I'm visiting from the E31 forum to inform those interested in retrofitting a multifunction steering wheel in their E34 that I've written an extensive DIY procedure on this topic. Below is a picture of the sport 3-spoke in my E31:
All buttons work including radio, cruise, and phone (note deleted cruise stalk in above photo).
My write-up should significantly reduce the amount of time and effort required. And for those interested in the wheel shown above (the sport 3-spoke), I offer machine shop services ($350) for a ready-to-install solution. (The standard 4-spoke and M 3-spoke MF wheels do not require machining to fit.) The following DIY procedure should answer all questions for those interested (written for E31 but applicable to all airbag equipped BMW's since 1988):
Multifunction Steering Wheel Retrofit.
The radio and phone functions are surprisingly straightforward to do, with cruise functions being a bit more involved. Here are examples of the wheel buttons in action:
[ame="http://www.youtube.com/watch?v=xSIKqx_f69I"]RADIO[/ame]
[ame="http://www.youtube.com/watch?v=-RhONuFV2iI"]PHONE[/ame]
[ame="http://www.youtube.com/watch?v=v7mHfcnE4uE"]CRUISE[/ame]
I have created a separate write-up for bluetooth phone integration. Please post all comments and view my write-up regarding this feature in the E31 forum here: Bluetooth Integration.
Ummm.... where did you find a MF Three Spoke like that? I like it! Actually prefer it to the M Wheel.
Thanks for the information by the way.
That is very cool. Thanks for sharing.
I actually have this very same wheel in my e34 right now, however I did not machine the base, so I do not have any airbag or horn functionality.
If someone wants to trade me their 3-spoke M3 wheel for my wheel, I'd be interested....
Very nicely detailed writeup, by the way.
Yes, it physically bolts to the steering column, however it won't support the slipring that e34s use, as it came from an e46 which uses the column mounted slipring. So I have been driving around using the exact same steering wheel as the OP has, but without airbag/horn/turnsignal cancellation functions.
Check out the OP's writeup link, particularly the pdf supplement regarding the MF wheel, it will explain how to use this wheel properly.
Excellent. This is high on the "to-do" list for my car. Thanks.
LeMons or bust!
this should only work on late 94+
i want a heated steering wheel bad
Incorrect. As stated, machining the sport 3-spoke wheel allows use of the usual wheel-mounted slip ring. In this case, slip ring '261 is used.
Actually, this works for all airbag-equipped BMW's since 1988.
Folks: that's why this is so cool!
Damn it so no airbag no luck
Is it possible to make all the radio functions and cruise control work with an e34 as well, or does that only work because you have a later model (obd2) e31?
Edit: awesome write-up. So I would need a cd43 (as opposed to a stock e34 radio) to interface to the wheel. Can it interface with e34 cruise control?
the earliest multifunction wheel i've seen is on e38s, 97+ e38s have the electronics in the buttons instead of in a control box in the dash like 95-96 e38s
but early airbag e34s have a different spline then later ones and 95 e34s have a different system too, so this mod would only work on late 94+ e34s I believe
You guys may be correct.
Looking at RealOEM, I see the '901 slip ring and '756 airbag go back to 7/90, along with '786 steering wheels on 5 and 7 series. The wheels I've worked with are '788 (on E36; same slip ring and airbag) and '785 (on E31; same slip ring and airbag). If the difference between wheel '786 and the other two is the spline count and not the diameter or thickness then yes - this retrofit wouldn't work without also changing steering columns. However, if wheels '788/'785 are interchangable with '786 - and I think they are - then this retrofit works back to 7/90 for sure.
Pre-7/90 then becomes another issue.
A completely different airbag, slip ring, and steering wheel was used proir to 7/90. So even if the steering wheel is compatible, the airbag system may not be. However, the airbag control unit is the same thru 9/91, leading me to believe the change was in the slip ring design. If anyone has direct experience with these build dates, please chime in.
I pride myself on being accurate. If I missed this detail, I apologize for any confusion. I can confidently say the airbag system is adaptable from 7/90-on, leaving only the steering wheel questionable - all of which are key. I may have to amend my write-up to specify 7/90-on build dates.
Additional feedback welcome.
Last edited by Frankie; 03-02-2012 at 12:07 AM. Reason: correction & clarification
Very Very cool. Once I get my 540 road worthy I'm definitely looking into this. My steering wheel is busted but I have other priorities.
Super cool. I have an e9x airbag in my e34.. I "hand" machined it, and it was a PITA, but got it working.
Glad to see someone did it correctly.
e46 m3, some 740 sport shorts, F30h, LR3 and a 540it
Reviving a very old thread. I just scored a nice M tech wheel with a single stage airbag from a 1998 E39, I'm so excited. I ordered the slip ring, the connector and all the little things suggested on the posted link. I'll be trying to achieve success at this upgrade probably during this weekend or the next one, depending on the arrival of the items. If you guys have any advice or little tricks to do a better job, it will be really helpful. I consider myself very handy but help is always appreciated.
BTW I'm doing this in an Alpinaweiß 1995 525. Thanks a lot guys for the great help you provide to the community.
