I have my 2000 BMW E39 M5 that I am thinking of selling, I have a car lined up, if I can sell the M5 by Friday, if not I will keep the M5. The VIN for the car is WBSDE9345YBZ94711. The M5 is Silverstone Metllic (Paint code 425), with Le Mans-Ble Extended Leather interior (interior code O5LB). The original MSRP on this M5 was $72,995. I am a BMW employee so I can pull any BMW service records up to 61,376 Miles (06/15/2006) and than after that I have all paper reciepts of all the work done on the car since I have $30,000+ in maintainence receipts for the last 3 years that you can have and this was with an employee discount on parts and labor, so it really is much more than $30K. The build sheet has this M5 listed with %100 Options, rear sunshades,park distance control and M5 floor mats (still have the original and they are in great shape. This M5 is in excellent shape with almost no dings on the car (one 1/4" on hood, must see in correct light) and maybe 2 scratches total. The M5 has a couple aftermarket parts on it starting with Bilstien PSS9's suspension all around ($1200+), high flow cats (throws SES light, either software or stock cats will turn off ses light), muffler/resonator delete, Active Autowerke Software upgrade with sport memory ($600), Schrick Cams ($2100+), Active Autowerke Cold air intake system running from bumper ($900), Brembo Big Brake Kit 355mmx32mm rotors ($3600), X5 tabs, e60 545 short shift kit, ZHP Shift Knob, VSL VB3 19x10 rears and 19x9.5 front rims. I had the front bumper replaced due to scratches on the bottom and a small crack in the bottom, I replaced it with a bumper and did the washer nozzle deletes to clean up the front end a bit. It has NC legal 35% tint on it. Rear pads were replaced at 119,500 miles with drilled and slotted rotors The headlight lenses were refinished. I have over $30,000 in paperwork on the car since 2008. The car currently has 121,500 miles on it. With all the aftermarket performance additions this M5 makes around 460 horsepower. Call or text 919-539-3768. I can pull the carfax, this car has a clean carfax. Here is a link to the carfax, you may have to be logged in so I am not sure if it will work. I am asking $17,900 but I am open to any offers. Either PM or call or text me.
http://www.carfaxonline.com/index.cf...ntName=C460338
Here is what was listed on Dealerspeed (BMW's service network, service will not show up performed outside the network) I dont have any of the outside records from BMW of this time period.
-36 Month, 36K Mile Warranty with an in-service date of 12/10/1999 which was covered until 12/10/2002 at JMK BMW
-Certified Pre-Owned 72 Month 100K Mile warranty enrolled in 02/10/2005 and was good until 12/10/2005.
- 1200 Mile Service performed at 1,099 Miles on 1/04/2000
- Drink Holder replaced at 3,941 Miles on 04/28/2000
- Gearshift knob replaced at 6,208 Miles on 08/29/2000
- Roller sun blind/ curtain rear window replaced, 1st oil change, front wipers replaced at 9,496 miles on 01/29/2001
- A/C compressor replaced on 07/05/2001 at 13,483 miles
- Handbrake replaced, drink holder replaced, front fog light replaced, switches for AC unit replaced at 23,238 miles on 02/27/2002
- Switch (cluster) power widnow/ door switch cluster replaced 03/13/2002 at 23,239 miles
- Rear differential center bearing rubber mount replaced at 27,726 miles on 07/02/2002
-Clutch Disk and Pressure plate and battery replaced at 32,934 Miles on 12/21/2002
- Rear drink holder replaced at 32,943 miles on 08/20/2003
- Camshaft sensor replacement at 45,663 on 11/11/2004
- MAF sensor replaced at 47,075 on 12/24/2004
- Catalytic converters replaced at 61,376 Miles on 06/13/2006
Here are the major reciepts that I have from the last couple years. I am only going to write the large jobs that were done, I have much more photographed below, but they may be hard to read. This is just a sample, I did not include many small jobs such as oil changes. A lot of these are just for labor also as they were customer supplied parts.
-Check engine light, Twin connection swtich-N (Coolant temp sensor) and Air mass meter-N (both MAF sensors) $806.88, 5W-40 Synthetic oil change with oil filter $120, at 79,748 miles on 03/04/2009
-Thermostat replacement ($440)/Battery terminals cleaned($44)/ Valve cover gaskets and seal washer valve replaced($584.72)/ Vanos O-Ring Upgrade Kit ($210.00)/ Spark plug replacement ($87.68) at 80,867 Miles on 03/19/2009 TOTAL =$1,333.48
-Mufflers Straight Piped on 09/18/2009 at 83,788 miles ($316.86)
-Fuel pump and fuel filter replaced *$596.09), Camshaft Position sensor ($340.36), Vanos Solenoid Replaced Bank 2 ($788.12), Lowering springs installed ($624.85), Exterior temp sensor ($112.52) at 81,966 on 06/22/2009
- Vanos Solenoid Bank 1 replaced ($745.35)
- Swiches replaced (Nov 30, 2009 $364.91)
- Front brake rotors and pads and super blue brake fuild at 87,432 $686.85
-Position sensor O-rung replaced at 90,223 $178.96
-Bilsteins ordered - March 4 2010 $1,173.13
-X5 tabs orderd Apr 16 2010 $73.82
-Fan Blade, Fan clutch and air box replaced ($649.88)/ coil over adjustment ($132.00), Fender lines installed ($44.00), AC recharged ($123.83), 4 wheel alignment ($100.00), Front thrust arm bushings replaced ($176.00) at 95,561 miles on 1/22/2010
-Regulatin/vent hose/oil FI Shifter level - $921.27 on June 30 2010
- Brembo Brakes ordered $3,433.18 on Oct 23, 2010
-Plugs coils and plug tubes replaced ($836.24), Fuel and intake service (149.99), CPS sensor for Bank 1 ($88.00), Pre cat 02 sensors replaced ($70.40), AA Cold Air intake system installed ($851.00), Short Shift Kit Install ($158.40), seconddary air pump hose replaced ($119.65), Brembo Brakes Installed ($176.00), Oils seperators install ($132.00), Brake fluid flush with SUper Blue ($84.96), Rear Sway bar bushings replaced ($104.83) at 97.086 miles on 5/9/2010
-Installed customer provided cats ($200.00) on 07/23/2010 at 98,032
Call or text 919-539-3768 the car is located in Wilmington North Carolina.
Here is a direct link to my photobucket album. I will try and use the IMG code but I am having issues with them converting. I have around 80+ pictures I will see how many I can get up on here.
http://s137.photobucket.com/albums/q...verstone%20M5/
I may have missed it since I'm on my phone, price?
Too many $$$$$ signs all over the place. What's the price? I can't find it.
In for the price.
[B][center]
Wow they had some trouble with that drink holder didn't they? Lol beautiful car but a clutch replacement at 32k miles? I didn't know these ate clutches that much, unless it was slipped and burned alot. Love that interior! GLWS.
Woah. Ferrari Window Regulator $840?
Lol. Nice car, GLWS
These cars will only go through clutches quickly if you launch them or if you don't know how to properly drive a manual. This is a perfect example of how an ad should look when selling a car.
Thank you, Yes it took a while to create the entire ad. I wanted to put in as much info as I could since people seem to always be asking for more photos or information. Sorry I thought I had the price in, I have it at $17,900 right now. I am open to any offers, I love the car and am really still on the edge of wanting to sell it.
Can't figure out the mileage. Help
And I quote, "The car currently has 121,500 miles on it".Originally Posted by dgarcia09
Is this the same car that was bought for $12,000 on the M5 Board? Looks identical to me.
http://www.m5board.com/vbulletin/sal...tained-nc.html
What's the story if the same car? If you are interested in selling it at the
price you bought it for of $12,000 I would be interested.
nope, 17,900 no rush to sell, only had it for sale because i had another lined up
Looks like it.. .exactly like it?
Nice car, GLWS
X2
Good looking car anyways, there is nothing wrong on trying to make money, there were a lot of people making money by flipping houses and making profit, in his case the profit may not be as much as he though cause we just found out how much he payed for it
Just my .02 cents
16,200 with stock rims and stock sofwtare!!!! BUMP!!! Have another car lined up call opr text 919-539-3768
nice ride.. glws
19 - BMW's: Past / Present
1979-E21 Euro Red/Black-RIP. Where it all began!!
1986-325es/345 Bronze/Tan -SOLD
1992-325IS Silver/Dove-SOLD
1993-325IS-Brilliantrot(Custom)/Tan-SOLD -
2005-E46 M3 ZCP ILB / Grey - SOLD
1999-M3-Alpine/Black - SOLD
1995-M3 Alpine/Dove - SOLD
1997-M3/4/5 Black/Black - SOLD
1994-M-Design/M-Technic - Project car-sold
1995-M3-Avus -track car build
2003 ZHP Mystic Blue/Carmel - SOLD I'm not sure why
2011 M3/4/7 ZCP Lemans / Black /Slicktop - SOLD
1999 M3 Fern GTS-3 Race Car/Track car - SOLD
2003 M3 Stahlgrau/Schwarz - Track Car - SOLD
2001 Euro Imported Slicktop MtechII Touring - S54 6sp
2005 M3 TiSilver/Schwarz - sold
2004 330i 6sp Grey/Black - sold
2003 M3-Sedan Hellrot wGrey/Black Indv Int - DD
2001 M3 Wagon Orient Blue/Red Fox - FOR SALE
wow...I was not expecting to find that blue inside, but I think I like it. Surprised you haven't gone angel eye. Rims and brakes are beautiful on it.
