Results 1 to 2 of 2
Thread: DIY Brake booster 5-oring and shaft seal
    Nov 2010
    Santa Ana, CA USA
    1988 m6
    DIY Brake booster 7-o-ring and shaft seal
    Hi Forum Members,
    This is for the following cars, with a Hydraulic brake servo booster, and ABS.
    e23, 728,730,732,733,735,745;
    e24, 628,633,635,m635,m6,L6;
    e28, 525,528,533,535,m535,m5;
    e32, 730,735,750;
    I up dated this DIY, I added the 9.5mm I.D. shaft seal and a how to replace the seal.
    And also added the 2 teflon high pressure internal piston rings. Total 10 piece kit.
    https://picasaweb.google.com/113565887645138328387/BrakeServoBoosterReBuild5NewORings?authkey=Gv1sRgC KnZ_Z7f6JrUyQE#
    Please read the written captions at the bottom of each photo.
    This repair needs to have the booster removed from the car.
    Tools needed: Dremal, vise, bench grinder, battery drill motor with reverse, 1-1/8 inch deep socket, 13mm 1/4 in drive socket with an extension into the drill motor, blade screw driver, 10mm drill bit or 3/8 inch metal drill bit, electric drill motor with 3/8 chuck, dial caliper, and a metric tap 8mm x 1.25.
    Dremal hobby tool at Home Depot $69.00 this is a must have tool to do this job correctly! The Dremal is variable speed.
    http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
    Or try Harbor Freight.
    http://www.harborfreight.com/power-t...kit-97626.html single speed
    EDIT: 12-7-12
    For the following cars, that have a Hydraulic brake servo booster, and ABS.
    e32, 730,735,750;
    This Do It Yourself (DIY) is to re-build the Brake Servo Booster for the e24,e28,e32(735 only) # 34331156925.
    On the e23 it is part # 34331152825
    The e23,e24,e28,e32 (735) only, all of the 10 piece interior repair kit's are identical., for both part numbers.
    And I have added the e32 750 part # 34331161772, which requires a different shaft seal at the firewall.
    And has a slightly higher price.
    I recently rebuilt another hydraulic brake servo booster, and I was amazed at how the rubber o-rings were deformed.
    They are now an oblong shape.
    The large o-ring 38.0mm x 3.0mm, at the front of the booster. It now measures 2.55mm high instead of 3mm.
    And is 3.28mm thick, were it should be again be 3.0mm. And it is noticeably more brittle.
    The smallest o-ring was brittle and it broke when removed.
    BOOSTER REBUILD SERVICE
    I am now offering to rebuild your booster for you, using my 10 piece repair kit. For the e23,e24,e28,e32-735.
    Price is $85.00 + shipping back to you. Cont USA only. USD
    If you send me your address, I can give you an accurate shipping quote.
    Via FedEx Ground home delivery, with tracking.
    And I will send you my address.
    Just send your booster to me, with a $ check. Insure for $175.00.
    PayPal add 4%
    I can also rebuild your e32 750 booster for $95.00 + shipping back to you. Cont USA, USD
    Insure for $220.00
    PayPal add 4%
    REBUILD SERVICE WITH CORE
    I also have a couple of spare rebuilt boosters, and I can send one to you. For the e23,e24,e28,e32-735.
    And you return your old core to me, return shipping on you. Insure for $175.00
    Same price of $85.00 + ship + $60.00 core. Cont USA, USD.
    Core charge is refundable via PayPal.
    PayPal add 4%
    I also have one spare rebuilt booster for the e32 750, that I can send to you.
    And you return your old core to me, shipping on you. Insure for $220.00
    Price is $95.00 + ship + $95.00 core. Cont USA, USD.
    PayPal add 4%
    Just send me an e-mail jay_c_stratton@hotmail.com
    Jay
    '88 M6 Cinnabar Red / Nappa Natur Highline Interior (10-87) Santa Ana, California. USA
    My NEW Website, Link : https://www.jaysbmwparts.com
    Booster repair
    A/C Wingcell Compressor leak repair
    e31 Door Handle Fix,
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    thank you very much, very good pics and explanations.
