Results 1 to 23 of 23
Thread: Dash lights stay on
    Oct 2008
    liverpool uk
    koenig ks8 /e31 850c
    Dash lights stay on
    3 year old batteries flat as a fluke.First off, to day I have changed both batteries,
    now
    The dash lights stay on even when the key is pulled and the car is locked, but the fuel tank shows empty.
    I am thinking that the GM has caused the dash to stay lit and batteries have gone flat.
    any idea's
    IcemanBHE's Avatar
    IcemanBHE is offline ¿pǝpɹɐʇǝɹ noʎ ǝɹɐ
    Wichita,KS/FortCollins,CO
    (4x7)+8=36
    Dave...be more specific.
    The dash lights...?
    Meaning?
    Im guessing the mileage. It goes off then snaps back on after about 5 seconds...and stays lit after doors closed. lights off, car locked.
    95 840Ci, Calypso Red/Silver, 83k - 99 740i, Black/Black, 185k, Alpina Mods - 01 740i, Titanium/Silver, 40k, Sport Pkg
    Complete Turnkey Diagnostic/Programming systems available...PM for details.
    http://www.8Coupe.com - Please register, spot, and help the project.
    Oct 2008
    liverpool uk
    fuel light on tank shows empty. put £40. today
    battery light. lit
    oil light. lit
    caution light. lit
    parking brake lit
    abs light lit
    milage light. lit
    tripometer. lit
    NO KEY IN LOCK, ALARM ON, DOORS LOCKED.
    UNLOCK/OPEN the car, turn the key, instant start.
    abs light. out
    caution light. out
    battery light. out
    oil light. out
    fuel light .ON gauge shows empty
    Mar 2011
    Damascus, Maryland USA
    E31/E32 VWs Tesla
    Sounds like your ignition switch ore some other module/relay is is keeping the HOT_IN_RUN_OR_START circuit energized.
    I'd recommend pulling relays (Like the "Unloader" relays) one at a time..
    If you do pull a relay that cuts those things off, it won't necessarily be the cause, but can point you to the appropriate solution.
    IIRC the General Module drives Consumer-Cut-Off circuits, things like wipers, interior lights, windows...
    Are any of those things still energized after opening the door? Windows? Climate Control? Sunroof?
    '89 735i, '91 850i, '81 MB 380SLC (For Sale), Tesla Model 3, and VW Passat TDI -- Yes, I still repair General Modules, DM for info!
    Oct 2008
    liverpool uk
    just took it for a run.
    fuel guage stays on empty with light on.
    engine temp guage is at 12 oclock even when the key is out.
    I have disconected the batteries for now.
    Feb 2010
    Morecambe, Lancashire, UK
    BMW 840Ci 97, 740i 08,
    Hope you get it sorted Dave!
    I think the fuel level sensors and engine the temp sensor feed the A25 Body electronics module - the EKM
    I don't know if the GM factors into any of the dash/cluster system.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by koenig d View Post
    Just had a 1991 850 in with a similar problem. Fuel guage showing empty when tank was full. Checked BOTH fuel level sensors - both okay. Took out the instrument cluster and opened the back plate to expose the individual guages. Removed the fuel level gauge and noticed that the contact pins mounted to the backboard that the guage sits on, were slightly corroded. Cleaned the pins, light coat of dielectric grease, reinstall and everything works perfectly now.
    Don't know about your "lights on always" issue, but have seen where the cluster backboard starts going crazy. A fellow down in Houston was monkying with the PCB to see if he can replace some of the electronic components, but he was unsuccessful. You may need a new backplate.
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Oct 2008
    liverpool uk
    just got back from a little drive.
    reconected the batteries. same problems as before but engine temp is now at 3 oclock.
    removed the key and all stay on
    Sunny Cali,
    6.5 second 69 Camaro
    Sounds like either the ignition switch or Alternator going out, There is a plug on the other end of the ignition switch, Unplug it and see if the lights go out. Unplug it from the plug, Much easier for testing.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Either the unloader relay K9 is stuck on - or the ignition switch is faulty. As the battery light is ON when the ignition switch is OFF, this means you are still getting power from Fuse 17 - and that gets power from the unloader relay K9 which is energised by the ignition switch.
    My BMW Repair YouTube Channel
    Oct 2008
    liverpool uk
    Quote Originally Posted by Timm View Post
    how do I find k9 Timm?
    thanks for the help guys.
    Sunny Cali,
    IcemanBHE's Avatar
    (4x7)+8=36
    Interesting. Not seen that one b4.
    Oct 2008
    liverpool uk
    SPOT ON TIMM. new K9 relay arrived today.
    all is back to normal.
    thanks.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Good news, glad to hear it!
    Puget Sound, USA
    1996 850ci
    congrats! I would not be able to own this car if not for this forum and it's members.
    Oxford Green Metallic, Parchment leather, 854 badge, EDC stock struts, M-Sport springs, 3.91 LSD, CSI rear sway, 18" M-Pars, M-Sport wheel w/flappy paddles, CD-43 head unit, Strong Strut brace, Euro FTPs, CSI rear defuser
    Previous -
    '70 2002
    '92 525it e34 - Touring
    '97 530i e39
    '06 325xi e91 - Touring
    IcemanBHE's Avatar
    (4x7)+8=36
    Good call T.
    Mar 2016
    US
    03 Mini Cooper S
    I just saw this post and forum. I'm having the same issues with my 03 Cooper S. Dash lights stay on after removing the key. It will go off and come back on. Sometimes stays on until you unhook the battery. I want to locate this unloaded relay (K9) that was mentioned but my fuse box doesn't look like the one in the image attached above. Please help.
    Sunny Cali,
    These yours? I have them, your relays are cheap in comparison.
    Aug 2019
    Madrid
    Mini Cooper R50 2006
    Hi all, I have the same issue on my mini cooper. I can not view the images to identify the k9. Can you help me? Thanks.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    This thread is not relevant to the Mini - the cause is different and so are all the component designations. Try Mini2.com
    Feb 2022
    Mold, Flintshire Uk
    2007 BMW 630 convertible
    I have a similar issue 2007 630i light cluster between dials stays illuminated even when car is locked. Any help in solving this would be much appreciated. Thanks Paul.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    This E31 8 series thread is not relevant to your 2007 630i - post the problem in our BMW Models 6 Series forum 2004+ (E63, E64, F06, F12, F13)
