BMW of Bloomfield
Results 1 to 2 of 2
Thread: FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    Lake Wylie, SC
    2002 Z3Coupe 3.0i
    Hi all. Life has changed a bit for me, and a racing budget is no longer in the cards. I'm putting up my race car build for sale.
    Take a look at my build thread for details.
    It is street legal, and is my daily driver, so I left in the A/C, Heat and Power Windows/Locks.
    To go racing, a safety cage, electrical shutoff and fire system need to be installed.
    Price - $9,000 which is less than what I paid for parts ($7,000) and the car ($3000).
    Clownshoe Diary - My quest for a BMW Z3 Coupe
    1972 2002tii - Malaga
    2002 Z3 Coupe 3.0i - Sterling Gray
    2009 650i - Carbon Black
    2015 228i THP - Estoril Blue
    2019 Z4 30 - San Francisco Red
    Lake Wylie, SC
    2002 Z3Coupe 3.0i
    Parts List
    Here is a parts list of what is included with the car:
    Tire Rack SPEC E36 Coilover Kit
    Tire Rack SPEC E36 Camber Plates
    UUC Motorwerks SPEC E36 Sway Bar Kit
    1995 M3 Strut Bearings
    New Strut Washers
    New Dust Protection Collars
    Meyle Lower Control Arms
    Meyle Inner Tie Rod Ends
    Meyle Outer Tie Rod Ends
    Powerflex Urethane Lower Control Arm Bushings
    New BMW Power Steering Reservoir
    New Power Steering Hoses
    Ground Control Rear Shock Mounts
    New Front & Rear Street Tires
    Extra R1 scrubs* (3)
    Kosei K1 Racing Wheels With R1 Tires
    Turner 15mm Wheel Spacers & Lug Bolts
    Turner Front Subframe Reinforcement Kit
    Vorschlag Nylon Motor Mount
    Bimmerworld Oil Pan Baffle
    Oil Pump Nut Welded to Shaft
    Oil Pan Gasket
    Silicone Brake Duct Hose*
    Air Ducts for Fog Light Holes
    SPEC E36 Required 3.15:1 LSD
    UUC Red Transmission Mounts
    Sparco Steering Wheel
    OMP Seats (Expired)
    Schroth Street Harnesses
    Sliding Seat Mount (Driver's Side Only)
    Pagid Yellow Front Brake Pads*
    Hawk HP Rear Pads*
    Recent Flush with Super Blue Racing Brake Fluid
    TC Kline 4 Point Bolt-In Roll Bar
    Red Line Diff & Trans Fluids
    UUC Urethane Trailing Arm Bushings*
    UUC Subframe Bushings
    Turner Rear Sway Bar Reinforcements
    Turner Rear Subframe Reinforcements
    Turner Rear Lower Arm Reinforcements
    Turner Rear Lower Arm Bushings
    New BMW ACS Boot*
    New Valve Cover Gasket*
    AFE drop-In Air Filter
    *Parts marked with an asterisk are currently not installed.
