****** SOLD ******
Hi all. Life has changed a bit for me, and a racing budget is no longer in the cards. I'm putting up my race car build for sale.
Take a look at my build thread for details.
It is street legal, and is my daily driver, so I left in the A/C, Heat and Power Windows/Locks. The car is a solid southern car without any hint of rust. It currently has 160k on the clock.
To go racing, a safety cage, updated seat, electrical shutoff and fire system need to be installed.
Price - $8,000 which is less than what I paid for parts ($7,000) and the car ($3000).
Here is a parts list of what is included with the car:
Tire Rack SPEC E36 Coilover Kit
Tire Rack SPEC E36 Camber Plates
UUC Motorwerks SPEC E36 Sway Bar Kit
1995 M3 Strut Bearings
New Strut Washers
New Dust Protection Collars
Meyle Lower Control Arms
Meyle Inner Tie Rod Ends
Meyle Outer Tie Rod Ends
Tie Rod Boots & Clamps
Powerflex Urethane Lower Control Arm Bushings
New BMW Power Steering Reservoir
New Power Steering Hoses
Ground Control Rear Shock Mounts
New Front & Rear Street Tires
Extra R1 scrubs* (3)
Kosei K1 Racing Wheels With R1 Tires
Turner 15mm Wheel Spacers & Lug Bolts
Turner Front Subframe Reinforcement Kit
Vorschlag Nylon Motor Mounts
Bimmerworld Oil Pan Baffle
Oil Pump Nut Welded to Shaft
Oil Pan Gasket
Silicone Brake Duct Hose*
Air Ducts for Fog Light Holes
SPEC E36 Required 3.15:1 LSD
UUC Red Transmission Mounts
Sparco Steering Wheel
OMP Seats (Expired)
Schroth Street Harnesses
Sliding Seat Mount (Driver's Side Only)
Pagid Yellow Front Brake Pads*
Hawk HP Rear Pads*
Recent Flush with Super Blue Racing Brake Fluid
TC Kline 4 Point Bolt-In Roll Bar
Red Line Diff & Trans Fluids
UUC Urethane Trailing Arm Bushings*
UUC Subframe Bushings
Turner Rear Sway Bar Reinforcements
Turner Rear Subframe Reinforcements
Turner Rear Lower Arm Reinforcements
OEM Rear Lower Arm Bushings
Turner Solid Diff Mounts
New BMW ACS Boot*
New Valve Cover Gasket*
AFE drop-In Air Filter
Wink Rear View Mirror
*Parts marked with an asterisk are currently not installed.
Clownshoe Diary - My quest for a BMW Z3 Coupe
1972 2002tii - Malaga
2002 Z3 Coupe 3.0i - Sterling Gray
2009 650i - Carbon Black
2015 228i THP - Estoril Blue
2019 Z4 30 - San Francisco Red
Good luck with sale Tim!!!!
Jay
From wannabe to has been in a few short years..... the older I get, the faster I was
Hellrot99M3, loved reading your build thread and car look nicely prepared. What can you tell me about the clutch, cooling system and have you dyno'd the car recently? Obviously the chassis/suspension is ALL nearly new, just wondering a bit about the drivetrain. If this was referenced somewhere I apologize. Thank you.
Email sent.
Price drop to $8,000.
I am looking for a another car to track only, I am concerned with the 160k mileage on the engine. Has any engine work been done?
As far as I know, nothing has been done inside the engine. I drive the car daily, have autocrossed the car, and have had it wide open at the BMW Performance Center (see videos in build thread). Not a lick of trouble. The car runs strong and is very quick. In fact, you can hear the comment of the starter in the video saying "your car is quick!".
Thanks Jeff. I really hate to see it go too. In the end, practicality wins out.
Will you have the car at C&C next Sat?
Jay
Hopefully not. It is scheduled to be gone tomorrow.
Awesome! Fingers crossed for you.
Jay
Booooooooyahhhhh!!!!!!!!!!!!
Congrats Tim. I think someone got a great deal. When will the Mini show up?
Jay
Thanks Jay!
I just had an offer accepted yesterday on a MINI. I should be picking it up on Thursday afternoon. If all goes well, I'll bring it to C&C.
I hope to be there but if it rains I may stay home. I missed the meeting last night because of a bad case of allergy assisted respiritory crap. Maybe I should have moved to the desert
Jay
If it rains, I probably won't go either. I had a meeting at work run late, so I missed the club meeting last night as well.
