Ok, this is the problem...
Long story short...
Few days ago I drove my E38 around... As I gain speed, especially around 80km/h, I've heard this annoying noise* + vibration on my feet**, coming from the right-front wheel area(driver side).
But as I drove faster, maybe above 100km/h or maybe more than 110km/h, I realised that noise & vibration becomes less, but not gone...
On a long smooth highway, I swerved my car to the left and right, just to check and make few tests. Then I realised that noise and vibration completely gone, especially when I swerved my car to the right???
I've asked around and some said it could be my tyre... could be the wheel bearing... and some said about replacing the steering rod or something...
Any of you guys here have any ideas or comments or experience this before??? Need more info, just ask
I know there's a lot of expert in here
*(I don't know how to explain/spell how the noise sounds like, but for me its sounds like if your bearing need replacement.)
**(small/mini/few not usual vibration... well I guess you all know what I mean when something just not suppose to be there)
2000 BMW 740iL
Jack up the car, take the wheel off, press the caliper back so the pads don't rub, puy the wheel back on and spin it, if you don;'t hear a grinding sound bearing is good
Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
I'd suggest balancing your tires and rotate them if they're the same on all four corners. If it does the same my guess would be it's the wheel bearings. Just my .02
Ow ok... Will do that "testing" a.s.a.p. around this week...
Thanks for the tips though
...or even better, I'll change both front tyres since both does need to be replace though... My rear tyres are still in superb condition... Then lets see if that "problem" still exist
Thanks for the suggestion though
2000 BMW 740iL
Bad wheel bearings are not always going to make a noise and to check a wheel bearing u grab the wheel at 12 oclock and 6 oclock and move it in and out while keeping the wheel in a fixed position looking for any play in the assembly. If u dont have directional tires I would swap the front wheels left to right and test drive. If the noise moves to the other side of the car then you know the problem is in the wheel assembly.
When you switched lanes to the right and the noise went away, thats a clear indication of a bad right wheel bearing.
As a simple test switch front tires left to right and ill bet the sound is still there. Thats because of the bad wheel bearing.
Dont re-pack the bearing with fresh greese but replace the bearing with new one.
You got it right KGB7.
So... Just to end what I've started, long story short, brought my car to the workshop, jack it up (on the right side), turn the wheel, and that "noise" does exist. The mechanic even jack up & turn the left wheel, just to be sure, and nothing.
Below, the pics of the front/right wheel bearing that had been taken off and replaced.
Before we took this bearing off (after removing the brake disc), we even try to turn it, and yeah, it sound terribly "dry"
So, replaced it with a new one, done!!!
This process of replacing the old with new one just took around 50-55 minutes, or less...
Ow about that "vibration"??? Both front tyres just need to be balanced... Both problem done in 2 hours time(+/-) and I'm a happy man
My E38 is as good as new
THANKS ALL FOR YOUR CONTRIBUTION AND IDEAS
2000 BMW 740iL
Does anyone have instructions or pics on how to replace front wheel bearings on a 2000 E38 740il. It would be appreciated. Thanks.
The hard bit is finding ways around the lack of special tools:
http://www.meeknet.co.uk/E38/E38_Fro...ng_Removal.pdf
My BMW Repair YouTube Channel
