Page 12 of 14 FirstFirst ... 234567891011121314 LastLast
Results 276 to 300 of 341
Thread: FS: Brand New Custom E36 M3 Roll Bar
  1. #276
    Atlanta, GA
    1999 m3 and 740iL
    Quote Originally Posted by mslevin View Post
    The cage is installed! Very happy with it. To everyone talking about larger guys in E36s- get a Sparco Sprint L and aluminum door panels. I have no issues fitting in the car and I'm 6'5" ~300lbs. I had to make my own floor adapters to get the seating position right, but I now fit comfortably in the car.
    Looks fantastic. I'm potentially interested in ordering the exact bar you have. Would you be able to take a few pictures of how closely the roll bar hugs the B-pillar on the drivers side? Basically a picture looking towards the rear of the car with the camera right against the window frame - not sure if that makes sense.
    What I'm curious about is if the main hoop is what would prevent the seat from mounting further back - or if the seat falls in between the main hoop. From what I've seen with most roll bars, the wings of the seat may be blocked by the roll bar and prevent it from sliding rearward.
    I'm also tall (6'7) so would love more pictures of your setup in general if you have them (roll bar, seat brackets, harness mounting etc.)
    Thanks!
  2. #277
    mslevin's Avatar
    mslevin is offline Have you checked RealOEM? BMW CCA Member
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    Quote Originally Posted by 5speed300 View Post
    Thanks!
    I can definitely take some pictures tonight. PM me if I don't post them by ~8pm PST. I'll also try to show my seat mount setup, but its kind of hidden by the seat. I will say, while my brackets work well, they were very difficult to install- mostly because there is no clearance anywhere to get any nuts or bolts on. Took some careful planning and lots of mistakes
    The biggest thing preventing a seat from going back farther is the bottom of the B pillar bars. The vertical bars tilt back, so I tilted my seat back a little to get some more room. The side/back of my seat doesn't touch the rollbar at all. This'll be easier to explain with pictures.
  3. #278
    Oct 2016
    Pullman, Wa
    B6 A4 2.7 STK
    Can someone please PM me Ben's number? I sent him an email about a cage, but have not heard back.
  4. #279
    Jun 2002
    Bradford, ON, Canada
    97 328is, 02 Subaru Impr
    I picked up my rollbar on Friday. The packaging job was pretty fantastic. The rollbar itself looks great, I just need to decide what I'm going to do for paint, powdercoat, automotive exterior paint or rattlecan.
    Nelson Papel
    Madeira Violet '97 BMW 328is
  5. #280
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Anyone have any pics of the floor mounting? I'm not sure how I want to approach dealing with the carpet and padding.
    Are people removing the carpet entirely? Cutting it with the bar in place? Cutting an "X" into the material?
  6. #281
    Dec 2012
    Piedmont, CA
    1997 M3
    Quote Originally Posted by golgo13 View Post
    I lifted the carpet, then cut out what was needed. You have to cut the plastic housing underneath anyway, so really need decent amount of access. I was able to put most of it back after I got everything installed. I am terrible with asthenic things so, not beautiful, but good enough for a car primarily used for track.
  7. #282
    Jan 2002
    Corpus Christi Texas
    99 M3
    See here: https://imgur.com/a/LxJQK
    I cut the carpet away and then the plastic cover below.
  8. #283
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by Mouger View Post
    Thanks for sharing! My car is a dedicated track weapon as well.
    Quote Originally Posted by Clifton23 View Post
    Thank you for sharing. That came out pretty clean. What tool did you use for the cutting?
  9. #284
    Atlanta, GA
    1999 m3 and 740iL
    What I really like about your installation is how far back the feet of the main hoop are - basically right up against the rear seat area. Some other installations show a sizable gap there, which limits how far back you can slide the seat.
    Any tips for how you got yours so flush with the rear seat area?
  10. #285
    Jan 2002
    99 M3
    Drill 1 hole in the back corner of one of the front mounts, then put a bolt in it. Go to the other side and do the same. Then do the other 3 bolts per side and then move to the rear mounts.
    I didn't really try to get it close to the rear, that just happened that way. LOL
  11. #286
    Minneapolis, MN
    '97 M3, '02 330i
    Another happy customer! Picked up directly from Ben, so got to chat a minute and see some of the other stuff he's working on. Great guy and nice work.
    Roll bar fit was amazing. Welds look great. My father helped with the install. He has a Kirk in his M3. It looks/fits great, but IMHO this is clearly nicer, and he agreed. He didn't believe it would go in as one piece, since the rear legs on the Kirk bolt on. But of course it did. He also mentioned that it was a pain bending the foot plates to match the contours of the car with the Kirk, while Ben's were spot-on.
    One note regarding the pictures people posted, above: Personally, I'd recommend removing the tar-based sound deadening. Especially on the floor, but under the rear feet as well. At least on my car, it came up in chunks fairly easily with a screwdriver. A little extra work went a long way toward getting the bar nice and snug, as rearward as possible, and with as much clearance to the roof as possible.
    For finish, I went over it with a 3M red scrubber, cleaned with acetone, and then hit it with VHT "Roll bar and chassis paint" in satin black. Cheap, available at many FLAPS, and self-priming. My dad used this on his wheels a year or two ago, and I'm really impressed with how well it has held up. I haven't taken any pics of the finished result yet, but I'm REALLY happy with the finish. Looks great.
  12. #287
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Got the Ben Sipson rollbar in finally.
    Glad the guy above had one with perfect fitment.
    Fitment is a B- as it took some massaging to get it to work.
    Quality of the welds A
    Price A
    I'm happy with it.
  13. #288
    mslevin's Avatar
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    What issues did you have with fitment? Mine went in fine, only issues I had was getting all the sound deadening out of the way. When I first placed it in, it didn't seem quite right, but once it was bolted down the fitment was spot on.
  14. #289
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Maybe it was the chassis, but it took a bit of hammering of the body to get the bar to sit flush. Once I got both feet lined up L/R and F/R, the outside of the passenger side foot was floating by about 1.5".
    You can see the missing paint where I hammered down the sheetmetal to get it to fit:
  15. #290
    Mar 2010
    NJ
    E39 540i, E46 M3, E36 M3
    Ben, are you there?
  16. #291
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by jake93854 View Post
    Ben, are you there?
    Not sure how often he monitors this thread, but I would email him for fastest response.
  17. #292
    Mar 2010
    NJ
    Picked up an X bar cage from NY98M3 yesterday after he decided he no longer planned on using it in his 1998 M3. I will post pics in a few days when it is installed. Very excited
  18. #293
    Aug 2013
    Santa Rosa, CA
    '99 Z3 Coupe, 99 328is
    Is Ben OK? Perhaps on vacation? Moved onto origami? Sent an email about 3 weeks ago and no reply. Do not want to be a pest, but really like the style and quality of his work - Nigel
  19. #294
    Atlanta, GA
    1999 m3 and 740iL
    I just ordered a bar from him last Tuesday and he shipped it out that Friday, so he's definitely still around. Reach out to him again, probably just got lost in his inbox.
    Had him do the setback harness bar as well as raise the height of the harness bar 2 inches. He also built the main hoop 3/4" higher for my track car that doesn't have the sunroof.
  20. #295
    Aug 2013
    Santa Rosa, CA
    Just to let folks know that I was able to get in touch with Ben and he shipped a bar out to California for me. Took about 3 weeks via Greyhound, which is great. As many others have said, Ben's work is very nice - Nigel
  21. #296
    Atlanta, GA
    1999 m3 and 740iL
    Took about the same for mine. One comment for those who are running no-sunroof, you may want him to add more than 3/4" to the height. He was kind enough to do that for me, but the bar still sits 3 inches from the middle of the roof. Ideally I'd like it a tighter fit like the Kirk and TCKline non-sunroof bars I've seen. But he did design them for cars with sunroof and full interior, so I can understand why there's that much space.
    Otherwise was a super easy install and high quality product.
  22. #297
    Sep 2011
    Orange Country, CA. & TW
    E36 M3 Evo & US 3.2
    Very interested. I like the x cross bar design and am wondering if Ben can custom make this the M4 GTS roll bar look?
  23. #298
    Eastford, CT
    E36 M3
    Hey everyone. Just wanted to keep anyone who may be interested updated. I sold my house/shop back in September and moved to Belleair, FL. I am finally settled in and back in action and able to make bars again. Email me if interested as I dont frequent the forums too often. ben.sipson@gmail.com
    Specializing in Custom E30,E36,E46 Roll Bars Follow me on instagram @baysidefabrication
  24. #299
    mslevin's Avatar
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    Free bump and another recommendation for Ben. I get tons of comments/questions about my rollbar anytime I'm at the track or at a meet. Looks great and fits SO MUCH better than all the other bolt-in cages that are mass produced (Autopower, etc). Price is great and quality is top notch!
  25. #300
    Oct 2013
    Atlanta
    98 M3
    Another bump for Ben, mine arrived in about 3 days to Atlanta via Grayhound. Quality looks superb, I would buy again. I will provide pictures once installed. Thanks Ben!
