Hello Guys,
I am looking for some help from any of you that may have a "late" E46 M3 in your garage you could look at for me.
Late being post 2003 model year to the end of the run E46 M3.
I am looking to confirm plumbing routing on an E46 M3 (MK60) ABS pump. If one of you knows or could confirm what plumbing goes where I would owe you many beers...
Looking at the ABS pump for this conversation oriented with its round bit pointing up (12:00) it has a silver plumbing block under it with the 4 outlets facing you, connector facing your right side
I know thats not how they are mounted in-situ, but for this purpose easiest to discuss.
There are:
2- fittings on the top (facing upwards like the round bit)
4- fittings on the face facing you
The way I am reading the German labeling on the pump I have deduced:
Upward LEFT port - Left Front brake
Upward RIGHT port - Right Rear brake
Forward Top LEFT port - Front Inlet from MC
Forward Top RIGHT port - Rear Inlet from MC
Forward Bottom LEFT port - Right Front brake
Forward Bottom RIGHT port - Left Rear brake.
Thanks again for reading this far and any confirmation (or the right way) you can send my way.
Cheers
jimmy
jimmy p.
88 E30 M3 Zinnoberot - street
88 E30 M3 Lachsilber - SCCA SPU
87 E30 M3 Prodrive British Touring Car 2.0 Litre
04 Ford F350 - V10
06 Audi A3 Brilliant Red / 2.0 / DSG
97 views, no one knows the hydraulic layout of the pump?
Any help greatly appreciated.
Thanks in advance.
jimmy p.
04 Ford F350 - V10
As I recall, the pump is pretty much buried and following the lines w/o the car on a lift would be a challenge.
I'll verify tomorrow, JImmy.
88M3 AW 43k miles Project FS
Thanks very much.
Even confirmation or correction of a few lines would help confirm or deny I was reading the german nomenclature correctly.
Thanks!
jimmy p.
04 Ford F350 - V10
I was correct in regards to the buried aspect. If the car was on a lift, it would help.
From above, I can see the top where the lines exit, but then they disappear.
I do see stamped lettering, which I'm sure you see as well. I'm going to e-mail a pic which probably is of little use.
