email sent
Hey german, thanks for everything. Excellent work. Tick is pretty much gone; it was the oil, just needed a little longer for the pressure to build up and lube everything up.
Definitely recommending german, nice guy, chill, very knowledgeable and skilled, and I learned a lot just listening while he was working on the car. Having a donor car there was clutch when I needed a piece for the hood cable lever. Great value and well worth the drive.
nahsayn: good kickin with you too. Great bball insight. Holy crap, game 4 was even worse than 3. Kobe still destroyed youngin harden.
Kill the Jack.
Thanks man glad everything worked out
Hi im looking for buy a m3 or 335i i was wondering if i could get your number to check out a car for me when i find the car. my email is ba_reefer@yahoo.com thanks
sorry i just saw this message
Tim, are you interested in putting your engine in my car? Either your place or my shop. If we do it at my shop then I can pull my old motor first and would hire you to install your old motor/tranny in my car. If it takes more than a day I'll even put you up in a hotel so you don't have to drive back home and come back in the morning. I got my supercharger kit yesterday, so I'm dying to get your motor running. So I can throw some boost at it and hope it doesn't pop.
Hit me up,
Ryan 707 623 0709
Bump
ever done ignition cylinder replacement. Already have all the panels off, just cant get the ignition cylinder out via the many DIYs posted.
2007 GT3: GT Silver, PCCB, Sharkwerk'd
There are guys who are afraid of the rev limiter and there are guys who use it to save a shift
Bump
thanx again tim for the motor/tranny mounts swap!...car feels sooo much smoother after a freeway ride home and that vibration has kinda levelled off a bit so hopefully that was the cause. here is an example of why i drove 2 1/2 hours in traffic to let tim handle my maintenance. after the mounts were swapped i took it for a spin and noticed that my small vibration was still present,so tim took it for a spin and as soon as he pulled into his garage he informed me that my front braking was HORRIBLE and that he would never drive with brakes like that on his car. needless to say tim had a spare set of ceramic front pads laying around and he proceeded to SWAP out my junk pads for his set! NO QUESTIONS ASKED!... THIS kind of service is why i will CONTINUE to come to tim if i ever need some maintenance work done on my car! PEOPLE if you need some QUALITY work done on your bimmer,I HIGHLY recommend this gentleman!...
Thanks again for choosing wtfgerman
Well I know even though I don't have a bimmer anymore I will still contact Tim if I need any help on my car.
Thank you
Tim-
Can you do an A/C compressor replacement and re-charge on my 5er ?
bump
Can you do a brake fluid flush for my e38? And i'll supply the fluid as well.
Alpina Lip/Muffler Delete/ Shadowline Trim/ Shadowline Grill/CF Roundels /CF Door Pillars/18' TSWs Staggered/Smoked LED Tails/Corners/Side Markers/ 8000K Lows/Fogs/ LED Dual Color Switch Back Turn Signals
Led Reverse Bulbs/LED Interior/Cargo Area/ Puddle Lights
48 SMD LED License Plate Housings
Just curious, clutch and flywheel?
bump
Bump..
bump
How about fancy fender rollin there Tim?
bump
Hey I'm looking to get my RTAB's and FCAB's replaced.
Edit: I sent you an email.
Hey Tim could you change the emergency brake pads on my 99 740?
Do you have any experiencing diagnosing cars for SMOG problems? '94 325i with 180k, had the cats replaced 2 years ago. Replaced the "air intake elbow" a few months ago, nothing changed with SMOG results.
Also, front passenger window has fallen off track, got an estimate from a local shop for ~$350 total.
