with reinzosil only even with 11.5PSI, but my gaskets only have 50k miles on them...
