Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 85
Thread: David Mc's custom INPA Installation
  1. #26
    IL
    2000 740i sport
    Quote Originally Posted by BMWPlanetDude
    I have 2012 files..
    For inpa/ediabas?
  2. #27
    Jul 2012
    Dublin/Ireland
    With wheels
    Quote Originally Posted by purplecty View Post
    For inpa/ediabas?
    Yeah Ipo, Prg files, so they work with Inpa, Edibas, Ncs...July 2012 update. Send me a pm if you want.
  3. #28
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    PM sent
  4. #29
    IL
    2000 740i sport
    PM sent as well!!!!
    David, i just tried to use the quick test on my e38 and i keep getting FAB-function no longer supported for a bunch of modules... What is this?
  5. #30
    Jul 2012
    Dublin/Ireland
    With wheels
    PM sent as well!!!!
    Did I read you were using an Ads inteface on a serial port or did I miss something?
  6. #31
    IL
    2000 740i sport
    No gerts cable, dell d610 true serial port...
  7. #32
    Jun 2010
    United Kingdom
    E87 120d M-Sport
    Question
    Quote Originally Posted by BMWPlanetDude View Post
    ...and the updated CFGDAT files to go with the *.ipo files?
  8. #33
    Jul 2012
    Dublin/Ireland
    With wheels
    Sorry no idea what a gerts cable is...is that still an ads interface or what?
    I am just saying the e38 does not take Ads just in case something was missed.
  9. #34
    Jul 2012
    Dublin/Ireland
    With wheels
    Quote Originally Posted by FAL View Post
    Yeah of course mate
  10. #35
    IL
    2000 740i sport
    Yeah of course mate
    Please Send em over...
  11. #36
    Jul 2012
    Dublin/Ireland
    With wheels
    Gone with the wind...let me know if you got my email...
    40Gb update, good luck guys lol
    Last edited by BMWPlanetDude; 10-08-2012 at 03:29 PM. Reason: Automerged Doublepost
  12. #37
    IL
    2000 740i sport
    40 gb?
  13. #38
    Jul 2012
    Dublin/Ireland
    With wheels
    40 gb?
    You have no idea what I sent you do you lol?
  14. #39
    IL
    2000 740i sport
    Yes i see it now...
  15. #40
    The Netherlands
    BMW 330CI DropTop
    Since when are the .ipo files from the ISTA dvd's compatible with INPA? Pretty sure this is not gonna work.
  16. #41
    IL
    2000 740i sport
    Quote Originally Posted by Beemer187
    Thats what i figured...
  17. #42
    Jul 2012
    Dublin/Ireland
    With wheels
    Quote Originally Posted by Beemer187 View Post
    Ah ah.
    Anyways next time you need something dude, get lost, no need to thank me for the files by the way.
    No wonder why these files are so hard to get and coders are not sharing with all wanabe wizards. On and off.
  18. #43
    IL
    2000 740i sport
    So back to my Q for david
    Could it be from the inpa 3 upgrade to 5? Did it overwrite the older files i needed for the quick tests for the e38? Im able to acess them all individually...
    Calling all Icemans!!!
  19. #44
    Jul 2012
    Dublin/Ireland
    With wheels
    You figured out nothing dude, you can not even connect INPA to your car.
    Of course the files I gave you do work in INPA. These files are for entire line of BMW tools, including NCS etc.
  20. #45
    Oct 2012
    Shreveport, LA, United St
    BMW
    Yes, it definitely works with ADS and I have used it with a Euro-spec E38.
  21. #46
    Dec 2007
    E70 3.0sd E21 323i
    You need to ensure that the revised files I sent you are installed as the last step in the update process, or some files will be overwritten. If this is not the case, re-install the files I sent you and try again.
    If you just did a conventional update from v3.01 to v5.02, you would also have overwritten some critical files. This is the reason that you have to only copy and add the new files to your v3.01 installation rather than just updating, which just overwrites the entire folder content.
  22. #47
    IL
    2000 740i sport
    Ok i followed the instructions doing the update from 3 to 5 but i believe it just said to update. It may of been conventionally done. I gota recheck over things. Maybe start over again or can i just and retain/copy all the files from 3.01 instead of starting all over???
  23. #48
    Dec 2007
    E70 3.0sd E21 323i
    Doing it that way will only save about 10 minutes on a complete install and manual upgrade and at least by doing it the long way you are assured that you have the full content.
  24. #49
    IL
    2000 740i sport
    Quote Originally Posted by David Mc
    So how do i manually upgrade from 3 to 5? I followed the directions you had and i dont remember it stating a manual upgrade... IIRC it says to start from scratch, install 3 then install standard tools and upgrade to 5, which is what i did and must of been auto updated and overwrote the 3.01 files i needed... After installing 6.4.3 do i change my ediabas folder also? Then do the upgrade to 6.4.7 and change that folder as well and manually move the files from 6.4.3 to 6.4.7 and then do step 3 for inpa 2010 and manually move the files to 6.4.7?
  25. #50
    Sep 2010
    england
    1998 bmw m3 coupe smg
    i believe you have to rename the original inpa 3.01 so its not overwritten by version 5,rename 3 back, then you add the files from 5 to 3.
    from davidmc,
    If you point an update to your existing INPA installation (i.e. c:\INPA) the update process will result in all existing files in that folder being replaced (i.e. old c:\INPA\CFGDAT folder will be overwritten with a new c:\INPA\CFGDAT folder etc). This results in the loss of earlier files which may not be contained in the update. Installing the update to the default location (c:\EC-APPS\INPA) creates a new updated INPA installation, allowing you to physically copy the content of the various folders and paste them into the corresponding folders in your existing c:\INPA installation, thereby expanding, rather than replacing the folder content.
